    Mirror not starting after update
    33 Posts 4 Posters 6.2k Views 4 Watching
      chrisfr1976 @sdetweil
      @sdetweil here is my upgrade.log:
      Upgrade started - Di Okt  1 19:33:02 CEST 2024
      system is Linux MagicPi 6.1.21-v7l+ #1642 SMP Mon Apr 3 17:22:30 BST 2023 armv7l GNU/Linux
      user requested to apply changes
      doing test run = false
      the os is PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)" NAME="Raspbian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Minimum Node version: v20.9.0
      Installed Node version: v21.7.3
      No Node.js upgrade necessary.
      Minimum npm version: V10.1.0
      Installed npm version: V10.5.0
      No npm upgrade necessary.
      saving custom.css
      remote name = origin
      upgrading from version 2.28.0 to 2.29.0
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is behind 'origin/master' by 1 commit, and can be fast-forwarded.
        (use "git pull" to update your local branch)
      Untracked files:
        (use "git add <file>..." to include in what will be committed)
      	core
      	js/main.backup.js
      nothing added to commit but untracked files present (use "git add" to track)
      no files different from github version
      test merge result rc='' , if empty, no conflicts
      executing merge, apply specified
      merge result rc= 0
       Updating 53fc814f..94c3c699 Fast-forward  .eslintignore
          2 -  .eslintrc.json
         93 -  .github/CONTRIBUTING.md
          2 +-  .github/workflows/automated-tests.yaml
          2 +-  .../workflows/{depsreview.yaml => dep-review.yaml}
          2 +  ...{electronRebuild.yaml => electron-rebuild.yaml}
          6 +-  .github/workflows/enforce-pullrequest-rules.yaml
          4 +-  .gitignore
          3 +  .prettierignore
          2 +-  CHANGELOG.md
         77 +-  Collaboration.md
         50 +-  README.md
          4 +-  cspell.config.json
        227 +  eslint.config.mjs
        121 +  fonts/package-lock.json
         18 +-  fonts/package.json
          4 +-  index.html
          1 +  installers/mm.sh
          4 -  js/app.js
         29 +-  js/check_config.js
        104 +-  js/class.js
         21 +-  js/defaults.js
          8 +-  js/electron.js
         50 +-  js/loader.js
         34 +-  js/main.js
         22 +-  js/module.js
         29 +-  js/node_helper.js
         24 +-  js/server.js
         12 +-  js/server_functions.js
         46 +-  js/translator.js
          6 +-  js/utils.js
         41 +-  modules/default/calendar/calendar.js
         38 +-  modules/default/calendar/debug.js
          3 +-  modules/default/compliments/compliments.js
        100 +-  modules/default/defaultmodules.js
          3 +-  .../default/updatenotification/update_helper.js
         19 +-  modules/default/weather/providers/envcanada.js
        342 +-  modules/default/weather/providers/openmeteo.js
         10 +-  .../default/weather/providers/openweathermap.js
         48 +-  modules/default/weather/providers/pirateweather.js
         10 +-  modules/default/weather/providers/smhi.js
         11 +-  modules/default/weather/providers/ukmetoffice.js
         39 +-  .../weather/providers/ukmetofficedatahub.js
         64 +-  modules/default/weather/providers/weatherbit.js
         10 +-  modules/default/weather/providers/weatherflow.js
         10 +-  modules/default/weather/providers/weathergov.js
         38 +-  modules/default/weather/providers/yr.js
         17 +-  modules/default/weather/weather.js
         13 +-  modules/default/weather/weatherutils.js
         36 +-  package-lock.json
       4724 ++++++++++----------  package.json
         51 +-  splashscreen/MagicMirror.plymouth
          8 -  splashscreen/MagicMirror.script
         53 -  splashscreen/splash.png
        Bin 37062 -> 0 bytes  splashscreen/splash_halt.png
        Bin 22304 -> 0 bytes  tests/configs/customregions.js
         23 +  .../modules/calendar/exdate_la_at_midnight_dst.js
          3 +-  .../modules/calendar/exdate_la_at_midnight_std.js
          3 +-  .../modules/calendar/exdate_la_before_midnight.js
          3 +-  .../modules/calendar/exdate_syd_at_midnight_dst.js
          3 +-  .../modules/calendar/exdate_syd_at_midnight_std.js
          3 +-  .../modules/calendar/exdate_syd_before_midnight.js
          3 +-  .../configs/modules/calendar/long-fullday-event.js
          3 +-  .../modules/calendar/single-fullday-event.js
          3 +-  .../modules/calendar/sliceMultiDayEvents.js
         30 +  .../modules/compliments/compliments_cron_entry.js
         18 +  .../compliments/compliments_e2e_cron_entry.js
         18 +  tests/e2e/animateCSS_spec.js
          2 +-  tests/e2e/custom_module_regions_spec.js
         30 +  tests/e2e/helpers/global-setup.js
         57 +-  tests/e2e/modules/calendar_spec.js
         11 -  tests/e2e/modules/compliments_spec.js
         11 +  tests/e2e/modules/newsfeed_spec.js
         31 +-  tests/e2e/modules/weather_hourly_spec.js
          4 +-  tests/e2e/modules_display_spec.js
          2 +-  tests/e2e/serveronly_spec.js
          2 +-  tests/electron/modules/calendar_spec.js
        123 +-  tests/electron/modules/compliments_spec.js
         36 +  tests/mocks/sliceMultiDayEvents.ics
