    Mirror not starting after update
    33 Posts 4 Posters 6.0k Views 4 Watching
      sdetweil @MarcLandis
      @MarcLandis and i just checked 20.9.0 or over
      ill have to look at that
      • C Offline
        chrisfr1976 @sdetweil
        @sdetweil here is my upgrade.log:
        Upgrade started - Di Okt  1 19:33:02 CEST 2024
        system is Linux MagicPi 6.1.21-v7l+ #1642 SMP Mon Apr 3 17:22:30 BST 2023 armv7l GNU/Linux
        user requested to apply changes
        doing test run = false
        the os is PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)" NAME="Raspbian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Node currently installed. Checking version number.
        Minimum Node version: v20.9.0
        Installed Node version: v21.7.3
        Check current Node installation ...
        No Node.js upgrade necessary.
        Check current NPM installation ...
        NPM currently installed. Checking version number.
        Minimum npm version: V10.1.0
        Installed npm version: V10.5.0
        No npm upgrade necessary.
        saving custom.css
        remote name = origin
        upgrading from version 2.28.0 to 2.29.0
        fetching latest revisions
        git fetch rc=0
        current branch = master
        On branch master
        Your branch is behind 'origin/master' by 1 commit, and can be fast-forwarded.
          (use "git pull" to update your local branch)
        Untracked files:
          (use "git add <file>..." to include in what will be committed)
        	core
        	js/main.backup.js
        nothing added to commit but untracked files present (use "git add" to track)
        no files different from github version
        test merge result rc='' , if empty, no conflicts
        executing merge, apply specified
        merge result rc= 0
         Updating 53fc814f..94c3c699 Fast-forward  .eslintignore
            2 -  .eslintrc.json
           93 -  .github/CONTRIBUTING.md
            2 +-  .github/workflows/automated-tests.yaml
            2 +-  .../workflows/{depsreview.yaml => dep-review.yaml}
            2 +  ...{electronRebuild.yaml => electron-rebuild.yaml}
            6 +-  .github/workflows/enforce-pullrequest-rules.yaml
            4 +-  .gitignore
            3 +  .prettierignore
            2 +-  CHANGELOG.md
           77 +-  Collaboration.md
           50 +-  README.md
            4 +-  cspell.config.json
          227 +  eslint.config.mjs
          121 +  fonts/package-lock.json
           18 +-  fonts/package.json
            4 +-  index.html
            1 +  installers/mm.sh
            4 -  js/app.js
           29 +-  js/check_config.js
          104 +-  js/class.js
           21 +-  js/defaults.js
            8 +-  js/electron.js
           50 +-  js/loader.js
           34 +-  js/main.js
           22 +-  js/module.js
           29 +-  js/node_helper.js
           24 +-  js/server.js
           12 +-  js/server_functions.js
           46 +-  js/translator.js
            6 +-  js/utils.js
           41 +-  modules/default/calendar/calendar.js
           38 +-  modules/default/calendar/debug.js
            3 +-  modules/default/compliments/compliments.js
          100 +-  modules/default/defaultmodules.js
            3 +-  .../default/updatenotification/update_helper.js
           19 +-  modules/default/weather/providers/envcanada.js
          342 +-  modules/default/weather/providers/openmeteo.js
           10 +-  .../default/weather/providers/openweathermap.js
           48 +-  modules/default/weather/providers/pirateweather.js
           10 +-  modules/default/weather/providers/smhi.js
           11 +-  modules/default/weather/providers/ukmetoffice.js
           39 +-  .../weather/providers/ukmetofficedatahub.js
           64 +-  modules/default/weather/providers/weatherbit.js
           10 +-  modules/default/weather/providers/weatherflow.js
           10 +-  modules/default/weather/providers/weathergov.js
           38 +-  modules/default/weather/providers/yr.js
           17 +-  modules/default/weather/weather.js
           13 +-  modules/default/weather/weatherutils.js
           36 +-  package-lock.json
         4724 ++++++++++----------  package.json
           51 +-  splashscreen/MagicMirror.plymouth
            8 -  splashscreen/MagicMirror.script
           53 -  splashscreen/splash.png
          Bin 37062 -> 0 bytes  splashscreen/splash_halt.png
          Bin 22304 -> 0 bytes  tests/configs/customregions.js
           23 +  .../modules/calendar/exdate_la_at_midnight_dst.js
            3 +-  .../modules/calendar/exdate_la_at_midnight_std.js
            3 +-  .../modules/calendar/exdate_la_before_midnight.js
            3 +-  .../modules/calendar/exdate_syd_at_midnight_dst.js
            3 +-  .../modules/calendar/exdate_syd_at_midnight_std.js
            3 +-  .../modules/calendar/exdate_syd_before_midnight.js
            3 +-  .../configs/modules/calendar/long-fullday-event.js
