    Calendar Down
    8 Posts 2 Posters 4.9k Views 1 Watching
    • N
      Neokamikaze
      I have a problem with the module Calendar. When i activate this my interface Down. After searching, i found this: The module don’t find this methode:
      this.sendSocketNotification("ADD_CALENDAR", {
      			url: url,
      			maximumEntries: this.config.maximumEntries,
      			maximumNumberOfDays: this.config.maximumNumberOfDays,
      			fetchInterval: this.config.fetchInterval
      Have you a same problem ?
      Note from admin: Please use Markdown on code snippets!
      • N
        Neokamikaze
        Visibliy my problem is with the socket.io package. I started the package installation but no change. Have an idea to install this on Debian 8 jessie.
        • N
          Neokamikaze
          This Error
          socket.io.js:1456
          GET http://localhost/socket.io/?EIO=3&transport=polling&t=LKvf3tp 404 (Not Found)
          Request.create @ socket.io.js:1456
          Request @ socket.io.js:1369
          XHR.request @ socket.io.js:1297
          XHR.doPoll @ socket.io.js:1327
          Polling.poll @ socket.io.js:1740
          Polling.doOpen @ socket.io.js:1684
          Transport.open @ socket.io.js:827
          Socket.open @ socket.io.js:248
          Socket @ socket.io.js:129
          Socket @ socket.io.js:55
          Manager.open.Manager.connect @ socket.io.js:4549
          (anonymous function) @ socket.io.js:4859
          • K
            KirAsh4 Moderator
            What hardware are you using? What version of the operating system? How did you install the MagicMirror package?
            • N
              Neokamikaze
              Hi KirAsh4
              I use one VM Debian 8 jessie and Socket.IO 6. I installed the raspberry package that found in the MagicMirror Kit.
              Thanks.
              • N
                Neokamikaze
                Hi All,
                I don’t the solution for my problem. Have you ideas ??
                • K
                  KirAsh4 Moderator
                  I have no idea what you mean with ‘MagicMirror Kit’. Please make sure you install from the official site (http://github.com/MichMich/MagicMirror/) and follow the directions from there. Also note that MM is proven to run on a Raspberry Pi 2 or 3 running the default Rasbian Jessie operating system.
                  • N
                    Neokamikaze
                    Hi KirAsh4,
                    OK Thanks.
                    I’ll test directly on a raspberry and not on a VM.
