    Error EBADENGINE when installing MM v2.28.0
    28 Posts 2 Posters 8.9k Views 2 Watching
      sdetweil @Ix
      @Ix do
      which node
      Or
      Find /usr -type f -name node
      • I Offline
        Ix @sdetweil
        @sdetweil said in Error EBADENGINE when installing MM v2.28.0:
        @Ix do
        which node
        Or
        these commands don’t output anything.
          sdetweil @Ix
          @Ix well isn’t that interesting.
          do
          sudo apt update
          sudo apt install nodejs
          node -v
          I 2 Replies Last reply Reply Quote 0
          • I Offline
            Ix @sdetweil
            @sdetweil you’re so patient! Thank you!
            mirror@raspberrypi:~ $ sudo apt update
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
            Reading package lists... Done
            Building dependency tree... Done
            Reading state information... Done
            All packages are up to date.
            mirror@raspberrypi:~ $ sudo apt install node.js
            E: Unable to locate package node.js
            E: Couldn't find any package by glob 'node.js'
            mirror@raspberrypi:~ $ node -v
            bash: node: command not found
            rebooted beforehand
            • I Offline
              Ix @sdetweil
              node -v
              ah snap, I made a small mistake here. I redid it without typo:
              mirror@raspberrypi:~ $ sudo apt install nodejs
              nodejs is already the newest version (18.17.1-deb-1nodesource1).
              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              somewhere in my OS must still remain some node debris…
              Edit: tried this:
              mirror@raspberrypi:~ $ sudo apt remove nodejs
              The following packages will be REMOVED:
                nodejs
              0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
              After this operation, 177 MB disk space will be freed.
              Do you want to continue? [Y/n] y
              (Reading database ... 114411 files and directories currently installed.)
              Removing nodejs (18.17.1-deb-1nodesource1) ...
              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_
              modules/yallist' not empty so not removed
              modules/write-file-atomic' not empty so not removed
              modules/wrap-ansi/node_modules/emoji-regex' not empty so not removed
              modules/wrap-ansi-cjs' not empty so not removed
              modules/which' not empty so not removed
              modules/walk-up-path' not empty so not removed
              modules/validate-npm-package-name' not empty so not removed
              modules/validate-npm-package-license' not empty so not removed
              modules/util-deprecate' not empty so not removed
              modules/unique-slug' not empty so not removed
              modules/unique-filename' not empty so not removed
              modules/tuf-js' not empty so not removed
              modules/treeverse' not empty so not removed
              modules/tiny-relative-date' not empty so not removed
              modules/text-table' not empty so not removed
              modules/tar/node_modules/fs-minipass/node_modules/minipass' not empty so not rem
              oved
              modules/ssri' not empty so not removed
              modules/spdx-expression-parse' not empty so not removed
              modules/spdx-exceptions' not empty so not removed
              modules/spdx-correct' not empty so not removed
              modules/socks' not empty so not removed
              modules/socks-proxy-agent' not empty so not removed
              modules/smart-buffer' not empty so not removed
              modules/sigstore' not empty so not removed
              modules/signal-exit' not empty so not removed
              modules/semver/internal' not empty so not removed
              modules/safer-buffer' not empty so not removed
              modules/retry' not empty so not removed
              modules/read' not empty so not removed
              modules/read-package-json-fast' not empty so not removed
              modules/read-cmd-shim' not empty so not removed
              modules/qrcode-terminal' not empty so not removed
              modules/promzard' not empty so not removed
              modules/promise-retry' not empty so not removed
              modules/promise-inflight' not empty so not removed
              modules/promise-call-limit' not empty so not removed
              modules/promise-all-reject-late' not empty so not removed
              modules/proc-log' not empty so not removed
              modules/postcss-selector-parser' not empty so not removed
              modules/path-scurry/dist' not empty so not removed
              modules/parse-conflict-json' not empty so not removed
              modules/pacote/lib/util' not empty so not removed
              modules/npm-user-validate' not empty so not removed
              modules/npm-registry-fetch' not empty so not removed
              modules/npm-profile' not empty so not removed
              modules/npm-pick-manifest' not empty so not removed
              modules/npm-packlist' not empty so not removed
              modules/npm-package-arg' not empty so not removed
              modules/npm-normalize-package-bin' not empty so not removed
              modules/npm-install-checks' not empty so not removed
              modules/npm-bundled' not empty so not removed
              modules/npm-audit-report' not empty so not removed
              modules/normalize-package-data' not empty so not removed
              modules/nopt' not empty so not removed
              modules/node-gyp/node_modules' not empty so not removed
              modules/node-gyp/lib' not empty so not removed
              modules/node-gyp/gyp/pylib' not empty so not removed
              modules/negotiator' not empty so not removed
              modules/mute-stream' not empty so not removed
              modules/ms' not empty so not removed
              modules/mkdirp' not empty so not removed
              modules/minizlib/node_modules/minipass' not empty so not removed
              modules/minipass-sized/node_modules/minipass' not empty so not removed
              modules/minipass-pipeline/node_modules/minipass' not empty so not removed
              modules/minipass-json-stream/node_modules/minipass' not empty so not removed