            3 +-  .../modules/calendar/single-fullday-event.js
            3 +-  .../modules/calendar/sliceMultiDayEvents.js
           30 +  .../modules/compliments/compliments_cron_entry.js
           18 +  .../compliments/compliments_e2e_cron_entry.js
           18 +  tests/e2e/animateCSS_spec.js
            2 +-  tests/e2e/custom_module_regions_spec.js
           30 +  tests/e2e/helpers/global-setup.js
           57 +-  tests/e2e/modules/calendar_spec.js
           11 -  tests/e2e/modules/compliments_spec.js
           11 +  tests/e2e/modules/newsfeed_spec.js
           31 +-  tests/e2e/modules/weather_hourly_spec.js
            4 +-  tests/e2e/modules_display_spec.js
            2 +-  tests/e2e/serveronly_spec.js
            2 +-  tests/electron/modules/calendar_spec.js
          123 +-  tests/electron/modules/compliments_spec.js
           36 +  tests/mocks/sliceMultiDayEvents.ics
           58 +  tests/unit/functions/server_functions_spec.js
            6 +-  .../modules/default/weather/weather_utils_spec.js
            2 +-  vendor/package-lock.json
           36 +-  vendor/package.json
            3 +-  vendor/vendor.js
            3 +-  84 files changed, 4147 insertions(+), 3078 deletions(-)  delete mode 100644 .eslintignore  delete mode 100644 .eslintrc.json  rename .github/workflows/{depsreview.yaml => dep-review.yaml} (90%)  rename .github/workflows/{electronRebuild.yaml => electron-rebuild.yaml} (77%)
        create mode 100644 cspell.config.json
        create mode 100644 eslint.config.mjs  delete mode 100755 installers/mm.sh  delete mode 100644 splashscreen/MagicMirror.plymouth  delete mode 100644 splashscreen/MagicMirror.script  delete mode 100644 splashscreen/splash.png  delete mode 100644 splashscreen/splash_halt.png
        create mode 100644 tests/configs/customregions.js
        create mode 100644 tests/configs/modules/calendar/sliceMultiDayEvents.js
        create mode 100644 tests/configs/modules/compliments/compliments_cron_entry.js
        create mode 100644 tests/configs/modules/compliments/compliments_e2e_cron_entry.js
        create mode 100644 tests/e2e/custom_module_regions_spec.js
        create mode 100644 tests/mocks/sliceMultiDayEvents.ics
        processor architecture is armv7l
        updating MagicMirror runtime, please wait
        npm ERR! code EBADENGINE
        npm ERR! engine Unsupported engine
        npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.29.0
        npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.29.0
        npm ERR! notsup Required: {"node":">=20.9.0 <21 || 22"}
        npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v21.7.3"}
        npm ERR! A complete log of this run can be found in: /home/chris/.npm/_logs/2024-10-01T17_33_19_444Z-debug-0.log
        npm install completed - Di Okt  1 19:33:27 CEST 2024 on base
        Checking for modules with removed libraries
        downloading dumpactivemodules script
        updating dependencies for active modules with package.json files
        	processing for module MMM-Carousel please wait
        up to date, audited 1 package in 2s
        found 0 vulnerabilities
        	processing complete for module MMM-Carousel
        	processing for module MMM-weconnectid please wait
        	processing complete for module MMM-weconnectid
        	processing for module MMM-BackgroundSlideshow please wait
        added 12 packages, and audited 13 packages in 12s
        3 packages are looking for funding
          run `npm fund` for details
        	processing complete for module MMM-BackgroundSlideshow
        	processing for module mmm-systemtemperature please wait
        added 1 package, and audited 2 packages in 6s
        	processing complete for module mmm-systemtemperature
        	processing for module MMM-pihole-stats please wait
        	processing complete for module MMM-pihole-stats
        	processing for module MMM-NINA please wait
        	processing complete for module MMM-NINA
        	processing for module MMM-Traffic please wait
        added 5 packages, and audited 6 packages in 6s
        	processing complete for module MMM-Traffic
        	processing for module MMM-NowPlayingOnSpotify please wait
        npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        added 131 packages, and audited 694 packages in 1m
        12 packages are looking for funding
        63 vulnerabilities (2 low, 22 moderate, 31 high, 8 critical)
        To address issues that do not require attention, run:
          npm audit fix
        To address all issues (including breaking changes), run:
          npm audit fix --force
        Run `npm audit` for details.
        	processing complete for module MMM-NowPlayingOnSpotify
        	processing for module MMM-DWD-Pollen please wait
        added 47 packages, and audited 48 packages in 3s
        2 moderate severity vulnerabilities
        Some issues need review, and may require choosing
        a different dependency.
