    custom.css ......body???
    42 Posts 3 Posters 5.5k Views 3 Watching
      sdetweil @piki
      @piki not separately from the mm language setting, which is set up at the top, before the modules:[] list
      • P Offline
        piki
        I don’t understand
          sdetweil @piki
          @piki you can set the language for MagicMirror in config.js
            var config = {
              address: "0.0.0.0",
               port: 8090,
              basePath: "/",
              language: "en",     <----- here
              serverOnly: "local",
              locale: "en-US",   <--- and here
              modules: [   <---- after here is module configuration
          • P Offline
            piki
            so I have it now…the clock shows me in “sk” language but the weather in “en”…???
            language: "sk",
            locale: "sk-SK",
            timeFormat: 24,
            units: "metric",
            		module: "clock",
            		position: "bottom_left"
            		module: "weather",
            		position: "bottom_right",
            			weatherProvider: "openmeteo",
            			type: "current",
            			lat: 48.7164,
            			lon: 21.2611,
            			units: "metric",
            			showForecast: true,
            			forecastLayout: "horizontal",
            			showSun: true,
            			lang: "sk",
              sdetweil @piki
              @piki right… there are two problems
              1. it should follow the system config - but doesn’t
              2. user should be able to override that - but can’t
              • P Offline
                piki
                is it not possible?
                  sdetweil @piki
                  @piki today, no
                  • P Offline
                    piki
                    I changed the bold font in main.css, but in the clock it only changed the date and day to bold, the clock itself remained thin… where could the problem be?
                      sdetweil @piki
                      @piki need more CSS work… every little element needs style… most do NOT inherit from their parent, or their particular thing doesn’t have the same style in effect…
                      • P Offline
                        piki
                        Can I find the specific clock element somewhere or do I have to write it down?
                        S R 2 Replies Last reply Reply Quote 0
                        • 4 / 5
