    MMM-MealieMenu Fetch Error
    30 Posts 3 Posters 9.7k Views 3 Watching
    • W Offline
      WallysWellies
      Hello. I have the MMM-MealieMenu module configured and working on an RPi5 but I run into a recurring issue where it will display a fetch error periodically.
      I’m not sure what causes it to be briefly unable to get the meal plan but the “bug” in my mind is that once the module hits that error it will just stop trying to refreshing the data forever, until I restart the Magic Mirror service. Once I restart the service it will get the meal plan and be happy for a few more days.
      I’m wondering if someone with more coding skills than myself can suggest a tweak to (presumably) the node_helper.js file so that it will allow the module to either try again at the next configured refresh cycle, or wait a period of time and retry repeatedly. Lines 120 to 126 seem to be the code block that deals with this particular error.
      I’m not sure where I might find log information to troubleshoot why the fetch error occurs in the first place but it appears to just be temporary as the meal planner remains accessible at it’s URL when using a browser, despite the error on screen. It’s all hosted on the Pi using the docker image.
        sdetweil @WallysWellies
        @WallysWellies I am a mealie user too.
        code looks good. will have to setup and test.
        it does get the data frequently
        60 seconds by default…
        • W Offline
          WallysWellies @sdetweil
          Thanks Sam. Any pointers would be good. It’s a fairly minor thing but it just seems a bit odd that after a single fetch error it just gives up forever (until restarted).
          I’ve discovered the pm2 log so I will try and remember to have a look at that next time it throws the error.
          I changed the config to update once every hour when I initially set it up:
          updateInterval: 60 * 60
            @WallysWellies ok… I’ll watch it running here at 15 min updates…
            well, I found it…
            in the node helper he sets a flag, to say request is active
            if the flag is set when the request comes from the module side
            he just returns… does nothing.
            on error he does not clear the flag
            (bad network, host, authorization… places where there is no recovery
            those make sense…)
                  .catch((error) => {   //<--- had and error here ...
                    this.sendSocketNotification("MEALIE_ERROR", {
                      error: "FETCH_ERROR",
                      details: error,
                      identifier: config.identifier
                  .finally(() => {
                    this.outstandingRequest = false;   // < --- only clears flag on success
            one could examine the error and reset if its a potentially recoverable error…
              @WallysWellies actually, the unrecoverable config errors are handled in a different place…
              so, just copy that one line before the sendSocketNotification for error
              W 2 Replies Last reply Reply Quote 0
              • W Offline
                @sdetweil Thank you for your advice and apologies for the delayed response - I need to enable email notifications or something…
                I will try your suggestion. Much appreciated.
                • W Offline
                  @sdetweil I’m looking at the node_helper.js file and reading your comments and I’m a little unsure what you are suggesting.
                  Are you saying I could edit this code block:
                  .catch((error) => {
                            details: error,
                  to this:
                  .catch((error) => {
                            details: error,
                  Sorry, I can fumble my way around code but I’m far from a programmer!
                    @WallysWellies yes, correct
                    • W Offline
                      @sdetweil Done!
                      I shall try and remember to report back if it seems to have worked - if I do not then we can assume I am a happy customer.
                      Cheers for your time.
                      • W WallysWellies has marked this topic as solved on
                        @WallysWellies remember that this is not an official change, so it could be lost.if you refresh the module
                        • zanixZ Offline
                          zanix
                          @sdetweil said in MMM-MealieMenu Fetch Error:
                          I should probably set the default to something higher. I had it set to 60 seconds while I was developing it.
                          well, I found it…
                          those make sense…)
                                    details: error,
                                .finally(() => {
                          I thought finally() runs even after a catch(), dangit.
                          @WallysWellies said in MMM-MealieMenu Fetch Error:
                          .catch((error) => {
                                    details: error,
                          to this:
                          .catch((error) => {
                                    details: error,
                          I will get this fix added and set the default updateInterval to something a bit more sane soon. Thanks to all for troubleshooting!
