    MMM-Pir toggling
    22 Posts 3 Posters 1.7k Views 3 Watching
      sdetweil @ttt126
      @ttt126 said in MMM-Pir toggling:
      exec: “/neu1.py”
      that means in the root system folder’if you meant YOUR home folder
      that would be , replace username with really logged on user for home folder
      /home/username/neu1.py
      there may have been messages posted to the MM startup output
      • T Offline
        ttt126
        Even with /home/pi/neu1.py it is not responding.
        Do I have to devine true and fals state in the config as well?
          sdetweil @ttt126
          @ttt126 can you execute the script manually from the terminal window?
          • T Offline
            ttt126
            Yes, this I can.
            Kliking - exexute, relay klliks on an off once.
              sdetweil @ttt126
              @ttt126 ok, i was checking for permissions
              did you check the messages from npm start location, see if any errors were posted
              • T Offline
                ttt126
                @sdetweil said in MMM-Pir toggling:
                npm start location
                pi@MagicMirro-2:~/MagicMirror/config $ npm start
                magicmirror@2.29.0 start
                DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                [2024-10-23 17:12:16.266] [LOG] Starting MagicMirror: v2.29.0
                [2024-10-23 17:12:16.334] [LOG] Loading config …
                [2024-10-23 17:12:16.341] [LOG] config template file not exists, no envsubst
                [2024-10-23 17:12:17.515] [INFO] Checking config file /home/pi/MagicMirror/conf ig/config.js …
                [2024-10-23 17:12:17.711] [INFO] Your configuration file doesn’t contain syntax errors :)
                [2024-10-23 17:12:17.712] [INFO] Checking modules structure configuration …
                [2024-10-23 17:12:17.959] [INFO] Your modules structure configuration doesn’t c ontain errors :)
                [2024-10-23 17:12:17.967] [LOG] Loading module helpers …
                [2024-10-23 17:12:18.020] [LOG] Initializing new module helper …
                [2024-10-23 17:12:18.022] [LOG] Module helper loaded: MMM-Pir
                [2024-10-23 17:12:18.026] [LOG] Initializing new module helper …
                [2024-10-23 17:12:18.028] [LOG] Module helper loaded: MMM-NotificationTrigger
                [2024-10-23 17:12:18.031] [LOG] No helper found for module: alert.
                [2024-10-23 17:12:18.042] [LOG] Initializing new module helper …
                [2024-10-23 17:12:18.043] [LOG] Module helper loaded: updatenotification
                [2024-10-23 17:12:18.044] [LOG] No helper found for module: clock.
                [2024-10-23 17:12:18.298] [LOG] Initializing new module helper …
                [2024-10-23 17:12:18.299] [LOG] Module helper loaded: calendar
                [2024-10-23 17:12:18.300] [LOG] No helper found for module: MMM-WebView.
                [2024-10-23 17:12:18.303] [LOG] No helper found for module: weather.
                [2024-10-23 17:12:18.306] [LOG] No helper found for module: MMM-RAIN-MAP.
                [2024-10-23 17:12:18.488] [LOG] Initializing new module helper …
                [2024-10-23 17:12:18.489] [LOG] Module helper loaded: newsfeed
                [2024-10-23 17:12:18.490] [LOG] All module helpers loaded.
                [2024-10-23 17:12:18.522] [LOG] Starting server on port 8080 …
                [2024-10-23 17:12:20.761] [ERROR] Whoops! There was an uncaught exception…
                [2024-10-23 17:12:20.816] [ERROR] Error: listen EADDRINUSE: address already in u se ::1:8080
                at Server.setupListenHandle [as _listen2] (node:net:1904:16)
                at listenInCluster (node:net:1961:12)
                at GetAddrInfoReqWrap.doListen [as callback] (node:net:2135:7)
                at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:111:8) {
                code: ‘EADDRINUSE’,
                errno: -98,
                syscall: ‘listen’,
                address: ‘::1’,
                port: 8080
                [2024-10-23 17:12:20.818] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [2024-10-23 17:12:20.824] [ERROR] If you think this really is an issue, please o pen an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                [13489:1023/171222.609717:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.619958:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.622864:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.623145:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.623492:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.623703:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.623989:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.624237:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.624616:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.627519:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.631965:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.632229:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.632531:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.632730:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.634239:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.637235:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.639949:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.643515:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.647036:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.647506:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.648316:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.648593:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.648900:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.649075:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.649295:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.649472:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [13489:1023/171222.649704:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [13489:1023/171222.649858:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [2024-10-23 17:12:24.158] [INFO] System information:
                SYSTEM: manufacturer: ; model: ; virtual: false
                OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
                VERSIONS: electron: 31.7.1; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
                OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                I think no errors according to the problem.
                  sdetweil @ttt126
                  @ttt126 that means you started MM AGAIN…
                  if you are using PM2, then you need to use the pm2 commands
                  pm2 status
                  pm2 stop x
                  where x is the name or number of the row of the app you want control
                  and then pm2 start x
                  or you can do
                  pm2 restart x
                  I STRONGLY recommend using manual start while you are developing your mm solution
                  changing config, adding modules
                  pm2 stop all
                  cd ~/MagicMirror
                  npm start
                  to stop MM in this mode, hit ctrl-q on the MM screen
                  if you do this over ssh cause you have no keyboard on the mm system (like me all the time) press ctrl-c in the ssh window where you did npm start
                  (if you do this when PM2 is controlling, it will do its job, “keep the app running”,
                  you stop it, and pm2 will restart it… )
                  • T Offline
                    ttt126
                    so this is the aktual config
                    the command python3 /home/pi/neu1.py is acting the relay if executed in termnal
                    I use fire and exec both with no action.
                    maybe there is no trigger natification.
                    module: "MMM-NotificationTrigger",
                                             triggers:[
                                                  trigger: "USER_PRESENCE",
                                                  fires: [
                                                      fire:"python3 /home/pi/neu1.py",
                                                      exec: (payload) => {
                                                        return "python3 /homr/pi/neu1.py " + payload.option
                    • T Offline
                      ttt126
                      I got it working, many thanks for your Help :-)
                        sdetweil @ttt126
                        @ttt126 what was the issue? might help others in the same predicament
                        • 2 / 3
