    MMM-Openhab header color
    8 Posts 2 Posters 945 Views 2 Watching
    • C Offline
      clakkentt
      Re: MMM-Openhab
      Has anyone been able to change the color of the sitemap title that MMM-Openhab displays in the magicmirror?
      I tried changing the color in the header section of the MMM-Style.css file in the Openhab/HTML/css folder but no luck
      /* =================================== HEADER FARBE */
       .mdl-layout__header {
        background-color: #000000 !important;
        color: #f4f00c !important;
      I also tried editing the magicmirror custom.css file adding
      .MMM-Openhab header{
      color: #f4f00c
      But again no change
      Thank you
        sdetweil @clakkentt
        @clakkentt if you use the browser developer window elements tab you can see and change the styles
        see the second link in my signature below
        its .module_header
        • C Offline
          clakkentt @sdetweil
          Thanks, I already tried that, the MMM-Openhab module is (or at least it seems to me) based on an i-frame. There is no header or anything configurable in MM
          That is why my first attempt was to modify the css file (MMM-Style.css) that MMM-Openhab uses inside Openhab to render the page.
            sdetweil @clakkentt
            @clakkentt yah, iframe is untouchable
            C 3 Replies Last reply Reply Quote 0
            • C Offline
              clakkentt @sdetweil
              But the i-frame properties must come from somewhere, the title in the i-frame is red
              This is the css file that is referenced
                color: red !important;
              .mdl-layout {
              /* =================================== HINTERGRUND FARBE  */
              /*  HINTERGRUND STEUERELEMENTE */
              .page-content {
              /*  HINTERGRUND Links/Rechts Wrapper */
              .mdl-color--grey-100 {
              /* =================================== STEUERELEMENTE LINE-HEIGHT */
              /* ZEILENHÖHE */
              html.ui-layout-condensed .mdl-form__row {
                  height: 45px;
              /* =================================== STEUERELEMENTE FARBE  */
              /* STEUERELEMENTE - HINTERGRUND FARBE  */
              .mdl-color--white {
              /* STEUERELEMENTE - TEXT FARBE  */
              .mdl-color-text--grey-700 {
              /* STEUERELEMENTE - Zwischenstriche Farbe */
              .mdl-form__row {
                  border-bottom: 1px solid #2d2d2d;
              .mdl-form__label {
                  color: #ffffff !important;
              .mdl-form__control {
              /* =================================== SWITCH FARBE OFF */
              /* SWITCH Button Farbe */
              .mdl-switch__thumb {
                background-color: #fff;
              /* SWITCH Button Track */
              .mdl-switch__track {
                  background: #9b4f4f;
              /* SWITCH Button Button-Farbe */
                background: #5b5757;
              /* =================================== SWITCH FARBE ON */
              .mdl-switch.is-checked .mdl-switch__thumb {
                  background: #d8d8d8;
              /* SWITCH Button Track-Farbe*/
              .mdl-switch.is-checked .mdl-switch__track {
                  background: #66d693;
              /* =================================== FRAME Rundungen */
              /* Fenster / Abschnitt Rundungen */
              .mdl-form {
                /*+border-radius: 10px;*/
                -moz-border-radius: 3px;
                -webkit-border-radius: 3px;
                -khtml-border-radius: 3px;
                border-radius: 3px;
              /* =================================== BUTTON FARBE - OFF */
              /* BUTTON SELECTED */
              BUTTON.mdl-button--accent {
                border: 1px solid #5ddd90;
                /*+box-shadow: 0px 0px !important;*/
                /*-moz-box-shadow: 0px 0px !important;
                -webkit-box-shadow: 0px 0px !important;
                background-color: #333 !important;
                color: #5ddd90 !important;
              /* =================================== BUTTON FARBE - ON */
              /* BUTTON DESELECTED */
              .mdl-form__setpoint BUTTON, .mdl-form__rollerblind BUTTON, .mdl-form__buttons BUTTON {
                color: white;
                background-color: #545454;
                /*+border-radius: 5px;*/
                -moz-border-radius: 2px;
                -webkit-border-radius: 2px;
                -khtml-border-radius: 2px;
                border-radius: 2px;
              /* =================================== BUTTON FARBE - HOVER */
              /* BUTTON HOVER FARBE */
              BUTTON.mdl-button:hover {
                background-color: #5ddd90;
              and this is the html file that Openhab uses
              • C Offline
                clakkentt @sdetweil
                It’s interesting. I changed the header color in the .css file and after a reboot it shows up correctly when I render the page from openhab
                However in MM the cog wheel and House Sensors still shows in red. So that color must be set somewhere in the MMM-Openhab config files
                I’ll take another look
                • C Offline
                  clakkentt @sdetweil
                  There is a css file in MM, but I still can’t figure out how to make it “work”
                  .MMM-Openhab {
                  	width: 400px;
                  	height: 700px;
                  	margin-right: 0px;
                  	margin-left: 0px;
                  	margin-top: 0px;
                  .MMM-Openhab .header {
                    color: red;               /* Header color. Default is red. */
                  .MMM-Openhab .ifr {
                   	width: 400px;
                  	height: 680px;
                  I changed the red to different colors both in hex and by their name and restarted MM but the header is still red.
                  Is there something, apart from restarting MM, that needs to be done to have the module accept the new color?
                    sdetweil @clakkentt
                    @clakkentt its called .module_header
                    use the developers window elements tab
