    custom.css ......body???
    42 Posts 3 Posters 11.5k Views 3 Watching
      piki
      http://localhost:8080/sku.jpg
      and should I enter that in custom .css?
      body {
      background-image : url(‘http://localhost:8080/sku.jpg.’);
      background-size: cover;
        sdetweil @piki
        @piki yes,
        you should be able to use the developers window to add that to test out
        select the body element and add in top right
          piki
          I copied it directly into custom .css…but it still doesn’t work
            sdetweil @piki
            @piki can you show the custom.css entry
              piki
              body {
              background-image : uurl(‘http://localhost:8080/sku.jpg.’);
              S 2 Replies Last reply
                sdetweil @piki
                @piki said in custom.css ......body???:
                uurl
                only url
                  piki
                  I fixed it, but the image still doesn’t appear
                  body {
                    sdetweil @piki
                    @piki and if you open the developers window, elements tab , select the body element
                    is the css selected
                    and are there any errors? (in the console tab)
                      sdetweil @piki
                      /sku.jpg.');
                      you also have a trailing . in the image name, ‘jpg.’
                        piki
                        Failed to load resource: the server responded with a status of 404 (Not found) sku.jpg.:1
                          sdetweil @piki
                          @piki still the trailing comma
                          but, I tested here, needs to be in a subfolder of MagicMirror, config worked
                            piki
                            yes, I also have the ending “.jpg” in the image name
                              sdetweil @piki
                              @piki no… your copy of custom.css said
                              body {
                              background-image : uurl(‘http://localhost:8080/sku.jpg. <<<<<<<<<—’);
                              also, you need to move the image to some subfolder
                              this worked for me(random jpg)
                              body {
                                  background-image : url('http://localhost:8090/config/scan-uuid.jpg');
                                piki
                                I put the sku.jpg file in the config directory…and it works…thank you very much
                                one more question, how do I change the color of the clock and weather module to black?
                                  sdetweil @piki
                                  you will have to change/override the CSS for those…
                                  in each module folder is the defined css (don’t change there, override in custom.css
                                  if not there(same for every module), then examine the elements in the developers window elements tab
                                    piki
                                    great, and if I want “Bolt” bold text instead of thin?
                                      sdetweil @piki
                                      @piki see main.css for the defined colors and styles
                                      if nothing there that works for you, then you have to define your own (in custom.css)
                                        piki
                                        if I would like to move the clock or the weather more towards the center from the edge, do I have to write it in config.js? is that so
                                          sdetweil @piki
                                          @piki in config.js are only the defined positions.
                                          see https://forum.magicmirror.builders/topic/286/regions?_=1732038547578
                                          otherwise you have to use css to adjust things.
                                          note that main.css defines margins around modules and the overall screen
                                          so you may have to adjust margins
                                            piki
                                            thank you very much for all the advice so far…you have helped me a lot