         58 +  tests/unit/functions/server_functions_spec.js
          6 +-  .../modules/default/weather/weather_utils_spec.js
          2 +-  vendor/package-lock.json
         36 +-  vendor/package.json
          3 +-  vendor/vendor.js
          3 +-  84 files changed, 4147 insertions(+), 3078 deletions(-)  delete mode 100644 .eslintignore  delete mode 100644 .eslintrc.json  rename .github/workflows/{depsreview.yaml => dep-review.yaml} (90%)  rename .github/workflows/{electronRebuild.yaml => electron-rebuild.yaml} (77%)
      create mode 100644 cspell.config.json
      create mode 100644 eslint.config.mjs  delete mode 100755 installers/mm.sh  delete mode 100644 splashscreen/MagicMirror.plymouth  delete mode 100644 splashscreen/MagicMirror.script  delete mode 100644 splashscreen/splash.png  delete mode 100644 splashscreen/splash_halt.png
      create mode 100644 tests/configs/customregions.js
      create mode 100644 tests/configs/modules/calendar/sliceMultiDayEvents.js
      create mode 100644 tests/configs/modules/compliments/compliments_cron_entry.js
      create mode 100644 tests/configs/modules/compliments/compliments_e2e_cron_entry.js
      create mode 100644 tests/e2e/custom_module_regions_spec.js
      create mode 100644 tests/mocks/sliceMultiDayEvents.ics
      processor architecture is armv7l
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.29.0
      npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.29.0
      npm ERR! notsup Required: {"node":">=20.9.0 <21 || 22"}
      npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v21.7.3"}
      npm ERR! A complete log of this run can be found in: /home/chris/.npm/_logs/2024-10-01T17_33_19_444Z-debug-0.log
      npm install completed - Di Okt  1 19:33:27 CEST 2024 on base
      downloading dumpactivemodules script
      updating dependencies for active modules with package.json files
      	processing for module MMM-Carousel please wait
      up to date, audited 1 package in 2s
      found 0 vulnerabilities
      	processing complete for module MMM-Carousel
      	processing for module MMM-weconnectid please wait
      	processing complete for module MMM-weconnectid
      	processing for module MMM-BackgroundSlideshow please wait
      added 12 packages, and audited 13 packages in 12s
      3 packages are looking for funding
        run `npm fund` for details
      	processing complete for module MMM-BackgroundSlideshow
      	processing for module mmm-systemtemperature please wait
      added 1 package, and audited 2 packages in 6s
      	processing complete for module mmm-systemtemperature
      	processing for module MMM-pihole-stats please wait
      	processing complete for module MMM-pihole-stats
      	processing for module MMM-NINA please wait
      	processing complete for module MMM-NINA
      	processing for module MMM-Traffic please wait
      added 5 packages, and audited 6 packages in 6s
      	processing complete for module MMM-Traffic
      	processing for module MMM-NowPlayingOnSpotify please wait
      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      added 131 packages, and audited 694 packages in 1m
      12 packages are looking for funding
      63 vulnerabilities (2 low, 22 moderate, 31 high, 8 critical)
      To address issues that do not require attention, run:
        npm audit fix
      To address all issues (including breaking changes), run:
        npm audit fix --force
      Run `npm audit` for details.
      	processing complete for module MMM-NowPlayingOnSpotify
      	processing for module MMM-DWD-Pollen please wait
      added 47 packages, and audited 48 packages in 3s
      2 moderate severity vulnerabilities
      Some issues need review, and may require choosing
      a different dependency.
      	processing complete for module MMM-DWD-Pollen
      	processing for module MMM-SmartWebDisplay please wait
      added 108 packages, and audited 109 packages in 5s
      14 packages are looking for funding
      	processing complete for module MMM-SmartWebDisplay
      	processing for module MMM-CalendarExt3 please wait
      > mmm-calendarext3@1.8.0 postinstall
      > git submodule update --init --recursive
      up to date, audited 1 package in 870ms
      	processing complete for module MMM-CalendarExt3
      	processing for module MMM-MovieListings please wait
      	processing complete for module MMM-MovieListings
      	processing for module MMM-GoogleMapsTraffic please wait
      added 5 packages, and audited 6 packages in 2s
      	processing complete for module MMM-GoogleMapsTraffic
      	processing for module MMM-EmbedURL please wait
      npm WARN deprecated @iconify/iconify@3.1.1: no longer maintained, switch to modern iconify-icon web component
      added 2 packages, and audited 3 packages in 3s
      1 package is looking for funding
      	processing complete for module MMM-EmbedURL
      	processing for module MMM-ImagesPhotos please wait
      added 70 packages, and audited 71 packages in 4s
      13 packages are looking for funding
      	processing complete for module MMM-ImagesPhotos
      restoring custom.css
      removing git alias
      Upgrade ended - Di Okt  1 19:36:05 CEST 2024
      Regards, Chris.
