    custom.css ......body???
    42 Posts 3 Posters 11.0k Views 3 Watching
      sdetweil @piki
      @piki IF you make the file to appear (copy or link) IN the MM tree THEN you can make it work thru css only
      the MM http server is configured ONLY for the MagicMirror tree and forward…
      not just anywhere in the file system
        piki
        but in which line in the tree should I edit (configure) just write the path there…or?
          sdetweil @piki
          @piki sorry, don’t understand the question
          put your file in ~/MagicMirror
          then your css url will be
          http://localhost:mm_config_port (usually 8080)/filename(whatever the name of the file is in the MagicMirror folder)
          http://localhost:8080/somefile.jpg
          or whatever you call it
          if you don’t want to copy it then
          sudo ln -s /wherever_the_actual_file_is somefile.jpg
          that will create a link for the file (from the booted sd card) to the MagicMirror folder
          you can name it whatever you want with whatever type it is: gif, png, jpg…
            piki
              sdetweil @piki
              @piki so
              http://localhost:8080/sku.jpg
                piki
                and should I enter that in custom .css?
                body {
                background-image : url(‘http://localhost:8080/sku.jpg.’);
                background-size: cover;
                  sdetweil @piki
                  @piki yes,
                  you should be able to use the developers window to add that to test out
                  select the body element and add in top right
                    piki
                    I copied it directly into custom .css…but it still doesn’t work
                      sdetweil @piki
                      @piki can you show the custom.css entry
                        piki
                        body {
                        background-image : uurl(‘http://localhost:8080/sku.jpg.’);
                          sdetweil @piki
                          @piki said in custom.css ......body???:
                          uurl
                          only url
                            piki
                            I fixed it, but the image still doesn’t appear
                            body {
                              sdetweil @piki
                              @piki and if you open the developers window, elements tab , select the body element
                              is the css selected
                              and are there any errors? (in the console tab)
                                sdetweil @piki
                                /sku.jpg.');
                                you also have a trailing . in the image name, ‘jpg.’
                                  piki
                                  Failed to load resource: the server responded with a status of 404 (Not found) sku.jpg.:1
                                    sdetweil @piki
                                    @piki still the trailing comma
                                    but, I tested here, needs to be in a subfolder of MagicMirror, config worked
                                      piki
                                      yes, I also have the ending “.jpg” in the image name
                                        sdetweil @piki
                                        @piki no… your copy of custom.css said
                                        body {
                                        background-image : uurl(‘http://localhost:8080/sku.jpg. <<<<<<<<<—’);
                                        also, you need to move the image to some subfolder
                                        this worked for me(random jpg)
                                        body {
                                            background-image : url('http://localhost:8090/config/scan-uuid.jpg');
                                          piki
                                          I put the sku.jpg file in the config directory…and it works…thank you very much
                                          one more question, how do I change the color of the clock and weather module to black?
                                            sdetweil @piki
                                            you will have to change/override the CSS for those…
                                            in each module folder is the defined css (don’t change there, override in custom.css
                                            if not there(same for every module), then examine the elements in the developers window elements tab
