    Upgrade to 2.29.0 - Cannot read properties of undefined (reading 'disableHardwareAcceleration
    9 Posts 2 Posters 1.2k Views 2 Watching
    • butchkemperB Offline
      butchkemper
      I upgraded to 2.29.0 and MM will not start. The error log repeatedly contains these messages as shown below. Also, the installer log is included.
      Butch
      [2024-10-01 16:28:48.246] ^[[31m[ERROR]^[[39m ^[[31mWhoops! There was an uncaught exception...^[[39m
      [2024-10-01 16:28:48.248] ^[[31m[ERROR]^[[39m ^[[31mTypeError: Cannot read properties of undefined (reading 'disableHardwareAcceleration')^[[39m
      ^[[31m    at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:18:6)^[[39m
      ^[[31m    at Module._compile (node:internal/modules/cjs/loader:1469:14)^[[39m
      ^[[31m    at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)^[[39m
      ^[[31m    at Module.load (node:internal/modules/cjs/loader:1288:32)^[[39m
      ^[[31m    at Module._load (node:internal/modules/cjs/loader:1104:12)^[[39m
      ^[[31m    at Object.<anonymous> (/usr/lib/node_modules/pm2/lib/ProcessContainerFork.js:33:23)^[[39m
      ^[[31m    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)^[[39m
      ^[[31m    at node:internal/main/run_main_module:28:49^[[39m
      [2024-10-01 16:28:48.250] ^[[31m[ERROR]^[[39m ^[[31mMagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?^[[39m
      [2024-10-01 16:28:48.251] ^[[31m[ERROR]^[[39m ^[[31mIf you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues^[[39m
      The Installer log follows - I had to make it shorter because of a post size limit.
      Upgrade started - Sun May  5 21:42:42 CDT 2024
      system is Linux MagicMirror 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
      user requested to apply changes
      doing test run = false
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
      Node currently installed. Checking version number.
      Minimum Node version: v20.8.0
      Installed Node version: v20.12.2
      Check current Node installation ...
      No Node.js upgrade necessary.
      Check current NPM installation ...
      NPM currently installed. Checking version number.
      Minimum npm version: V10.1.0
      Installed npm version: V10.5.0
      No npm upgrade necessary.
      saving custom.css
      remote name = origin
      upgrading from version 2.26.0 to 2.27.0
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is behind 'origin/master' by 1 commit, and can be fast-forwarded.
        (use "git pull" to update your local branch)
      Changes not staged for commit:
        (use "git add/rm <file>..." to update what will be committed)
        (use "git restore <file>..." to discard changes in working directory)
      	deleted:    config/config.js.sample
      Untracked files:
        (use "git add <file>..." to include in what will be committed)
      	css/save_custom.css
      	installers/pm2_MagicMirror.json
      	installers/stashed_files
      	run-start.sh
      no changes added to commit (use "git add" and/or "git commit -a")
      no files different from github version
      test merge result rc='' , if empty, no conflicts
      executing merge, apply specified
      merge result rc= 0
       Updating 118e2123..5ea8a346 Fast-forward  .eslintignore
          3 +-  .eslintrc.json
         18 +-  .github/codecov.yaml
         10 -  .github/dependabot.yaml
         15 +  .github/workflows/depsreview.yaml
          2 +-  .github/workflows/electronRebuild.yaml
         20 +  .github/workflows/enforce-pullrequest-rules.yaml
          2 +-  .gitignore
          6 +-  .husky/pre-commit
          2 -  .npmrc
          1 +  .prettierignore
          2 +  CHANGELOG.md
        199 +-  Collaboration.md
         24 +-  LICENSE.md
          2 +-  README.md
         10 +-  clientonly/index.js
          4 +-  config/config.js.sample
          5 +-  css/custom.css.sample
          8 +-  fonts/package-lock.json
         18 +-  fonts/package.json
         11 +-  js/animateCSS.js
          7 -  js/app.js
         42 +-  js/check_config.js
         23 +-  js/defaults.js
          8 +-  js/deprecated.js
          8 -  js/electron.js
          1 +  js/loader.js
          6 -  js/logger.js
         43 +-  js/main.js
