    Googlr Photos not syncing with MagicMirror
    12 Posts 2 Posters 1.7k Views 2 Watching
      synint Project Sponsor @synint
      @synint
      RESOLVED
      Hi Sam, I have resolved it and thank you, thank you and thank you it was only through your guidance and help that made me look deeper to resolve the issue.
      SOLUTION
      In a YouTube video I had seen it advised setting the minWidth 1366 and maxHeight to 768 this is the resolution of the TV I am using. Looking at a post on Git hub some one said change the minWidth and maxHeight to null and it does not matter what size your images are (see config file below) and after reboot everything works as it should.
      Cheers,
      John
      				module: "MMM-GooglePhotos",
      				position: "fullscreen_below",
      				albums: ["MagicMirror2024"], // Set your album name. like ["My wedding", "family share", "Travle to Paris"]
      				updateInterval: 15 * 800, // minimum 10 seconds.
      				sort: "random", // "old", "random"
      				uploadAlbum: null, // Only album created by `create_uploadable_album.js`.
      				condition: {
      				fromDate: null, // Or "2018-03", RFC ... format available
      				toDate: null, // Or "2019-12-25",
      				minWidth: null, // Or 400
      				maxWidth: null, // Or 8000
      				minHeight: null, // Or 400
      				maxHeight: null, // Or 8000
      				minWHRatio: null,
      				maxWHRatio: null,
      				// WHRatio = Width/Height ratio ( ==1 : Squared Photo,   < 1 : Portraited Photo, > 1 : Landscaped Photo)
      				showWidth: 800, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.
      				showHeight: 1200,
      				timeFormat: "YYYY/MM/DD HH:mm", // Or `relative` can be used.
      				debug: true,
        sdetweil @synint
        @synint yes, the example in the module doc uses null. and I never set the sizes
