    Mirror not starting after update
    33 Posts 4 Posters 6.0k Views 4 Watching
    • X Offline
      xIExodusIx @sdetweil
      magicmirror@2.29.0 install-mm
      npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      magicmirror@2.29.0 postinstall
      npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
      magicmirror@2.29.0 install-vendor
      echo "Installing vendor files …
      " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      up to date in 2s
      magicmirror@2.29.0 install-fonts
      echo "Installing fonts …
      " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      Installing fonts …
      up to date in 1s
      magicmirror@2.29.0 prepare
      [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
      no husky installed.
      up to date in 14s
      after that, nodejs is still the same: 18.19.0
      • X Offline
        the installers folder is still there.
        should I delete it?
        or should run the script without delete the installers folder?
        • X Offline
          if I do npm start
          I get this error at the end:
          [2024-10-02 16:13:22.616] [LOG] All module helpers loaded.
          [2024-10-02 16:13:22.627] [LOG] Starting server on port 8181 …
          [63161:1002/161323.449087:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
          [63161:1002/161323.449298:ERROR:env.cc(258)] The platform failed to initialize. Exiting.
          /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
            sdetweil @xIExodusIx
            @xIExodusIx said in Mirror not starting after update:
            this version like last requires node 20 or 22 (not 21)
            this is the ‘problem’
            magicMirror will not upgrade nodejs… only my upgrade script will do that
            npm run install-mm should have failed as there is a test for the correct node version(s)…
            can you show me the part of
            ~/MagicMirror/installers/upgrade.log
            from one of your upgrade runs?
            or open an issue on my scripts repo and attached the log there
            no personal info is present in the log
            X 1 Reply Last reply Reply Quote 0
            • X Offline
              Upgrade started - Wed Oct 2 15:47:21 CEST 2024
              system is Linux MirrorPi 6.6.51+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt2 (2024-10-01) aarch64 GNU/Linux
              user requested to force apply changes
              doing test run = false
              the os is PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)” NAME=“Debian GNU/Linux” VERSION_ID=“12” VERSION=“12 (bookworm)” VERSION_CODENAME=bookworm ID=debian HOME_URL=“https://www.debian.org/” SUPPORT_URL=“https://www.debian.org/support” BUG_REPORT_URL=“https://bugs.debian.org/”
              Node currently installed. Checking version number.
              Minimum Node version: v20.9.0
              Installed Node version: v20.9.0
              Check current Node installation …
              No Node.js upgrade necessary.
              Check current NPM installation …
              NPM currently installed. Checking version number.
              Minimum npm version: V10.1.0
              Installed npm version: V10.8.3
              No npm upgrade necessary.
              increasing swap space
              saving custom.css
              remote name = origin
              upgrading from version 2.29.0 to 2.29.0
              fetching latest revisions
              git fetch rc=0
              current branch = master
              On branch master
              Your branch is up to date with ‘origin/master’.
              Changes not staged for commit:
              (use “git add …” to update what will be committed)
              (use “git restore …” to discard changes in working directory)
              modified: package-lock.json
              modified: package.json
              Untracked files:
              (use “git add …” to include in what will be committed)
              core
              installers/
              run-start.sh
              splashscreen/
              no changes added to commit (use “git add” and/or “git commit -a”)
              there are 2 local files that are different than the master repo
              package-lock.json
              package.json
              save/restore files selection = y
              erasing lock files
              Saved working directory and index state WIP on master: 94c3c69 Release 2.29.0 (#3568)
              test merge result rc=‘’ , if empty, no conflicts
              executing merge, apply specified
              merge result rc= 0
              Already up to date.
              processor architecture is aarch64
              updating MagicMirror runtime, please wait
              up to date in 3s
              Installing fonts …
              up to date in 1s
              no husky installed.
