    Compatibility with raspberry Pi 5 right now and in the future.
    15 Posts 8 Posters 9.6k Views 8 Watching
      alex2 @Linas123
      @Linas123 said in Compatibility with raspberry Pi 5 right now and in the future.:
      I want to upgrade my Magic Mirror from a Pi 3 to the new Pi 5 because my old one takes almost an hour to boot — it’s basically dead already.
      A lot of the modules I use don’t really get updates anymore.
      Do you think I could run into serious problems if I reinstall all of them on the new Pi 5?
      When I set everything up last time, I had issues with almost every module because of Node.js versions and similar things.
      I’m not a coder, so I’m not really able to tweak the modules myself to fix compatibility issues.
      I have a unit with a 3B+ and I’m having much of the same issue. It seems to just hang and many modules are no longer updating.
      S BKeyportB 2 Replies Last reply Reply Quote 0
        sdetweil @alex2
        @alex2 see my reply in your other post
        • mumblebajM Online
          mumblebaj Module Developer @karsten13
          @karsten13 @BKeyport and @Linas123 I have been running MM on trixie since Feb or April I think, No issues. Only issues I had was with the control of my monitor on and off via a scripts but I documented that and posted it in the forum as well.
          • BKeyportB Offline
            BKeyport Module Developer @alex2
            @alex2 Could just need a refresh of the core - sometimes over many updates things will stick just because the OS, NPM, node.js and/or Magicmirror have updated so many times and they just get confused.
            I generally rebuild my system with every major OS release that supports my PIs. Copy off the config files and start fresh.
            • PierreGodeP Offline
              PierreGode Module Developer @Hugo
              @Hugo I been running magic mirror on pi5 since they released it.
