custom.css ......body???
42 Posts 3 Posters 3.9k Views 3 Watching
    piki
    Re: CSS 101 - Getting started with CSS and understanding how CSS works
    I can’t change the background to MagiMirror. I need to put one image (file) there that will be loaded from the SD card. I also changed through css…but none of it works. If I change only the color it works…but the photo from the file does not. I checked the path name of the address books…but it still doesn’t work. Isn’t it necessary to add something? Thanks for any advice.
    S 1 Reply Last reply Nov 18, 2024, 5:29 PM Reply Quote 0
      sdetweil @piki
      @piki the MM webserver root is the MagicMirror folder, you cannot load anything from outside that folder tree thru the local server file:/// doesn’t work either
      http://localhost:MM-port/
      points to the MagicMirror folder
      SO, you can make a LINK to the file into the MM folder
      see the ln command
      sudo ln -s source dest
      source is where it is
      dest is where you want it to appear
      also, see the second link in my signature below, or using the developers window elements tab to check on the contents and play with/test styles on elements
      P 1 Reply Last reply Nov 18, 2024, 6:04 PM Reply Quote 0
        piki @sdetweil
        @sdetweil so via custom.css as I read it won’t work over time?
          piki
          or it won’t work only through custom .css?
          S 1 Reply Last reply Nov 18, 2024, 6:33 PM Reply Quote 0
            sdetweil @piki
            @piki IF you make the file to appear (copy or link) IN the MM tree THEN you can make it work thru css only
            the MM http server is configured ONLY for the MagicMirror tree and forward…
            not just anywhere in the file system
              piki
              but in which line in the tree should I edit (configure) just write the path there…or?
              S 1 Reply Last reply Nov 18, 2024, 7:05 PM Reply Quote 0
                sdetweil @piki
                @piki sorry, don’t understand the question
                put your file in ~/MagicMirror
                then your css url will be
                http://localhost:mm_config_port (usually 8080)/filename(whatever the name of the file is in the MagicMirror folder)
                http://localhost:8080/somefile.jpg
                or whatever you call it
                if you don’t want to copy it then
                sudo ln -s /wherever_the_actual_file_is somefile.jpg
                that will create a link for the file (from the booted sd card) to the MagicMirror folder
                you can name it whatever you want with whatever type it is: gif, png, jpg…
                  piki
                  S 1 Reply Last reply Nov 18, 2024, 7:46 PM Reply Quote 0
                    sdetweil @piki
                    @piki so
                    http://localhost:8080/sku.jpg
                      piki
                      and should I enter that in custom .css?
                      body {
                      background-image : url(‘http://localhost:8080/sku.jpg.’);
                      background-size: cover;
                      S 1 Reply Last reply Nov 18, 2024, 8:45 PM Reply Quote 0
                      • 1 / 5
                      1 / 5