              added 466 packages in 35s
              112 packages are looking for funding
              run npm fund for details
              npm install completed - Wed Oct 2 15:48:06 CEST 2024 on base
              fixing sandbox permissions
              Checking for modules with removed libraries
              downloading dumpactivemodules script
              updating dependencies for active modules with package.json files
              processing for module MMM-mmpm please wait
              up to date, audited 1 package in 1s
              found 0 vulnerabilities
              processing complete for module MMM-mmpm
              processing for module MMM-pages please wait
              processing complete for module MMM-pages
              processing for module MMM-FlipClock please wait
              added 1 package, and audited 2 packages in 5s
              processing complete for module MMM-FlipClock
              processing for module MMM-GoogleCalendar please wait
              npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
              added 52 packages, and audited 53 packages in 26s
              17 packages are looking for funding
              processing complete for module MMM-GoogleCalendar
              processing for module MMM-DynamicWeather please wait
              processing complete for module MMM-DynamicWeather
              processing for module MMM-Bring please wait
              added 3 packages, and audited 4 packages in 3s
              1 package is looking for funding
              1 moderate severity vulnerability
              To address all issues (including breaking changes), run:
              npm audit fix --force
              Run npm audit for details.
              processing complete for module MMM-Bring
              processing for module MMM-PublicTransportHafas please wait
              mmm-publictransporthafas@2.1.1 prepare
              [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
              added 51 packages, and audited 52 packages in 9s
              16 packages are looking for funding
              processing complete for module MMM-PublicTransportHafas
              processing for module MMM-Autobahn please wait
              added 1 package, and audited 2 packages in 2s
              processing complete for module MMM-Autobahn
              processing for module MMM-Globe please wait
              processing complete for module MMM-Globe
              processing for module MMM-FRITZ-Box-Callmonitor-py3 please wait
              added 11 packages, and audited 12 packages in 5s
              processing complete for module MMM-FRITZ-Box-Callmonitor-py3
              processing for module MMM-Fuel please wait
              added 17 packages, and audited 18 packages in 4s
              8 packages are looking for funding
              processing complete for module MMM-Fuel
              processing for module MMM-NINA please wait
              processing complete for module MMM-NINA
              processing for module MMM-network-signal please wait
              added 1 package, and audited 2 packages in 4s
              processing complete for module MMM-network-signal
              restoring custom.css
              removing git alias
              we stashed a set of files that appear changed from the latest repo versions. you should review them
              Upgrade ended - Wed Oct 2 15:49:22 CEST 2024
                @xIExodusIx
                https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/
                you are on node 20.9.
                package-lock.json
                package.json
                sorry, you cannot save/restore those two files…
                they are the KEY files for each release
                so, do
                cd ~/MagicMirror
                git diff package.json >somefile.txt
                git checkout package.json
                git checkout package-lock.json
                rm -rf node_modules
                npm run install-mm
                any changes you made to package.json are shown in the
                somefile.txt if you need to re-apply them to the new package.json file
                generally first rule, NEVER edit any files we ship.
                1 it breaks upgrades
                2 YOU are RESPONSIBLE for remembering WHAT and WHY you did it and how to fix it for next time.
                this is why my upgrade script is TWO passes… to detect changes to critical files and warn you … help you remember (before we whack them)
                • X Offline
                  Sorry I didn’t know that, I thought that it were better to save/restore these files. Next time i will answer that question with no.
                    @xIExodusIx BUT their presence in the list SHOULD have made you think…
                    what did I change? and is it still important…
                    that is why I recommend running the test pass to find those things…
                    my hope is to never break a running mirror…
                    • X Offline
                      Sorry, I thougt they were important so thought it were better to save/restore them.
                      I never changed anything in them, I can not code, I’m too stupid for coding!
                      The question will you save tells me they are important otherwise they were maybe orverwritten so it is better to save them.
                      I did not know that they were KEY-files for each new versions of MM and had (must) to be replaced by new ones.
                      I never will answer that quesion with yes again.
                      Now I will start to install my MM from scratch again for get it work. This will be my last attemp. When this does not work this time I will give up my MagicMirror project.
                      Thanks for helping.
                        @xIExodusIx you do not need to start over…
                        jut use the command I gave to restore the 2 files and do the npm install again
                        all will be well…
                        X 2 Replies Last reply Reply Quote 0
                        • 3 / 4