                          • W Offline
                            WallysWellies @zanix
                            @zanix Thanks for your input :)
                            I made the change after posting and it certainly doesn’t break anything but I have been playing with some other modules too so have restarted the software several times meaning I haven’t given it a chance to error but based on my understanding it probably shouldn’t anymore. I don’t know why it was in the first place though - the Mealie container is on the Pi so it’s using localhost to retrieve data. Who knows.
                            I did make one other change because I wanted to see the next week of meals, rather than the remaining meals this week. So I changed this line:
                            const startOfWeek = this.getFirstDayOfWeek(config.weekStartsOnMonday);
                            to this:
                            const startOfWeek = moment();
                            It’s pretty crude but if you’re taking suggestions it might be nice to have the option to show x number of days in the future rather than until the end of the week. I don’t believe that’s currently possible natively?
                            Thanks for the module though, it’s great!
                            zanixZ 1 Reply Last reply Reply Quote 0
                            • zanixZ Offline
                              zanix @WallysWellies
                              Hopefully that fixes the issue, let me know otherwise.
                              to this:
                              Before now no, but I did just add the fetch fix, updateInterval default to 1 hour, and some additional meal entry options in version 1.5.0.
                              The options are:
                              • currentWeek: Only show meals for the current week.
                              • dayLimit: How many days will be displayed after today.
                              • entryLimit: How many entries from future days should be shown in total.
                              Now you can just set currentWeek to false to get the same effect.
                              I appreciate that, glad it’s useful!
                              • W Offline
                                WallysWellies
                                @zanix The mealie module has been in an error since yesterday and I wonder if you might be able to help me troubleshoot?
                                I have run the following command:
                                tail -100 .pm2/logs/mm-error.log
                                And at the end I see the following:
                                [2024-05-31 16:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-05-31 17:47:51.580] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-05-31 18:47:51.581] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-05-31 19:47:51.590] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-05-31 20:47:51.571] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-05-31 21:47:51.575] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-05-31 22:47:51.582] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-05-31 23:47:51.574] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 00:47:51.604] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 01:47:51.601] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 02:47:51.576] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 03:47:51.576] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 04:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 05:47:51.575] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 06:47:51.580] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 07:47:51.571] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 08:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 09:47:51.572] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 10:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 11:47:51.576] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 12:47:51.568] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                [2024-06-01 13:47:51.580] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
                                I have confirmed that the correct username / password is in my config.js file (and it has worked previously) - I can login via my laptop using http://raspberrypi:9925/ using these credentials.
                                The config.js file is using the following line for the connection:
                                host: "http://localhost:9925"
                                I use browser / terminal / SSH etc. to access the Pi but if necessary I can connect a keyboard / mouse if that would aid in narrowing down the issue.
                                Do you have any thoughts? I can probably just restart the mirror service but I haven’t yet in case that deletes any valuable information. Any advice would be appreciated.
                                • W Offline
                                  WallysWellies
                                  • I have found the part of Mealie that allows creation of an API key so I could switch to that method for authentication.
                                  • I also see I am a couple of versions behind the Mealie master branch (I use version 1.5.1 - current version is 1.7.0). That looks drastic but it’s only 2 releases behind.
                                  I don’t think either of these things are causing my issue necessarily but it’s a couple of things I can change soon.
                                    @WallysWellies are you using watchtower to keep. your containers up to date?
                                    • W Offline
                                      @sdetweil Mealie is the first time I’ve used docker so it’s totally manual. I’ve never tried to update it - it was setup within the last couple of months.
                                      I was planning to do the update based on the Mealie docs but I could look into watchtower.
                                        @WallysWellies i have watchtower maintain all my docker stacks
                                        • W Offline
                                          @sdetweil I’ll look into it, thanks.
                                          • zanixZ Offline
                                            zanix
                                            I normally use an API key but I just tried my username/password and it worked. I’m on Mealie 1.7.0.
                                            Go ahead and restart MM and see if that works.
                                            Are you on the latest MMM-MealieMenu (1.5.0)? I added an additional log when the auth token fetch fails.
