    Mirror not starting after update
    33 Posts 4 Posters 6.0k Views 4 Watching
      sdetweil @chrisfr1976
      @chrisfr1976 its been reported that the upgrade script doesn’t restore the installers/MagicMirror.sh we took out of the MagicMirror repo and put in my repo
      pm2 info 0
      will list out the details of the managed app. it will list the program started
      S C 2 Replies Last reply Reply Quote 0
        I have fixed the upgrade script to save/restore the installers folder and mm.sh
        • X Offline
          xIExodusIx @sdetweil
          how can I update nodejs?
          I have:
          nodejs -v
          v18.19.0
          and
          node -v
          v20.9.0
          npm install nodejs@latest
          does not change my nodejs version.
            sdetweil @xIExodusIx
            @xIExodusIx what OS are you on?
            lsb_release -a
            and
            uname -a
            will show
            did you use my upgrade script? it will upgrade node too
            X 2 Replies Last reply Reply Quote 0
            • X Offline
              Raspberry Pi 4
              OS = bookworm 64bit
                @xIExodusIx did you use my upgrade script?
                  @chrisfr1976 can you show me the output of thew npm run install-mm
                  do it this way (from the MM folder of course)
                  cd ~/MagicMirror
                  npm run install-mm >somefile.txt 2>&1
                  then when it finishes all the output is in somefile.txt
                  X 1 Reply Last reply Reply Quote 0
                  • X Offline
                    lsb_release -a shows:
                    No LSB modules are available.
                    Distributor ID: Debian
                    Description: Debian GNU/Linux 12 (bookworm)
                    Release: 12
                    Codename: bookworm
                    uname -a shows:
                    Linux MirrorPi 6.6.51+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt2 (2024-10-01) aarch64 GNU/Linux
                    yes I used your upgrade-script with apply and also with force.
                    pm2 start MagicMirror will start the MM but it won’t show up!
                    npm start results in following errors:
                    [41163:1002/155017.678545:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
                    [41163:1002/155017.688550:ERROR:env.cc(258)] The platform failed to initialize. Exiting.
                    /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                      @xIExodusIx before this morning, my upgrade script had a bug
                      do
                      cd ~/MagicMirror
                      ls installers
                      that should fail (not found)
                      then do
                      mkdir installers
                      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/mm.sh >installers/mm.sh
                      chmod +x installers/mm.sh
                        @xIExodusIx also, if you do
                        cd ~/MagicMirror
                        npm start
                        does MM come up?
                        • 2 / 4
