    Mirror not starting after update
    33 Posts 4 Posters 8.0k Views 4 Watching
      @chrisfr1976 I have just updated the upgrade script to check for node V21 and if found, upgrade to 22.9
        chrisfr1976 @sdetweil
        @sdetweil I did the npm run install-mm already. Still the same error.
        I have a copy of my SD Card. I could start from last version again only with the update script. Maybe this helps.
        Chris.
        Regards, Chris.
          sdetweil @chrisfr1976
          @chrisfr1976 its been reported that the upgrade script doesn’t restore the installers/MagicMirror.sh we took out of the MagicMirror repo and put in my repo
          pm2 info 0
          will list out the details of the managed app. it will list the program started
          S C 2 Replies Last reply Reply Quote 0
            I have fixed the upgrade script to save/restore the installers folder and mm.sh
            • X Offline
              xIExodusIx @sdetweil
              how can I update nodejs?
              I have:
              nodejs -v
              v18.19.0
              and
              node -v
              v20.9.0
              npm install nodejs@latest
              does not change my nodejs version.
                sdetweil @xIExodusIx
                @xIExodusIx what OS are you on?
                lsb_release -a
                and
                uname -a
                will show
                did you use my upgrade script? it will upgrade node too
                X 2 Replies Last reply Reply Quote 0
                • X Offline
                  Raspberry Pi 4
                  OS = bookworm 64bit
                    @xIExodusIx did you use my upgrade script?
                      @chrisfr1976 can you show me the output of thew npm run install-mm
                      do it this way (from the MM folder of course)
                      npm run install-mm >somefile.txt 2>&1
                      then when it finishes all the output is in somefile.txt
                      X 1 Reply Last reply Reply Quote 0
                      • X Offline
                        lsb_release -a shows:
                        No LSB modules are available.
                        Distributor ID: Debian
                        Description: Debian GNU/Linux 12 (bookworm)
                        Release: 12
                        Codename: bookworm
                        uname -a shows:
                        Linux MirrorPi 6.6.51+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt2 (2024-10-01) aarch64 GNU/Linux
                        yes I used your upgrade-script with apply and also with force.
                        pm2 start MagicMirror will start the MM but it won’t show up!
                        npm start results in following errors:
                        [41163:1002/155017.678545:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
                        [41163:1002/155017.688550:ERROR:env.cc(258)] The platform failed to initialize. Exiting.
                        /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                          @xIExodusIx before this morning, my upgrade script had a bug
                          do
                          ls installers
                          that should fail (not found)
                          then do
                          mkdir installers
                          curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/mm.sh >installers/mm.sh
                          chmod +x installers/mm.sh
                            @xIExodusIx also, if you do
                            npm start
                            does MM come up?
                            • X Offline
                              magicmirror@2.29.0 install-mm
                              npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                              magicmirror@2.29.0 postinstall
                              npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                              magicmirror@2.29.0 install-vendor
                              echo "Installing vendor files …
                              " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                              up to date in 2s
                              magicmirror@2.29.0 install-fonts
                              echo "Installing fonts …
                              " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                              Installing fonts …
                              up to date in 1s
                              magicmirror@2.29.0 prepare
                              [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                              no husky installed.
                              up to date in 14s
                              after that, nodejs is still the same: 18.19.0
                              • X Offline
                                the installers folder is still there.
                                should I delete it?
                                or should run the script without delete the installers folder?
                                • X Offline
                                  if I do npm start
                                  I get this error at the end:
                                  [2024-10-02 16:13:22.616] [LOG] All module helpers loaded.
                                  [2024-10-02 16:13:22.627] [LOG] Starting server on port 8181 …
                                  [63161:1002/161323.449087:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
                                  [63161:1002/161323.449298:ERROR:env.cc(258)] The platform failed to initialize. Exiting.
                                    @xIExodusIx said in Mirror not starting after update:
                                    this version like last requires node 20 or 22 (not 21)
                                    this is the ‘problem’
                                    magicMirror will not upgrade nodejs… only my upgrade script will do that
                                    npm run install-mm should have failed as there is a test for the correct node version(s)…
                                    can you show me the part of
                                    ~/MagicMirror/installers/upgrade.log
                                    from one of your upgrade runs?
                                    or open an issue on my scripts repo and attached the log there
                                    no personal info is present in the log
                                    • X Offline
                                      Upgrade started - Wed Oct 2 15:47:21 CEST 2024
                                      system is Linux MirrorPi 6.6.51+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt2 (2024-10-01) aarch64 GNU/Linux
                                      user requested to force apply changes
                                      doing test run = false
                                      the os is PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)” NAME=“Debian GNU/Linux” VERSION_ID=“12” VERSION=“12 (bookworm)” VERSION_CODENAME=bookworm ID=debian HOME_URL=“https://www.debian.org/” SUPPORT_URL=“https://www.debian.org/support” BUG_REPORT_URL=“https://bugs.debian.org/”
                                      Minimum Node version: v20.9.0
                                      Installed Node version: v20.9.0
                                      Check current Node installation …
                                      No Node.js upgrade necessary.
                                      Check current NPM installation …
                                      Minimum npm version: V10.1.0
                                      Installed npm version: V10.8.3
                                      No npm upgrade necessary.
