Dell LCD Display with ESP32
 Dear community, Thanks again for the helpful links and tips regarding my project. I’ve now more or less completed it. The only thing still missing is a suitable flat and thin frame—then it’ll be fully done. I’m really impressed by how well it works with the Raspberry Pi Zero 2 W. Everything runs smoothly, and I’ve been able to install all the modules I need without any issues. The whole setup is now less than 1 cm thick. With the frame, it will probably end up around 1.5 cm. Unfortunately, I still have to run two cables—one for the display board and one for the Zero2. Once again, thank you so much for the support! This project was a lot of fun and now gives us a great overview of daily tasks, appointments, current traffic conditions, weather, and more.
 Very nice. I have done something similar, although I prefer the Pi 3 Model A+. It’s slightly bigger than the zero 2w but is clocked faster (1.4 GHz vs 1) and has a full-size HDMI port. (they both use essentially the same SoC). Note I have historically had problems with running out of memory running electron in the 512 MB limited memory space - but using dietPI has really help stability