          6 -  js/module.js
          6 +-  js/node_helper.js
          6 -  js/server.js
         16 +-  js/server_functions.js
          4 +-  js/socketclient.js
          6 -  js/translator.js
          6 -  js/utils.js
        Bin 0 -> 6947 bytes  modules/default/alert/alert.js
          6 -  modules/default/calendar/calendar.js
         33 +-  modules/default/calendar/calendarfetcher.js
          9 +-  modules/default/calendar/calendarfetcherutils.js
        268 +-  modules/default/calendar/calendarutils.js
          6 -  modules/default/calendar/debug.js
          3 -  modules/default/calendar/node_helper.js
         15 +-  modules/default/clock/clock.js
         11 +-  modules/default/compliments/compliments.js
          8 +-  modules/default/defaultmodules.js
          5 +-  modules/default/helloworld/helloworld.js
          6 -  modules/default/newsfeed/newsfeed.js
         43 +-  modules/default/newsfeed/newsfeedfetcher.js
         13 +-  modules/default/newsfeed/node_helper.js
          7 -  modules/default/updatenotification/git_helper.js
         10 +-  .../default/updatenotification/update_helper.js
         57 +-  .../updatenotification/updatenotification.js
         10 +-  modules/default/weather/current.njk
         56 +-  modules/default/weather/providers/envcanada.js
          8 +-  modules/default/weather/providers/openmeteo.js
         12 +-  .../default/weather/providers/openweathermap.js
          9 +-  modules/default/weather/providers/pirateweather.js
         11 +-  modules/default/weather/providers/smhi.js
         12 +-  modules/default/weather/providers/ukmetoffice.js
          9 +-  .../weather/providers/ukmetofficedatahub.js
          9 +-  modules/default/weather/providers/weatherbit.js
         11 +-  modules/default/weather/providers/weatherflow.js
         10 +-  modules/default/weather/providers/weathergov.js
         10 +-  modules/default/weather/providers/yr.js
         10 +-  modules/default/weather/weather.js
         14 +-  modules/default/weather/weatherobject.js
         12 -  modules/default/weather/weatherprovider.js
          9 +-  modules/default/weather/weatherutils.js
          6 -  package-lock.json
       4180 +++++++++++++-------  package.json
         60 +-  serveronly/index.js
          2 +-  tests/configs/default.js
          5 -  tests/configs/empty_ipWhiteList.js
          5 -  tests/configs/modules/alert/default.js
          5 -  tests/configs/modules/calendar/auth-default.js
          5 -  tests/configs/modules/calendar/bad_rrule.js
          5 -  tests/configs/modules/calendar/basic-auth.js
          5 -  tests/configs/modules/calendar/changed-port.js
          5 -  tests/configs/modules/calendar/custom.js
          6 +-  tests/configs/modules/calendar/default.js
          5 -  .../{exdate.js => exdate_la_at_midnight_dst.js}
         13 +-  .../modules/calendar/exdate_la_at_midnight_std.js
         37 +  .../modules/calendar/exdate_la_before_midnight.js
         37 +  .../modules/calendar/exdate_syd_at_midnight_dst.js
         37 +  .../modules/calendar/exdate_syd_at_midnight_std.js
         37 +  .../modules/calendar/exdate_syd_before_midnight.js
         37 +  tests/configs/modules/calendar/fail-basic-auth.js
          7 -  .../configs/modules/calendar/long-fullday-event.js
         28 +  tests/configs/modules/calendar/old-basic-auth.js
          5 -  tests/configs/modules/calendar/recurring.js
          5 -  tests/configs/modules/calendar/rrule_until.js
         30 +  .../calendar/show-duplicates-in-calendar.js
          5 -  .../modules/calendar/single-fullday-event.js
         28 +  tests/configs/modules/clock/clock_12hr.js
          5 -  tests/configs/modules/clock/clock_24hr.js
          5 -  tests/configs/modules/clock/clock_analog.js
          4 -  .../modules/clock/clock_displaySeconds_false.js
          5 -  .../configs/modules/clock/clock_showDateAnalog.js
          5 -  .../configs/modules/clock/clock_showPeriodUpper.js
          5 -  tests/configs/modules/clock/clock_showSunMoon.js
          5 -  tests/configs/modules/clock/clock_showTime.js
          5 -  tests/configs/modules/clock/clock_showWeek.js
          5 -  tests/configs/modules/clock/es/clock_12hr.js
          5 -  tests/configs/modules/clock/es/clock_24hr.js