                                      increasing swap space
                                      saving custom.css
                                      remote name = origin
                                      upgrading from version 2.29.0 to 2.29.0
                                      fetching latest revisions
                                      git fetch rc=0
                                      current branch = master
                                      On branch master
                                      Your branch is up to date with ‘origin/master’.
                                      (use “git add …” to update what will be committed)
                                      (use “git restore …” to discard changes in working directory)
                                      modified: package-lock.json
                                      modified: package.json
                                      Untracked files:
                                      (use “git add …” to include in what will be committed)
                                      core
                                      installers/
                                      run-start.sh
                                      splashscreen/
                                      no changes added to commit (use “git add” and/or “git commit -a”)
                                      there are 2 local files that are different than the master repo
                                      package-lock.json
                                      package.json
                                      save/restore files selection = y
                                      erasing lock files
                                      Saved working directory and index state WIP on master: 94c3c69 Release 2.29.0 (#3568)
                                      test merge result rc=‘’ , if empty, no conflicts
                                      executing merge, apply specified
                                      merge result rc= 0
                                      Already up to date.
                                      processor architecture is aarch64
                                      up to date in 3s
                                      Installing fonts …
                                      up to date in 1s
                                      no husky installed.
                                      added 466 packages in 35s
                                      112 packages are looking for funding
                                      run npm fund for details
                                      npm install completed - Wed Oct 2 15:48:06 CEST 2024 on base
                                      fixing sandbox permissions
                                      downloading dumpactivemodules script
                                      updating dependencies for active modules with package.json files
                                      processing for module MMM-mmpm please wait
                                      up to date, audited 1 package in 1s
                                      found 0 vulnerabilities
                                      processing complete for module MMM-mmpm
                                      processing for module MMM-pages please wait
                                      processing complete for module MMM-pages
                                      processing for module MMM-FlipClock please wait
                                      added 1 package, and audited 2 packages in 5s
                                      processing complete for module MMM-FlipClock
                                      processing for module MMM-GoogleCalendar please wait
                                      npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                                      added 52 packages, and audited 53 packages in 26s
                                      17 packages are looking for funding
                                      processing complete for module MMM-GoogleCalendar
                                      processing for module MMM-DynamicWeather please wait
                                      processing complete for module MMM-DynamicWeather
                                      processing for module MMM-Bring please wait
                                      added 3 packages, and audited 4 packages in 3s
                                      1 package is looking for funding
                                      1 moderate severity vulnerability
                                      To address all issues (including breaking changes), run:
                                      npm audit fix --force
                                      Run npm audit for details.
                                      processing complete for module MMM-Bring
                                      processing for module MMM-PublicTransportHafas please wait
                                      mmm-publictransporthafas@2.1.1 prepare
                                      [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
                                      added 51 packages, and audited 52 packages in 9s
                                      16 packages are looking for funding
                                      processing complete for module MMM-PublicTransportHafas
                                      processing for module MMM-Autobahn please wait
                                      added 1 package, and audited 2 packages in 2s
                                      processing complete for module MMM-Autobahn
                                      processing for module MMM-Globe please wait
                                      processing complete for module MMM-Globe
                                      processing for module MMM-FRITZ-Box-Callmonitor-py3 please wait
                                      added 11 packages, and audited 12 packages in 5s
                                      processing complete for module MMM-FRITZ-Box-Callmonitor-py3
                                      processing for module MMM-Fuel please wait
                                      added 17 packages, and audited 18 packages in 4s
                                      8 packages are looking for funding
                                      processing complete for module MMM-Fuel
                                      processing for module MMM-NINA please wait
                                      processing complete for module MMM-NINA
                                      processing for module MMM-network-signal please wait
                                      added 1 package, and audited 2 packages in 4s
                                      processing complete for module MMM-network-signal
                                      restoring custom.css
                                      removing git alias
                                      we stashed a set of files that appear changed from the latest repo versions. you should review them
                                      Upgrade ended - Wed Oct 2 15:49:22 CEST 2024
                                        @xIExodusIx
                                        https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/
                                        you are on node 20.9.
                                        package-lock.json
                                        package.json
                                        sorry, you cannot save/restore those two files…
                                        they are the KEY files for each release
                                        so, do
                                        git diff package.json >somefile.txt
                                        git checkout package.json
                                        git checkout package-lock.json
                                        rm -rf node_modules
                                        npm run install-mm
                                        any changes you made to package.json are shown in the
                                        somefile.txt if you need to re-apply them to the new package.json file
                                        generally first rule, NEVER edit any files we ship.
                                        1 it breaks upgrades
                                        2 YOU are RESPONSIBLE for remembering WHAT and WHY you did it and how to fix it for next time.
                                        this is why my upgrade script is TWO passes… to detect changes to critical files and warn you … help you remember (before we whack them)
                                        • X Offline
                                          Sorry I didn’t know that, I thought that it were better to save/restore these files. Next time i will answer that question with no.
                                            @xIExodusIx BUT their presence in the list SHOULD have made you think…
                                            what did I change? and is it still important…
                                            that is why I recommend running the test pass to find those things…
                                            my hope is to never break a running mirror…
