custom.css ......body???
42 Posts 3 Posters 4.0k Views 3 Watching
    sdetweil @piki
    @piki yes,
    you should be able to use the developers window to add that to test out
    select the body element and add in top right
    • P Offline
      piki
      I copied it directly into custom .css…but it still doesn’t work
      S 1 Reply Last reply Nov 19, 2024, 4:23 PM Reply Quote 0
        sdetweil @piki
        @piki can you show the custom.css entry
        • P Offline
          piki
          body {
          background-image : uurl(‘http://localhost:8080/sku.jpg.’);
          background-size: cover;
          S 2 Replies Last reply Nov 19, 2024, 4:38 PM Reply Quote 0
            sdetweil @piki
            @piki said in custom.css ......body???:
            uurl
            only url
            • P Offline
              piki
              I fixed it, but the image still doesn’t appear
              body {
              background-image : url(‘http://localhost:8080/sku.jpg.’);
              S 1 Reply Last reply Nov 19, 2024, 4:44 PM Reply Quote 0
                sdetweil @piki
                @piki and if you open the developers window, elements tab , select the body element
                is the css selected
                and are there any errors? (in the console tab)
                  sdetweil @piki
                  /sku.jpg.');
                  you also have a trailing . in the image name, ‘jpg.’
                  • P Offline
                    piki
                    Failed to load resource: the server responded with a status of 404 (Not found) sku.jpg.:1
                    S 1 Reply Last reply Nov 19, 2024, 4:51 PM Reply Quote 0
                      sdetweil @piki
                      @piki still the trailing comma
                      but, I tested here, needs to be in a subfolder of MagicMirror, config worked
                      • 2 / 5
                      2 / 5