          5 -  .../modules/clock/es/clock_showPeriodUpper.js
          5 -  tests/configs/modules/clock/es/clock_showWeek.js
          6 -  .../modules/compliments/compliments_animateCSS.js
          6 -  .../compliments_animateCSS_fallbackToDefault.js
          7 -  ...compliments_animateCSS_invertedAnimationName.js
          6 -  .../modules/compliments/compliments_anytime.js
          5 -  .../modules/compliments/compliments_date.js
          5 -  .../compliments/compliments_only_anytime.js
          5 -  .../modules/compliments/compliments_parts_day.js
          5 -  .../modules/compliments/compliments_remote.js
          5 -  tests/configs/modules/display.js
          5 -  tests/configs/modules/helloworld/helloworld.js
          5 -  .../modules/helloworld/helloworld_default.js
          5 -  tests/configs/modules/newsfeed/default.js
          5 -  tests/configs/modules/newsfeed/ignore_items.js
          4 -  tests/configs/modules/newsfeed/incorrect_url.js
          4 -  tests/configs/modules/newsfeed/prohibited_words.js
          4 -  tests/configs/modules/positions.js
          5 -  .../modules/weather/currentweather_compliments.js
          5 -  .../modules/weather/currentweather_default.js
          6 +-  .../modules/weather/currentweather_options.js
          7 +-  .../modules/weather/currentweather_units.js
          7 +-  .../modules/weather/forecastweather_absolute.js
          5 -  .../modules/weather/forecastweather_default.js
          5 -  .../modules/weather/forecastweather_options.js
          5 -  .../modules/weather/forecastweather_units.js
          5 -  .../modules/weather/hourlyweather_default.js
          5 -  .../modules/weather/hourlyweather_options.js
          5 -  .../weather/hourlyweather_showPrecipitation.js
          5 -  tests/configs/noIpWhiteList.js
          5 -  tests/configs/port_8090.js
          5 -  tests/configs/port_variable.js.template
          5 -  tests/configs/without_modules.js
          5 -  tests/e2e/animateCSS_spec.js
          7 -  tests/e2e/fonts_spec.js
          2 +-  tests/e2e/helpers/basic-auth.js
          2 +-  tests/e2e/modules/calendar_spec.js
         31 +  tests/e2e/modules/weather_current_spec.js
         16 +-  tests/e2e/serveronly_spec.js
          2 +-  tests/e2e/template_spec.js
          2 +-  tests/e2e/translations_spec.js
          4 +-  tests/electron/env_spec.js
          2 +-  tests/electron/helpers/global-setup.js
          6 +-  tests/electron/modules/calendar_spec.js
        105 +-  tests/mocks/calendar_test_exdate.ics
         34 -  tests/mocks/calendar_test_full_day_events.ics
         33 +  .../calendar_test_multi_day_starting_today.ics
         33 +  tests/mocks/exdate_la_at_midnight_dst.ics
         15 +  tests/mocks/exdate_la_at_midnight_std.ics
         15 +  tests/mocks/exdate_la_before_midnight.ics
         15 +  tests/mocks/exdate_syd_at_midnight_dst.ics
         15 +  tests/mocks/exdate_syd_at_midnight_std.ics
         15 +  tests/mocks/exdate_syd_before_midnight.ics
         15 +  tests/mocks/rrule_until.ics
         24 +  tests/unit/classes/class_spec.js
          2 +-  tests/unit/classes/translator_spec.js
          2 +-  tests/unit/classes/utils_spec.js
         35 +-  tests/unit/functions/cmp_versions_spec.js
          2 +-  tests/unit/functions/updatenotification_spec.js
         22 +-  tests/unit/global_vars/defaults_modules_spec.js
          4 +-  tests/unit/global_vars/root_path_spec.js
          4 +-  tests/utils/weather_mocker.js
         13 +-  translations/et.json
         31 +-  translations/translations.js
          7 -  vendor/package-lock.json
         10 +-  vendor/package.json
          9 +-  vendor/vendor.js
          6 -  173 files changed, 4108 insertions(+), 2557 deletions(-)  delete mode 100644 .github/codecov.yaml
      create mode 100644 .github/workflows/electronRebuild.yaml
      create mode 100644 mm2.png  rename tests/configs/modules/calendar/{exdate.js => exdate_la_at_midnight_dst.js} (50%)
      create mode 100644 tests/configs/modules/calendar/exdate_la_at_midnight_std.js
      create mode 100644 tests/configs/modules/calendar/exdate_la_before_midnight.js
      create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_dst.js