        	processing complete for module MMM-DWD-Pollen
        	processing for module MMM-SmartWebDisplay please wait
        added 108 packages, and audited 109 packages in 5s
        14 packages are looking for funding
        	processing complete for module MMM-SmartWebDisplay
        	processing for module MMM-CalendarExt3 please wait
        > mmm-calendarext3@1.8.0 postinstall
        > git submodule update --init --recursive
        up to date, audited 1 package in 870ms
        	processing complete for module MMM-CalendarExt3
        	processing for module MMM-MovieListings please wait
        	processing complete for module MMM-MovieListings
        	processing for module MMM-GoogleMapsTraffic please wait
        added 5 packages, and audited 6 packages in 2s
        	processing complete for module MMM-GoogleMapsTraffic
        	processing for module MMM-EmbedURL please wait
        npm WARN deprecated @iconify/iconify@3.1.1: no longer maintained, switch to modern iconify-icon web component
        added 2 packages, and audited 3 packages in 3s
        1 package is looking for funding
        	processing complete for module MMM-EmbedURL
        	processing for module MMM-ImagesPhotos please wait
        added 70 packages, and audited 71 packages in 4s
        13 packages are looking for funding
        	processing complete for module MMM-ImagesPhotos
        restoring custom.css
        removing git alias
        Upgrade ended - Di Okt  1 19:36:05 CEST 2024
        Regards, Chris.
          sdetweil @chrisfr1976
          @chrisfr1976 need to upgrade nodejs to v22.???
          then run npm run install-mm
          i will fix my script in the morning as i am occupied w grandchildren rest of today
          • C Offline
            Now I have:
            node -v
            v22.9.0
            And when starting with pm2 I get 2 errors. Fist is directly im PM2:
            chris@MagicPi:~ $ pm2 start mm
            (node:3915) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
            (Use `node --trace-deprecation ...` to show where the warning was created)
            [PM2] Applying action restartProcessId on app [mm](ids: [ 0 ])
            [PM2] [mm](0) ✓
            [PM2] Process successfully started
            │ id │ name              │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
            │ 1  │ Display_Drehen    │ default     │ N/A     │ fork    │ 3913     │ 2s     │ 26   │ online    │ 0%       │ 1.8mb    │ chris    │ disabled │
            │ 0  │ mm                │ default     │ N/A     │ fork    │ 3922     │ 0s     │ 1    │ online    │ 0%       │ 1.8mb    │ chris    │ disabled │
            Second with “pm2 log mm”:
            0|mm  | > magicmirror@2.29.0 start
            0|mm  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
            0|mm  | App threw an error during load
            0|mm  | Error: Cannot find module 'logger'
            0|mm  | Require stack:
            0|mm  | - /home/chris/MagicMirror/js/app.js
            0|mm  | - /home/chris/MagicMirror/js/electron.js
            0|mm  |     at Module._resolveFilename (node:internal/modules/cjs/loader:1232:15)
            0|mm  |     at s._resolveFilename (node:electron/js2c/browser_init:2:121498)
            0|mm  |     at Module._resolveFilename (/home/chris/MagicMirror/node_modules/module-alias/index.js:49:29)
            0|mm  |     at Module._load (node:internal/modules/cjs/loader:1058:27)
            0|mm  |     at c._load (node:electron/js2c/node_init:2:17025)
            0|mm  |     at Module.require (node:internal/modules/cjs/loader:1318:19)
            0|mm  |     at require (node:internal/modules/helpers:179:18)
            0|mm  |     at Object.<anonymous> (/home/chris/MagicMirror/js/app.js:7:13)
            0|mm  |     at Module._compile (node:internal/modules/cjs/loader:1484:14)
            0|mm  |     at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
            0|mm  |     at Module.load (node:internal/modules/cjs/loader:1295:32)
            0|mm  |     at Module._load (node:internal/modules/cjs/loader:1111:12)
            0|mm  |     at Object.<anonymous> (/home/chris/MagicMirror/js/electron.js:4:14)
            0|mm  | A JavaScript error occurred in the main process
            0|mm  | Uncaught Exception:
            0|mm  | [4076:1001/220004.817112:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.817605:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.817935:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.818158:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.818461:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.818629:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.818957:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.819176:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.819569:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.819796:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.820180:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.820424:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.820811:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.821043:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            0|mm  | [4076:1001/220004.821511:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            and so on…
            Regards, Chris.
              @chrisfr1976
              Error: Cannot find module ‘logger’
              you have to do
              npm run install-mm ( in the MagicMirror folder)
              after updating nodejs
              S X 2 Replies Last reply Reply Quote 0
                @chrisfr1976 I have just updated the upgrade script to check for node V21 and if found, upgrade to 22.9
                • C Offline
                  @sdetweil I did the npm run install-mm already. Still the same error.
                  I have a copy of my SD Card. I could start from last version again only with the update script. Maybe this helps.
                  Chris.
                  Regards, Chris.
                    @chrisfr1976 its been reported that the upgrade script doesn’t restore the installers/MagicMirror.sh we took out of the MagicMirror repo and put in my repo
                    pm2 info 0
                    will list out the details of the managed app. it will list the program started
                    S C 2 Replies Last reply Reply Quote 0
                      I have fixed the upgrade script to save/restore the installers folder and mm.sh
                      • X Offline
                        xIExodusIx @sdetweil
                        how can I update nodejs?
                        I have:
                        nodejs -v
                        v18.19.0
                        and
                        node -v
                        v20.9.0
                        npm install nodejs@latest
                        does not change my nodejs version.
                        • 4 / 4
