    Calendar Events not passing to MMM-CalendarEXT3
    5 Posts 2 Posters 1.2k Views 2 Watching
      bobbylx
      Hello all, I’ve got an issue I hope someone can help with. My MagicMirror has been working great for a year or so. I use MMM-Calext3, and have generic holidays and a personal google calendar shown. It has worked without issue.
      A few days ago, I was trying to install a module that puts the display to sleep on a schedule and whatnot. In the process, I goofed up my config.js and the mirror would launch but had errors (wrong characters in wrong places type issues). I did not touch any of my calendar entries nore the calendar modules. While troubleshooting why my power/sleep module wasn’t working I saw I was behind on the MM base version, so I updated. I don’t recall updating anything else. I finally just restore the config.js to the working version i copied before I started.
      So now, my MM works, CalEXT3 launches, but I’m not getting any events passed from the default calendar. Again, I did not change a single character in the calendar entries, what is below is what was working fine 48 hours ago. Can someone smarter than myself take a look? I did npm start, but is seems to hang up after the System information line. I left it about 10 minutes with no change or additional lines showing up, eventually just had to ctrl-c out of it. I can put the calendar ICS links in a browser and they still work.
      let config = {
      	address: "localhost",	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
      	language: "en",
      	locale: "en-US",
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			disabled: true,
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_bar"
      			module: "weather",
      			position: "top_bar",
      				type: "current",
      				locationID: "4471641", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				apiKey: "cbbb4aab37f038db12caadaece805ecf"
      			module: "weather",
      			header: "",
      				type: "forecast",
      			module: "MMM-MoonPhase",
      				updateInterval: 43200000,
      				hemisphere: "N",
      				resolution: "detailed",
      				basicColor: "white",
      				title: true,
      				phase: true,
      				moonAlign: "end",
                      		textAlign: "end",
      				alpha: 0.7,
                      		riseAndSet: {
      		                    display: true,
      		                    lon: -78.8,
      		                    lat: 35.6,
      		                    gmtOffset: -5.0
      			  module: "MMM-CalendarExt3",
      			  position: "bottom_bar",
      			   title: "",
      			    mode: "",
      			    weekIndex: 0,
      			    weeksInView: 5,
      			    instanceId: "basicCalendar",
      			    locale: 'en-EN',
      			    maxEventLines: 5,
      			    firstDayOfWeek: 0,
      			    refreshInterval: 120000,
      			    animationSpeed: 0,
      			    useSymbol: false,
      			    useMarquee: false,
      			    fontSize: '25px',
      			    useWeather: true,
      			    displayWeatherTemp: true,
      			    calendarSet: ['family','us_holiday'],
      			                         weatherPayload:(payload) => {
              			 if (Array.isArray(payload?.forecastArray)) {
      			           payload.forecastArray = payload.forecastArray.map((f) => {
      			             f.maxTemperature = Math.round(f.maxTemperature * 9 / 5 + 32)
      			             f.minTemperature = Math.round(f.minTemperature * 9 / 5 + 32)
      		             return f
      			         return payload
      			eventTransformer: (ev) => {
                              if (ev.title.search('Allie') > -1) ev.color = '#ec4899'
      			if (ev.title.search('Em','Emily')> -1) ev.color = '#c084fc'
      			if (ev.title.search('Mom')> -1) ev.color = '#06b6d4'
      			if (ev.title.search('Dad')> -1) ev.color = '#3b82f6'
                              return ev
                               position: "",
                               broadcastPastEvents: true,
                                url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                                color: "red"
                               position: "",
                               maximumNumberOfDays: 60,
                                animationSpeed: 0,
                                fetchInterval: 160000,
                                useSymbol: false,
                                url: "*******",
      			  color: "yellow",
                                      user: '**',
                                      pass: '**',
                                      method: 'basic'
      pi@raspberrypi:~/MagicMirror/config $ npm start
      > magicmirror@2.28.0 start
      [2024-09-05 18:52:35.091] [LOG]   Starting MagicMirror: v2.28.0
      [2024-09-05 18:52:35.152] [LOG]   Loading config ...
      [2024-09-05 18:52:35.159] [LOG]   config template file not exists, no envsubst
      [2024-09-05 18:52:35.178] [WARN]  Invalid module position found for this configuration: {
        module: 'calendar',
        position: '',
        config: { broadcastPastEvents: true, calendars: [ [Object] ] }
      [2024-09-05 18:52:35.181] [WARN]  Invalid module position found for this configuration: {
        module: 'calendar',
        position: '',
          animationSpeed: 0,
          useSymbol: false,
      [2024-09-05 18:52:35.184] [LOG]   Loading module helpers ...
      [2024-09-05 18:52:35.187] [LOG]   No helper found for module: alert.
      [2024-09-05 18:52:35.189] [LOG]   No helper found for module: clock.
      [2024-09-05 18:52:35.191] [LOG]   No helper found for module: weather.
      [2024-09-05 18:52:35.193] [LOG]   No helper found for module: weather.
      [2024-09-05 18:52:35.241] [LOG]   Initializing new module helper ...
      [2024-09-05 18:52:35.243] [LOG]   Module helper loaded: MMM-MoonPhase
      [2024-09-05 18:52:35.244] [LOG]   No helper found for module: MMM-CalendarExt3.
      [2024-09-05 18:52:35.244] [LOG]   All module helpers loaded.
      [2024-09-05 18:52:35.264] [LOG]   Starting server on port 8080 ...
      [2024-09-05 18:52:37.137] [LOG]   Server started ...
      [2024-09-05 18:52:37.142] [LOG]   Connecting socket for: MMM-MoonPhase
      [2024-09-05 18:52:37.144] [LOG]   Starting module helper: MMM-MoonPhase
      [2024-09-05 18:52:37.156] [LOG]   Sockets connected & modules started ...
      [2024-09-05 18:52:37.681] [LOG]   Launching application.
      [2024-09-05 18:52:47.741] [INFO]  System information:
      ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Rev 1.2; raspberry: [object Object]; virtual: false
      ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
      ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1
      ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
        sdetweil @bobbylx
        @bobbylx the new MagicMirror version checks the position against a known list, and “” is invalid
                                 position: "",
        just comment out the position
            //                     position: "",
          bobbylx @sdetweil
          @sdetweil You sir are correct, that fixed it. I guess I should have read some release notes, haha. Thanks for your help.
            sdetweil @bobbylx
            @bobbylx glad you got it working
            we added the checks because we crashed otherwise. we shouldn’t crash.
            there was an error reported in the MagicMirror startup messages as well
              sdetweil @bobbylx
              @bobbylx can you mark this resolved
              • B bobbylx has marked this topic as solved on