      create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_std.js
      create mode 100644 tests/configs/modules/calendar/exdate_syd_before_midnight.js
      create mode 100644 tests/configs/modules/calendar/long-fullday-event.js
      create mode 100644 tests/configs/modules/calendar/rrule_until.js
      create mode 100644 tests/configs/modules/calendar/single-fullday-event.js  delete mode 100644 tests/mocks/calendar_test_exdate.ics
      create mode 100644 tests/mocks/calendar_test_full_day_events.ics
      create mode 100644 tests/mocks/calendar_test_multi_day_starting_today.ics
      create mode 100644 tests/mocks/exdate_la_at_midnight_dst.ics
      create mode 100644 tests/mocks/exdate_la_at_midnight_std.ics
      create mode 100644 tests/mocks/exdate_la_before_midnight.ics
      create mode 100644 tests/mocks/exdate_syd_at_midnight_dst.ics
      create mode 100644 tests/mocks/exdate_syd_at_midnight_std.ics
      create mode 100644 tests/mocks/exdate_syd_before_midnight.ics
      create mode 100644 tests/mocks/rrule_until.ics
      processor architecture is armv7l
      updating MagicMirror runtime, please wait
      > magicmirror@2.27.0 postinstall
      > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
      > magicmirror@2.27.0 install-vendor
      > echo "Installing vendor files ...
      > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      changed 1 package in 2s
      > magicmirror@2.27.0 install-fonts
      > echo "Installing fonts ...
      > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      changed 2 packages in 6s
      > magicmirror@2.27.0 prepare
      > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
      no husky installed.
      added 483 packages in 2m
      112 packages are looking for funding
        run `npm fund` for details
      npm install completed - Sun May  5 21:44:26 CDT 2024 on base
      fixing sandbox permissions
      Checking for modules with removed libraries
      downloading dumpactivemodules script
      updating dependencies for active modules with package.json files
      	processing for module MMM-Fuel please wait
      added 17 packages, and audited 18 packages in 9s
      8 packages are looking for funding
      found 0 vulnerabilities
      	processing complete for module MMM-Fuel
      restoring custom.css
      removing git alias
      Upgrade ended - Sun May  5 21:44:39 CDT 2024
      Upgrade started - Thu Jul 25 21:33:44 CDT 2024
      Minimum Node version: v20.9.0
      Installed Node version: v20.16.0
      Installed npm version: V10.8.1
      saving custom.css
      upgrading from version 2.27.0 to 2.28.0
      git fetch rc=0
      On branch master
      Untracked files:
      	run-start.sh
      merge result rc= 0
       Updating 5ea8a346..53fc814f Fast-forward  .github/workflows/automated-tests.yaml
          3 +-  .github/workflows/electronRebuild.yaml
          8 +  CHANGELOG.md
         45 +-  config/config.js.sample
         14 +-  fonts/package-lock.json
         16 +-  fonts/package.json
         10 +-  js/app.js
         15 +-  js/check_config.js
         66 +  js/loader.js
          3 +-  js/main.js
         11 +-  js/utils.js
         11 +  modules/default/calendar/calendar.js
         15 +-  modules/default/compliments/compliments.js
          7 +-  .../default/updatenotification/update_helper.js
         11 +-  modules/default/weather/providers/openmeteo.js
         18 +-  modules/default/weather/providers/weathergov.js
          2 +-  package-lock.json
       3164 +++++++++++++-------  package.json
        105 +-  .../compliments_specialDayUnique_false.js
         22 +  .../compliments_specialDayUnique_true.js
         22 +  tests/e2e/modules/compliments_spec.js
         24 +  vendor/package-lock.json
          8 +-  vendor/package.json
          8 +-  23 files changed, 2342 insertions(+), 1266 deletions(-)
      create mode 100644 tests/configs/modules/compliments/compliments_specialDayUnique_false.js
      create mode 100644 tests/configs/modules/compliments/compliments_specialDayUnique_true.js
      > magicmirror@2.28.0 postinstall
      > magicmirror@2.28.0 install-vendor
      changed 1 package in 11s
      > magicmirror@2.28.0 install-fonts
      > magicmirror@2.28.0 prepare
      no husky installed.