        sdetweil @chrisfr1976
        @chrisfr1976 need to upgrade nodejs to v22.???
        then run npm run install-mm
        i will fix my script in the morning as i am occupied w grandchildren rest of today
          Now I have:
          node -v
          v22.9.0
          And when starting with pm2 I get 2 errors. Fist is directly im PM2:
          chris@MagicPi:~ $ pm2 start mm
          (node:3915) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
          (Use `node --trace-deprecation ...` to show where the warning was created)
          [PM2] Applying action restartProcessId on app [mm](ids: [ 0 ])
          [PM2] [mm](0) ✓
          [PM2] Process successfully started
          │ id │ name              │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
          │ 1  │ Display_Drehen    │ default     │ N/A     │ fork    │ 3913     │ 2s     │ 26   │ online    │ 0%       │ 1.8mb    │ chris    │ disabled │
          │ 0  │ mm                │ default     │ N/A     │ fork    │ 3922     │ 0s     │ 1    │ online    │ 0%       │ 1.8mb    │ chris    │ disabled │
          Second with “pm2 log mm”:
          0|mm  | > magicmirror@2.29.0 start
          0|mm  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
          0|mm  | App threw an error during load
          0|mm  | Error: Cannot find module 'logger'
          0|mm  | Require stack:
          0|mm  | - /home/chris/MagicMirror/js/app.js
          0|mm  | - /home/chris/MagicMirror/js/electron.js
          0|mm  |     at Module._resolveFilename (node:internal/modules/cjs/loader:1232:15)
          0|mm  |     at s._resolveFilename (node:electron/js2c/browser_init:2:121498)
          0|mm  |     at Module._resolveFilename (/home/chris/MagicMirror/node_modules/module-alias/index.js:49:29)
          0|mm  |     at Module._load (node:internal/modules/cjs/loader:1058:27)
          0|mm  |     at c._load (node:electron/js2c/node_init:2:17025)
          0|mm  |     at Module.require (node:internal/modules/cjs/loader:1318:19)
          0|mm  |     at require (node:internal/modules/helpers:179:18)
          0|mm  |     at Object.<anonymous> (/home/chris/MagicMirror/js/app.js:7:13)
          0|mm  |     at Module._compile (node:internal/modules/cjs/loader:1484:14)
          0|mm  |     at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
          0|mm  |     at Module.load (node:internal/modules/cjs/loader:1295:32)
          0|mm  |     at Module._load (node:internal/modules/cjs/loader:1111:12)
          0|mm  |     at Object.<anonymous> (/home/chris/MagicMirror/js/electron.js:4:14)
          0|mm  | A JavaScript error occurred in the main process
          0|mm  | Uncaught Exception:
          0|mm  | [4076:1001/220004.817112:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.817605:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.817935:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.818158:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.818461:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.818629:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.818957:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.819176:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.819569:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.819796:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.820180:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.820424:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.820811:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.821043:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
          0|mm  | [4076:1001/220004.821511:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
          and so on…
          Regards, Chris.
            @chrisfr1976
            Error: Cannot find module ‘logger’
            you have to do
            npm run install-mm ( in the MagicMirror folder)
            after updating nodejs
            S X 2 Replies Last reply Reply Quote 0
              @chrisfr1976 I have just updated the upgrade script to check for node V21 and if found, upgrade to 22.9
                @sdetweil I did the npm run install-mm already. Still the same error.
                I have a copy of my SD Card. I could start from last version again only with the update script. Maybe this helps.
                Chris.
                Regards, Chris.
                  @chrisfr1976 its been reported that the upgrade script doesn’t restore the installers/MagicMirror.sh we took out of the MagicMirror repo and put in my repo
                  pm2 info 0
                  will list out the details of the managed app. it will list the program started
                  S C 2 Replies Last reply Reply Quote 0
                    I have fixed the upgrade script to save/restore the installers folder and mm.sh
                    • X Offline
                      xIExodusIx @sdetweil
                      how can I update nodejs?
                      I have:
                      nodejs -v
                      v18.19.0
                      and
                      node -v
                      v20.9.0
                      npm install nodejs@latest
                      does not change my nodejs version.
                        sdetweil @xIExodusIx
                        @xIExodusIx what OS are you on?
                        lsb_release -a
                        and
                        uname -a
                        will show
                        did you use my upgrade script? it will upgrade node too
                        • 1 / 4