              modules/minipass-flush/node_modules/minipass' not empty so not removed
              modules/minipass-fetch' not empty so not removed
              modules/minipass-collect' not empty so not removed
              modules/minimatch/dist' not empty so not removed
              modules/make-fetch-happen' not empty so not removed
              modules/lru-cache' not empty so not removed
              modules/libnpmversion' not empty so not removed
              modules/libnpmteam' not empty so not removed
              modules/libnpmsearch' not empty so not removed
              modules/libnpmpublish' not empty so not removed
              modules/libnpmpack' not empty so not removed
              modules/libnpmorg' not empty so not removed
              modules/libnpmhook' not empty so not removed
              modules/libnpmfund' not empty so not removed
              modules/libnpmexec' not empty so not removed
              modules/libnpmdiff' not empty so not removed
              modules/libnpmaccess' not empty so not removed
              modules/just-diff' not empty so not removed
              modules/just-diff-apply' not empty so not removed
              modules/jsonparse' not empty so not removed
              modules/json-stringify-nice' not empty so not removed
              modules/json-parse-even-better-errors' not empty so not removed
              modules/jackspeak/dist' not empty so not removed
              modules/isexe' not empty so not removed
              modules/is-lambda' not empty so not removed
              modules/is-core-module' not empty so not removed
              modules/init-package-json' not empty so not removed
              modules/ini' not empty so not removed
              modules/ignore-walk' not empty so not removed
              modules/iconv-lite' not empty so not removed
              modules/https-proxy-agent' not empty so not removed
              modules/http-proxy-agent' not empty so not removed
              modules/http-cache-semantics' not empty so not removed
              modules/hosted-git-info' not empty so not removed
              modules/graceful-fs' not empty so not removed
              modules/glob/dist' not empty so not removed
              modules/function-bind' not empty so not removed
              modules/fs-minipass' not empty so not removed
              modules/foreground-child' not empty so not removed
              modules/fastest-levenshtein' not empty so not removed
              modules/err-code' not empty so not removed
              modules/encoding' not empty so not removed
              modules/diff/lib/patch' not empty so not removed
              modules/debug/node_modules/ms' not empty so not removed
              modules/cssesc' not empty so not removed
              modules/cross-spawn/node_modules/which' not empty so not removed
              modules/common-ancestor-path' not empty so not removed
              modules/color-name' not empty so not removed
              modules/color-convert' not empty so not removed
              modules/cmd-shim' not empty so not removed
              modules/cidr-regex' not empty so not removed
              modules/ci-info' not empty so not removed
              modules/chownr' not empty so not removed
              modules/chalk/source' not empty so not removed
              modules/cacache' not empty so not removed
              modules/brace-expansion' not empty so not removed
              modules/bin-links' not empty so not removed
              modules/balanced-match' not empty so not removed
              modules/archy' not empty so not removed
              modules/aproba' not empty so not removed
              modules/agent-base/dist' not empty so not removed
              modules/abbrev' not empty so not removed
              modules/@tufjs/models' not empty so not removed
              modules/@tufjs/canonical-json' not empty so not removed
              modules/@sigstore/protobuf-specs/dist/__generated__/google/protobuf' not empty s
              o not removed
              modules/@pkgjs/parseargs' not empty so not removed
              modules/@npmcli/run-script' not empty so not removed
              modules/@npmcli/query' not empty so not removed
              modules/@npmcli/promise-spawn' not empty so not removed
              modules/@npmcli/package-json' not empty so not removed
              modules/@npmcli/name-from-folder' not empty so not removed
              modules/@npmcli/metavuln-calculator' not empty so not removed
              modules/@npmcli/map-workspaces' not empty so not removed
              modules/@npmcli/installed-package-contents' not empty so not removed
              modules/@npmcli/git' not empty so not removed
              modules/@npmcli/fs/lib/cp' not empty so not removed
              modules/@npmcli/config/lib' not empty so not removed
              modules/@npmcli/arborist/lib' not empty so not removed
              modules/@isaacs/string-locale-compare' not empty so not removed
              modules/@isaacs/cliui/node_modules/emoji-regex' not empty so not removed
              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/m
              an1' not empty so not removed
              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/u
              tils' not empty so not removed
              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/c
              ommands' not empty so not removed
              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/docs/
              output/configuring-npm' not empty so not removed
              output/commands' not empty so not removed
              dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/bin'
              Processing triggers for man-db (2.9.4-2) ...
                sdetweil @Ix
                @Ix do
                hash -r
                which node
                which npm
                if they respond then that is the path location of each program
                • I Offline
                  Ix @sdetweil
                  Hey!
                  I tried this several times. it seems like there is no way on my system to properly reinstall node. All I get is the same errors I posted above. So my next step (the one I didn’t want to do) is to set up a completely new system and build up everything from scratch.
                  Anyway thank you for your help!
                    sdetweil @Ix
                    @Ix backup your MagicMirror config
                    see my back up/ restore
