    Help with Snow Falling Module
    7 Posts 2 Posters 983 Views 2 Watching
    • X Offline
      xTITUS MAXIMUSx
      I am currently trying to create a module that will display snow falling on the screen. I’m sure I am missing something but, from what I can tell the module is loading in the logs, just not displaying the snow falling. Any help would be appreciated.
      MMM-SnowFlakes.js
      Module.register("MMM-Snowflakes", {
              // Default configuration options
              defaults: {
                      totalSnowflakes: 50, // Number of snowflakes
              // Start method
              start: function () {
                      Log.info("Starting module: " + this.name);
              // Override the getDom method to provide the HTML content
              getDom: function () {
                      const wrapper = document.createElement("div");
                      wrapper.className = "initial-snow"; // The main container for the snowflakes
                      return wrapper;
              // Load the CSS and external JS file
              getStyles: function () {
                      return ["MMM-Snowflakes.css"];
              getScripts: function () {
                      return ["snowflakes.js"];
              // Pass configuration to the client-side script
              getConfig: function () {
                      return this.config;
      snowflakes.js
      document.addEventListener("DOMContentLoaded", () => {
              const snowContainer = document.querySelector(".initial-snow");
              const totalSnowflakes = window.ModuleConfig.totalSnowflakes || 50; // Fallback if config is not loaded
              // Snowflake variants
              const snowflakeVariants = ["❄", "❅", "❆"];
              for (let i = 0; i < totalSnowflakes; i++) {
                      const snowflake = document.createElement("span");
                      snowflake.classList.add("snowflake");
                      // Randomly pick a snowflake variant
                      const variantIndex = Math.floor(Math.random() * snowflakeVariants.length);
                      snowflake.innerHTML = snowflakeVariants[variantIndex];
                      // Randomize size, position, and animation duration
                      const size = Math.random() * 0.8 + 0.2; // Size between 0.2 and 1
                      const left = Math.random() * 100; // Random horizontal position
                      const duration = Math.random() * 5 + 5; // Duration between 5s and 10s
                      const blur = Math.random() < 0.3 ? "blur(1px)" : "none";
                      snowflake.style.fontSize = `${size}em`;
                      snowflake.style.left = `${left}vw`;
                      snowflake.style.animationDuration = `${duration}s`;
                      snowflake.style.filter = blur;
                      snowflake.style.setProperty("--start-x", `${Math.random() * 10 - 5}vw`);
                      snowflake.style.setProperty("--end-x", `${Math.random() * 10 - 5}vw`);
                      // Append to the container
                      snowContainer.appendChild(snowflake);
      MMM-Snowflakes.css
      .initial-snow {
              position: absolute;
              top: 0;
              left: 0;
              width: 100%;
              height: 100%;
              overflow: hidden;
              z-index: 1;
      .snowflake {
              position: absolute;
              top: -5vh;
              color: white;
              animation: snowfall linear infinite;
              transform: translate3d(var(--start-x), 0, 0);
      /* Keyframes for snowfall animation */
      @keyframes snowfall {
              0% {
              100% {
                      transform: translate3d(var(--end-x), 110vh, 0);
      config.js
                          module: "MMM-Snowflakes",
                          position: "fullscreen_above",
                              totalSnowflakes: 50
      S 1 Reply Last reply Reply Quote 2
        sdetweil @xTITUS MAXIMUSx
        @xTITUS-MAXIMUSx said in Help with Snow Falling Module:
        document.addEventListener(“DOMContentLoaded”, () => {
        that doesn’t happen for MM modules. they are all JS… script tags in the index.html
        that event DOES happen for the index.html… but your module is not activated yet
        you can use the notification, MODULE_DOM_CREATED
        notificationReceived(notification, payload, sender) {
           if(notification=='MODULE_DOM_CREATED'){
        from https://docs.magicmirror.builders/development/notifications.html
          @xTITUS-MAXIMUSx
          AND if it happened, you module content is not present at that time
          so this will fail
          const snowContainer = document.querySelector(“.initial-snow”);
          you can debug this by using the developer window sources tab, and put a breakpoint on the code and step thru it…
          X 1 Reply Last reply Reply Quote 0
          • X Offline
            xTITUS MAXIMUSx @sdetweil
            @sdetweil Thank you for the reply and I really appreciate your help with this. To be honest I had some help with chatGPT as I don’t quite understand JS very well. Can you explain more about what I need to do exactly for this to work? Do I need to take the snowflake.js contents and place them in the MMM-Snowflake.js when it is being registered and use the notificationReceived function? Again, thanks for the help.
              @xTITUS-MAXIMUSx yes, you would move the script to the module.js
              and then put the function after the notification
              one thing tho… this is only happening once… I think… , no… it repeats… cool (edited)
              there are snow modules already (don’t mean to bust your bubble)
              see the 3rd party list above and enter snow in the search box
              • X Offline
                xTITUS MAXIMUSx
                NVM I figured it out. Here is what I needed to do. I had to really think about what you were saying. thanks for pointing me in the right direction. I will post this on github for everyone to use.
                    defaults: {
                        totalSnowflakes: 50 // Default number of snowflakes
                    // Start the module
                    // Called when MagicMirror DOM is created
                    notificationReceived: function(notification, payload, sender) {
                        if (notification === 'MODULE_DOM_CREATED') {
                            this.createSnowflakes();
                    // Create snowflakes in the DOM
                    createSnowflakes: function () {
                        if (!snowContainer) {
                            Log.error("Snowflakes: Container not found!");
                            return;
                        const totalSnowflakes = this.config.totalSnowflakes; // Get from config
                        const snowflakeVariants = ["&#10052;", "&#10053;", "&#10054;"]; // Snowflake symbols
                            // Append snowflake to the container
                    // Generate DOM for this module
                    getDom: function() {
                        wrapper.className = "initial-snow"; // Container for snowflakes
                        return wrapper;
                    // Load CSS for the module
                    getStyles: function() {
                  @xTITUS-MAXIMUSx awesome!!
