    Upgrade to 2.29.0 - Cannot read properties of undefined (reading 'disableHardwareAcceleration
    9 Posts 2 Posters 984 Views 2 Watching
      sdetweil @butchkemper
      @butchkemper is this starting w pm2? or npm start
      • butchkemperB Offline
        butchkemper
        pm2 when I do it manually.
        I am not sure what the default when the system comes up. How do I find what the system uses?
        Butch
        Resistance is not Futile!
        It is voltage divided by current.
          @butchkemper manual is
          npm start
          in the MM folder
          otherwise by command or autostart is pm2
          can you try
          npm start
          in the MagicMirror folder?
          butchkemperB 1 Reply Last reply Reply Quote 0
            butchkemper @sdetweil
            Okay, using the npm start &, the mirror comes up. The MMM-Fuel app is working but I have a problem with the weather app which is something I can work through.
            So, how do I make the autostart at reboot work?
            By doing the npm start, the pm2 logs are not working. I am missing that good debugging aid.
            Here are messages displayed during the start:
            ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model A Plus Rev 1.0; virtual: false
            ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
            ### VERSIONS: electron: 31.6.0; used node: 20.17.0; installed node: 20.17.0; npm: 10.8.2; pm2: 5.4.2
            ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
            Thanks,
            Butch
              @butchkemper ok, MagicMirror is good
              check for the installers/mm.sh
              my upgrade script has a bug ill fix later this morning
                @sdetweil The v2.29.0 installers directory does not include the mm.sh file.
                Is it a fix to copy the mm.sh file from v2.28.0 installers directory?
                  @butchkemper yes, i have also updated the upgrade script to fix that
                    @sdetweil I ran the fixuppm2 script and now MM starts when the System starts and pm2 now works.
                    I just need to figure out why the MM Calendar is not starting.
                    Thank you for your help.
                    Butch
                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                    • butchkemperB butchkemper has marked this topic as solved on
