    custom.css ......body???
    42 Posts 3 Posters 7.3k Views 3 Watching
      piki @sdetweil
      @sdetweil so via custom.css as I read it won’t work over time?
        piki
        or it won’t work only through custom .css?
          sdetweil @piki
          @piki IF you make the file to appear (copy or link) IN the MM tree THEN you can make it work thru css only
          the MM http server is configured ONLY for the MagicMirror tree and forward…
          not just anywhere in the file system
            piki
            but in which line in the tree should I edit (configure) just write the path there…or?
              sdetweil @piki
              @piki sorry, don’t understand the question
              put your file in ~/MagicMirror
              then your css url will be
              http://localhost:mm_config_port (usually 8080)/filename(whatever the name of the file is in the MagicMirror folder)
              http://localhost:8080/somefile.jpg
              or whatever you call it
              if you don’t want to copy it then
              sudo ln -s /wherever_the_actual_file_is somefile.jpg
              that will create a link for the file (from the booted sd card) to the MagicMirror folder
              you can name it whatever you want with whatever type it is: gif, png, jpg…
                piki
                  sdetweil @piki
                  @piki so
                  http://localhost:8080/sku.jpg
                    piki
                    and should I enter that in custom .css?
                    body {
                    background-image : url(‘http://localhost:8080/sku.jpg.’);
                    background-size: cover;
                      sdetweil @piki
                      @piki yes,
                      you should be able to use the developers window to add that to test out
                      select the body element and add in top right
                        piki
                        I copied it directly into custom .css…but it still doesn’t work
                        • 1 / 5
