    custom.css ......body???
    42 Posts 3 Posters 7.3k Views 3 Watching
      sdetweil @piki
      @piki IF you make the file to appear (copy or link) IN the MM tree THEN you can make it work thru css only
      the MM http server is configured ONLY for the MagicMirror tree and forward…
      not just anywhere in the file system
        piki
        but in which line in the tree should I edit (configure) just write the path there…or?
          sdetweil @piki
          @piki sorry, don’t understand the question
          put your file in ~/MagicMirror
          then your css url will be
          http://localhost:mm_config_port (usually 8080)/filename(whatever the name of the file is in the MagicMirror folder)
          http://localhost:8080/somefile.jpg
          or whatever you call it
          if you don’t want to copy it then
          sudo ln -s /wherever_the_actual_file_is somefile.jpg
          that will create a link for the file (from the booted sd card) to the MagicMirror folder
          you can name it whatever you want with whatever type it is: gif, png, jpg…
            piki
              sdetweil @piki
              @piki so
              http://localhost:8080/sku.jpg
                piki
                and should I enter that in custom .css?
                body {
                background-image : url(‘http://localhost:8080/sku.jpg.’);
                background-size: cover;
                  sdetweil @piki
                  @piki yes,
                  you should be able to use the developers window to add that to test out
                  select the body element and add in top right
                    piki
                    I copied it directly into custom .css…but it still doesn’t work
                      sdetweil @piki
                      @piki can you show the custom.css entry
                        piki
                        body {
                        background-image : uurl(‘http://localhost:8080/sku.jpg.’);
                        • 1 / 5