      added 469 packages in 2m
      npm notice
      npm notice New patch version of npm available! 10.8.1 -> 10.8.2
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.8.2
      npm notice To update run: npm install -g npm@10.8.2
      npm notice
      npm install completed - Thu Jul 25 21:35:27 CDT 2024 on base
      removing git alias
      Upgrade ended - Thu Jul 25 21:35:39 CDT 2024
      Upgrade started - Tue Oct  1 16:05:55 CDT 2024
      the os is PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)" NAME="Raspbian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Installed Node version: v20.17.0
      Installed npm version: V10.8.2
      saving custom.css
      upgrading from version 2.28.0 to 2.29.0
      git fetch rc=0
      On branch master
      Untracked files:
      	run-start.sh
      merge result rc= 0
       Updating 53fc814f..94c3c699 Fast-forward  .eslintignore
          2 -  .eslintrc.json
         93 -  .github/CONTRIBUTING.md
          2 +-  .github/workflows/automated-tests.yaml
          2 +-  .../workflows/{depsreview.yaml => dep-review.yaml}
          2 +  ...{electronRebuild.yaml => electron-rebuild.yaml}
          6 +-  .github/workflows/enforce-pullrequest-rules.yaml
          4 +-  .gitignore
          3 +  .prettierignore
          2 +-  CHANGELOG.md
         77 +-  Collaboration.md
         50 +-  README.md
          4 +-  cspell.config.json
        227 +  eslint.config.mjs
        121 +  fonts/package-lock.json
          4 +-  index.html
          1 +  installers/mm.sh
          4 -  js/app.js
         29 +-  js/check_config.js
        104 +-  js/class.js
         21 +-  js/defaults.js
          8 +-  js/electron.js
         50 +-  js/loader.js
         34 +-  js/main.js
         22 +-  js/module.js
         29 +-  js/node_helper.js
         24 +-  js/server.js
         12 +-  js/server_functions.js
         46 +-  js/translator.js
          6 +-  js/utils.js
         41 +-  modules/default/calendar/calendar.js
         38 +-  modules/default/calendar/debug.js
          3 +-  modules/default/compliments/compliments.js
        100 +-  modules/default/defaultmodules.js
          3 +-  .../default/updatenotification/update_helper.js
         19 +-  modules/default/weather/providers/envcanada.js
        342 +-  modules/default/weather/providers/openmeteo.js
         10 +-  .../default/weather/providers/openweathermap.js
         48 +-  modules/default/weather/providers/pirateweather.js
         10 +-  modules/default/weather/providers/smhi.js
         11 +-  modules/default/weather/providers/ukmetoffice.js
         39 +-  .../weather/providers/ukmetofficedatahub.js
         64 +-  modules/default/weather/providers/weatherbit.js
         10 +-  modules/default/weather/providers/weatherflow.js
         38 +-  modules/default/weather/providers/yr.js
         17 +-  modules/default/weather/weather.js
         13 +-  modules/default/weather/weatherutils.js
         36 +-  package-lock.json
       4724 ++++++++++----------  package.json
         51 +-  splashscreen/MagicMirror.plymouth
          8 -  splashscreen/MagicMirror.script
         53 -  splashscreen/splash.png
        Bin 37062 -> 0 bytes  splashscreen/splash_halt.png
        Bin 22304 -> 0 bytes  tests/configs/customregions.js
         23 +  .../modules/calendar/exdate_la_at_midnight_dst.js
          3 +-  .../modules/calendar/exdate_la_before_midnight.js
          3 +-  .../modules/calendar/exdate_syd_at_midnight_dst.js
          3 +-  .../modules/calendar/exdate_syd_at_midnight_std.js
          3 +-  .../modules/calendar/exdate_syd_before_midnight.js
          3 +-  .../configs/modules/calendar/long-fullday-event.js
          3 +-  .../modules/calendar/single-fullday-event.js
          3 +-  .../modules/calendar/sliceMultiDayEvents.js
         30 +  .../modules/compliments/compliments_cron_entry.js
         18 +  .../compliments/compliments_e2e_cron_entry.js
         18 +  tests/e2e/animateCSS_spec.js
          2 +-  tests/e2e/custom_module_regions_spec.js
         30 +  tests/e2e/helpers/global-setup.js
         57 +-  tests/e2e/modules/calendar_spec.js
         11 -  tests/e2e/modules/compliments_spec.js
         11 +  tests/e2e/modules/newsfeed_spec.js
         31 +-  tests/e2e/modules/weather_hourly_spec.js
          4 +-  tests/e2e/modules_display_spec.js
