    custom.css ......body???
    42 Posts 3 Posters 11.5k Views 3 Watching
      sdetweil @piki
      @piki said in custom.css ......body???:
      uurl
      only url
        piki
        I fixed it, but the image still doesn’t appear
        body {
        background-image : url(‘http://localhost:8080/sku.jpg.’);
        background-size: cover;
          sdetweil @piki
          @piki and if you open the developers window, elements tab , select the body element
          is the css selected
          and are there any errors? (in the console tab)
            sdetweil @piki
            /sku.jpg.');
            you also have a trailing . in the image name, ‘jpg.’
              piki
              Failed to load resource: the server responded with a status of 404 (Not found) sku.jpg.:1
                sdetweil @piki
                @piki still the trailing comma
                but, I tested here, needs to be in a subfolder of MagicMirror, config worked
                  piki
                  yes, I also have the ending “.jpg” in the image name
                    sdetweil @piki
                    @piki no… your copy of custom.css said
                    body {
                    background-image : uurl(‘http://localhost:8080/sku.jpg. <<<<<<<<<—’);
                    also, you need to move the image to some subfolder
                    this worked for me(random jpg)
                    body {
                        background-image : url('http://localhost:8090/config/scan-uuid.jpg');
                      piki
                      I put the sku.jpg file in the config directory…and it works…thank you very much
                      one more question, how do I change the color of the clock and weather module to black?
                        sdetweil @piki
                        you will have to change/override the CSS for those…
                        in each module folder is the defined css (don’t change there, override in custom.css
                        if not there(same for every module), then examine the elements in the developers window elements tab
                          piki
                          great, and if I want “Bolt” bold text instead of thin?
                            sdetweil @piki
                            @piki see main.css for the defined colors and styles
                            if nothing there that works for you, then you have to define your own (in custom.css)
                              piki
                              if I would like to move the clock or the weather more towards the center from the edge, do I have to write it in config.js? is that so
                                sdetweil @piki
                                @piki in config.js are only the defined positions.
                                see https://forum.magicmirror.builders/topic/286/regions?_=1732038547578
                                otherwise you have to use css to adjust things.
                                note that main.css defines margins around modules and the overall screen
                                so you may have to adjust margins
                                  piki
                                  thank you very much for all the advice so far…you have helped me a lot
                                    piki
                                    can be changed language in openmeteo weather?
                                      sdetweil @piki
                                      @piki not separately from the mm language setting, which is set up at the top, before the modules:[] list
                                        piki
                                        I don’t understand
                                          sdetweil @piki
                                          @piki you can set the language for MagicMirror in config.js
                                            var config = {
                                              address: "0.0.0.0",
                                               port: 8090,
                                              basePath: "/",
                                              language: "en",     <----- here
                                              serverOnly: "local",
                                              locale: "en-US",   <--- and here
                                              modules: [   <---- after here is module configuration
                                            piki
                                            so I have it now…the clock shows me in “sk” language but the weather in “en”…???
                                            language: "sk",
                                            locale: "sk-SK",
                                            timeFormat: 24,
                                            units: "metric",
                                            		module: "clock",
                                            		position: "bottom_left"
                                            		module: "weather",
                                            		position: "bottom_right",
                                            			weatherProvider: "openmeteo",
                                            			type: "current",
                                            			lat: 48.7164,
                                            			lon: 21.2611,
                                            			units: "metric",
                                            			showForecast: true,
                                            			forecastLayout: "horizontal",
                                            			showSun: true,
                                            			lang: "sk",
                                            • 2 / 3
