    custom.css ......body???
    42 Posts 3 Posters 11.5k Views 3 Watching
      piki
        sdetweil @piki
        @piki so
        http://localhost:8080/sku.jpg
          piki
          and should I enter that in custom .css?
          body {
          background-image : url(‘http://localhost:8080/sku.jpg.’);
          background-size: cover;
            sdetweil @piki
            @piki yes,
            you should be able to use the developers window to add that to test out
            select the body element and add in top right
              piki
              I copied it directly into custom .css…but it still doesn’t work
                sdetweil @piki
                @piki can you show the custom.css entry
                  piki
                  body {
                  background-image : uurl(‘http://localhost:8080/sku.jpg.’);
                  S 2 Replies Last reply
                    sdetweil @piki
                    @piki said in custom.css ......body???:
                    uurl
                    only url
                      piki
                      I fixed it, but the image still doesn’t appear
                      body {
                        sdetweil @piki
                        @piki and if you open the developers window, elements tab , select the body element
                        is the css selected
                        and are there any errors? (in the console tab)
                          sdetweil @piki
                          /sku.jpg.');
                          you also have a trailing . in the image name, ‘jpg.’
                            piki
                            Failed to load resource: the server responded with a status of 404 (Not found) sku.jpg.:1
                              sdetweil @piki
                              @piki still the trailing comma
                              but, I tested here, needs to be in a subfolder of MagicMirror, config worked
                                piki
                                yes, I also have the ending “.jpg” in the image name
                                  sdetweil @piki
                                  @piki no… your copy of custom.css said
                                  body {
                                  background-image : uurl(‘http://localhost:8080/sku.jpg. <<<<<<<<<—’);
                                  also, you need to move the image to some subfolder
                                  this worked for me(random jpg)
                                  body {
                                      background-image : url('http://localhost:8090/config/scan-uuid.jpg');
                                    piki
                                    I put the sku.jpg file in the config directory…and it works…thank you very much
                                    one more question, how do I change the color of the clock and weather module to black?
                                      sdetweil @piki
                                      you will have to change/override the CSS for those…
                                      in each module folder is the defined css (don’t change there, override in custom.css
                                      if not there(same for every module), then examine the elements in the developers window elements tab
                                        piki
                                        great, and if I want “Bolt” bold text instead of thin?
                                          sdetweil @piki
                                          @piki see main.css for the defined colors and styles
                                          if nothing there that works for you, then you have to define your own (in custom.css)
                                            piki
                                            if I would like to move the clock or the weather more towards the center from the edge, do I have to write it in config.js? is that so