          2 +-  tests/e2e/serveronly_spec.js
          2 +-  tests/electron/modules/calendar_spec.js
        123 +-  tests/electron/modules/compliments_spec.js
         36 +  tests/mocks/sliceMultiDayEvents.ics
         58 +  tests/unit/functions/server_functions_spec.js
          6 +-  .../modules/default/weather/weather_utils_spec.js
          2 +-  vendor/package-lock.json
         36 +-  vendor/package.json
          3 +-  vendor/vendor.js
          3 +-  84 files changed, 4147 insertions(+), 3078 deletions(-)  delete mode 100644 .eslintignore  delete mode 100644 .eslintrc.json  rename .github/workflows/{depsreview.yaml => dep-review.yaml} (90%)  rename .github/workflows/{electronRebuild.yaml => electron-rebuild.yaml} (77%)
      create mode 100644 cspell.config.json
      create mode 100644 eslint.config.mjs  delete mode 100755 installers/mm.sh  delete mode 100644 splashscreen/MagicMirror.plymouth  delete mode 100644 splashscreen/MagicMirror.script  delete mode 100644 splashscreen/splash.png  delete mode 100644 splashscreen/splash_halt.png
      create mode 100644 tests/configs/customregions.js
      create mode 100644 tests/configs/modules/calendar/sliceMultiDayEvents.js
      create mode 100644 tests/configs/modules/compliments/compliments_cron_entry.js
      create mode 100644 tests/configs/modules/compliments/compliments_e2e_cron_entry.js
      create mode 100644 tests/e2e/custom_module_regions_spec.js
      create mode 100644 tests/mocks/sliceMultiDayEvents.ics
      > magicmirror@2.29.0 postinstall
      > magicmirror@2.29.0 install-vendor
      added 1 package, and changed 1 package in 9s
      > magicmirror@2.29.0 install-fonts
      changed 2 packages in 5s
      > magicmirror@2.29.0 prepare
      no husky installed.
      added 466 packages in 1m
      npm install completed - Tue Oct  1 16:07:21 CDT 2024 on base
      removing git alias
      Upgrade ended - Tue Oct  1 16:07:33 CDT 2024
      Butch
      Resistance is not Futile!
      It is voltage divided by current.
        sdetweil @butchkemper
        @butchkemper yes, i have also updated the upgrade script to fix that
        butchkemperB 1 Reply Last reply Reply Quote 0
          @butchkemper is this starting w pm2? or npm start
            butchkemper
            pm2 when I do it manually.
            I am not sure what the default when the system comes up. How do I find what the system uses?
            Butch
              @butchkemper manual is
              npm start
              in the MM folder
              otherwise by command or autostart is pm2
              can you try
              npm start
              in the MagicMirror folder?
                butchkemper @sdetweil
                Okay, using the npm start &, the mirror comes up. The MMM-Fuel app is working but I have a problem with the weather app which is something I can work through.
                So, how do I make the autostart at reboot work?
                By doing the npm start, the pm2 logs are not working. I am missing that good debugging aid.
                Here are messages displayed during the start:
                ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model A Plus Rev 1.0; virtual: false
                ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
                ### VERSIONS: electron: 31.6.0; used node: 20.17.0; installed node: 20.17.0; npm: 10.8.2; pm2: 5.4.2
                ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
                Thanks,
                Butch
                  @butchkemper ok, MagicMirror is good
                  check for the installers/mm.sh
                  my upgrade script has a bug ill fix later this morning
                    @sdetweil The v2.29.0 installers directory does not include the mm.sh file.
                    Is it a fix to copy the mm.sh file from v2.28.0 installers directory?
                        @sdetweil I ran the fixuppm2 script and now MM starts when the System starts and pm2 now works.
                        I just need to figure out why the MM Calendar is not starting.
                        Thank you for your help.
                        Butch
                        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                        • butchkemperB butchkemper has marked this topic as solved on
