    Trouble Integrating MMM-OpenWeatherMapForecast with OpenWeather API v3.0
    29 Posts 2 Posters 4.8k Views 2 Watching
      Socrates
      I’m having trouble getting the MMM-OpenWeatherMapForecast module to work. It was functioning fine until a few months ago when OpenWeather switched to API v3.0. I generated a new API key for v3.0, removed the old v2.5 key from the MMM-OpenWeatherMapForecast section of my config file, and replaced it with the new key. However, the module still isn’t working. Below is a snippet of my code.
        module: "MMM-OpenWeatherMapForecast",
        header: "Weather",
        classes: "default everyone",
        disabled: false,
          apikey: "v3.0 api",
          latitude: "29.714670",
          longitude: "-95.836860",
          iconset: "5c",
          units: "imperial",
          concise: true,
          forecastLayout: "tiled",
          showExtraCurrentConditions: true,
          showForecastTableColumnHeaderIcons: true,
          showSummary: false,
          showWind: true,
          hourlyForecastInterval: "1",
          forecastHeaderText: false,
          showPrecipitation: true,
          showCurrentConditions: false,
          maxDailiesToShow: 5,
          maxHourliesToShow: 4
        Socrates @sdetweil
        Hello and good evening again. The issue has been resolved. Even after reinstalling the module it did not work. Then i thought about something i would have done years back as a Linux System admin if a rpm package was not able to find depedencies already installed, i went and granted chmod -R 777 * to the MMM-OWMF folder, thus giving it recursive permission to read write and execute to self and guest users. After that i restarted and now I can see the module in my dashboard.
        Thank you so much for standing with me since yesterday and helping me out with this issue. This has been a great learning curve.
        Thanks again!!!
        S S 2 Replies Last reply Reply Quote 0
          sdetweil @Socrates
          @Socrates do a git pull in the module folder to update the code
          S 3 Replies Last reply Reply Quote 0
            Socrates @sdetweil
            Thanks for your replies. I forgot to mention that, before posting this here, i did update the module. Infact to be on the safe side i renamed the folder MMM-OpenWeatherMapForecast to preserve it as a backup, and then used git clone to download the new module and ran npm install from within the MMM-OpenWeatherMapForecast folder.
              Socrates @sdetweil
              Did a git pull no, luck.
                sdetweil @Socrates
                @Socrates ok, edit the node_helper.js
                and change the end of line 63 from
                 HH:mm") + " ** ERROR ** " + error);
                to
                 HH:mm") + " ** ERROR ** " + response .statusCode);
                then restart MagicMirror and look at the output of npm start
                im guessing its 401, access denied
                is your new apikey with a credit card?
                  Socrates @sdetweil
                  Also wanted to let you know I am using one openweather api for a different module in mm and thats working fine, only this module its not working, the module wont even show up on mm screen.
                    sdetweil @Socrates
                    @Socrates I took your config, used my v3 apikey and it works…
                      Socrates @sdetweil
                      hello and good evening again. No i do not have a credit card on file with Openweathermap. Its a free tier.
                      Also, may i request you to guide me where to find the output file? I have mm on auto start while rebooting
                        Socrates @sdetweil
                        So do i need to sign up for a paid API using a credit card? Or do u think there is an inconsistency with my MMM-OWMF module? I have made the changes to the node_helper.js file just as you suggested and restarted MM, still no avail.
                          sdetweil @Socrates
                          @Socrates i believe the 3.0 free tier also requires a credit card on file…
                          they give you 1000 calls no charge per day, but if you go over they charge you
                          see the link ‘Pay as you call’
                          (vs prevent the api from working)
                          this is new for 3.0
                          the linked pages says
                          'One Call API 3.0 is included to the “One call by call” subscription plan only, users pay for the actual use of the product. '
                          if you are using pm2 to autolaunch then the output will be here
                          pm2 logs --lines=xxxx
                          where xxxx is the number of the most recent lines of the log to display,
                          default 15
                          you may need more
                          I always recommend using manual start mode while debugging, this makes the output easier to access
                          pm2 status
                          will show the running apps
                          pm2 stop all
                          will stop them all
                          manual start
                          cd ~/MagicMirror
                          npm start
                          ctrl-c at the terminal or
                          ctrl-q on the mm screen to stop mm
                          once things are resolved
                          pm2 status
                          pm2 start x
                          where x is the number of the line for the app to start or the name on that line
                          0 or MagicMirror as shown below on one of my systems
                          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                          │ 0  │ MagicMirror        │ fork     │ 5    │ online    │ 0%       │ 2.5mb    │
                            sdetweil @Socrates
                            @Socrates said in Trouble Integrating MMM-OpenWeatherMapForecast with OpenWeather API v3.0:
                            all that change did was output the status code to the log , instead of the empty error
                            so, the log output will tell you
                            Im sure its 401
                            I hacked my apikey , and this is what the line should look like in the log
                            [2024-09-09 21:49:07.454] [LOG]   [MMM-OpenWeatherMapForecast] 9-Sep-24 21:49 ** ERROR ** 401
                              Socrates
                              Sounds good, its getting very late here in Houston, I will check this in the morning, add a credit card on file with OpenWeather and subscribe to a v3.0 api, make the changes accordingly and let u know in the morning. Thanks again for helping me out with this.
                                Socrates
                                Ok, before i go to sleep i had to do this.
                                I added a credit card on openweather and subscribed for the plan.
                                created a new api, and added it to the owmf module config file.
                                restarted mm, and navigated to the log file, and i see this…
                                [2024-09-10 00:52:18.498] [LOG] [MMM-OpenWeatherMapForecast] 10-Sep-24 00:52 ** ERROR ** 401
                                [2024-09-10 00:52:18.526] [INFO] .
                                [2024-09-10 00:52:18.527] [INFO] Beginning of Update Data:
                                [2024-09-10 00:52:18.529] [INFO] .
                                [2024-09-10 00:52:18.544] [INFO] {
                                  Socrates @sdetweil
                                  Sorry to keep nagging you. But today morning when i started troubleshooting MM, i see the Weather title bar show up, but the whole module per say is loading.
                                  I have the credit card on file with openweather, and have subscribed to v3.0 api
                                    sdetweil @Socrates
                                    @Socrates can you show the log output?
                                      Socrates @sdetweil
                                      Thanks, i have pm’ed you the output, as the output file contains api keys and all google calander private url details. Hence sent it to you through pm
                                        sdetweil @Socrates
                                        @Socrates sent pm back
                                          Socrates @sdetweil
                                          It looks like i might be facing an issue with the OpenWeather api. Under services tab i see this msg. It looks like Hourly and Daily forcast is still not available to me.
                                          My membership services shows. See screenshot below.
                                          alt text
                                          However my subscription shows its active with the paid membership
                                          alt text
                                          I have written an email to OpenWeather support, as soon as i hear from them, i will report back. I think this has to do with my subscription and for them to activate the daily forcast on my account.
                                            sdetweil @Socrates
                                            @Socrates when u need to upload a pic, use the 2nd icon from the right (upload image) on the editor toolbar
                                              sdetweil @Socrates
                                              @Socrates remember it worked ok from my system
