    MMM-Scrapey - I made something that could be useful?
    14 Posts 5 Posters 3.1k Views 5 Watching
      sdetweil @fredric.nil
      @fredric.nil
      well there is a problem
      .MMM-Scrapey .td {
      the stuff before the {
      is called the selector clause, it ‘selects’ the elements the styles after the { apply to
      if the thing in the selector clause starts with a dot(.)
      that means classname, class=
      if it starts with a pound sign(#)
      that means id, id=
      otherwise no prefix means an html element name
      table, tr, td, div, …
      you have .td
      • F Offline
        fredric.nil
        I put it in the custom.css.
        It doesn’t seem to matter if I enter
        .td , #td , td or .MMM-Scrapey .td , .MMM-Scrapey3 #td or .MMM-Scrapey td or even .td , #td or td before {
        I can only say that this is not my cup of tea.
          AndyHazz Project Sponsor
          @fredric.nil yes as @sdetweil says it needed to be .MMM-Scrapey td {} to have any effect.
          Try this in your custom CSS, I think it’s the line height you want to adjust, not the padding:
          .MMM-Scrapey td {
              line-height: 1;
          MagicMirror default line height on the body element is 1.5 so I think everything inherits that unless overidden.
          • F Offline
            fredric.nil
            @AndyHazz said in MMM-Scrapey - I made something that could be useful?:
            .MMM-Scrapey td {
            line-height: 1;
            Just that, perfect
            Thank you.
