    Troubleshooting Positions
    13 Posts 2 Posters 2.0k Views 2 Watching
      roaminMirror
      I am very much a newbie at this. I have been attempting just to start with defaults. I have dug and dug through the configuration files and JS and I am missing something. When I attempt to NPM Run start I get an error message for every position listed in the defaultModules except for the position “fullscreen_below”. When I am running the test I get;
      [ERROR] This module configuration contains errors:
      “module”: “updatenotification”,
      “position”: “top_bar”
      position: must be equal to one of the allowed values
      “fullscreen_below”
      I am not able to change the array in the positions.js file as it’s updated by a config file. What am I missing? Any help with this would be great, as I am able to mess with the different modules to learn as I go as long as I am using that single position.
      These are the positions I am attempting to use but failing> [“top_bar”, “top_left”, “top_center”, “top_right”, “upper_third”, “middle_center”, “lower_third”, “bottom_left”, “bottom_center”, “bottom_right”, “bottom_bar”, “fullscreen_above”, “fullscreen_below”];
      All of which are defined by class in the CSS properly, as far as I can tell.
      S R 2 Replies Last reply Reply Quote 0
        sdetweil @roaminMirror
        @roaminMirror if you look at the messages from npm start you should see an error maybe
        one of the ideas was to make the positions extendable/customizable…
        currently you have to edit 5 files.
        SO, I added code to read the index.html file, which has the positions/regions used defined, in the server side where I can read a file
        BUT I need to pass that info to the browser side code that checks it…
        SO, I WRITE the list of positions to a file js/positions.js
        someone else reported that they got a permission denied on this write…
        (cause they had used sudo to install MM… oops)
        it also fails on synology nas drives under docker, if the storage is created by a synology user , and accessed from the docker user(1000)
        you can erase that file, js/positions.js
        and it will be recreated
        I added a new message to the next release about this permissions problem, instead of crashing
          roaminMirror @roaminMirror
          @roaminMirror Thank you for your reply. What are the 5 files that I will need to edit to have the positions be recoginized and allowed in the positions.js file? I found that editing it manually it will, as you mentioned, recreate itself in the original manner. I am assuming it is gathering it’s array from another location butI am not sure what file is creating that positions.js file with this const modulePositions=[“fullscreen_below”]e with the array .
          The only position that is working is Fullscreen_Below for some reason. Sorry I am just not understanding.
            @roaminMirror can you show me ~/MagicMirror/index.html
            that is the file i read for the regions
            it should not be changed unless you ate adding new regions
            also post the contents of ~/MagicMirror/js/positions.js
              @roaminMirror see the doc on module position
              see the note
                roaminMirror @sdetweil
                I haven’t made any changes to the index.html file. The config.js is unchanged as well as the positions.js file.
                <!doctype html>
                <html>
                  <head>
                    <title>MagicMirror²</title>
                    <meta name="google" content="notranslate" />
                    <meta http-equiv="Content-type" content="text/html; charset=utf-8" />
                    <meta name="apple-mobile-web-app-capable" content="yes" />
                    <meta name="apple-mobile-web-app-status-bar-style" content="black" />
                    <meta name="format-detection" content="telephone=no" />
                    <meta name="mobile-web-app-capable" content="yes" />
                    <link rel="icon" href="data:;base64,iVBORw0KGgo=" />
                    <link rel="stylesheet" type="text/css" href="css/main.css" />
                    <link rel="stylesheet" type="text/css" href="fonts/roboto.css" />
                    <link rel="stylesheet" type="text/css" href="vendor/node_modules/animate.css/animate.min.css" />
                    <!-- custom.css is loaded by the loader.js to make sure it's loaded after the module css files. -->
                    <script type="text/javascript">
                      window.mmVersion = "#VERSION#";
                    </script>
                  </head>
                  <body>
                    <div class="region fullscreen below"><div class="container"></div></div>
                    <div class="region top bar">
                      <div class="top_bar"><div class="container"></div></div>
                      <div class="region top center"><div class="container"><clock /></div></div>
                      <div class="region top right"><div class="container"></div></div>
                    </div>
                    <div class="region upper third"><div class="container"></div></div>
                    <div class="region middle center"><div class="container"></div></div>
                    <div class="region lower third">
                      <div class="container"><br /></div>
                    </div>
                    <div class="region bottom bar">
                      <div class="region bottom left"><div class="container"></div></div>
                      <div class="region bottom center"><div class="container"></div></div>
                      <div class="region bottom right"><div class="container"></div></div>
                    </div>
                    <div class="region fullscreen above"><div class="container"></div></div>
                    <script type="text/javascript" src="socket.io/socket.io.js"></script>
                    <script type="text/javascript" src="vendor/node_modules/nunjucks/browser/nunjucks.min.js"></script>
                    <script type="text/javascript" src="js/defaults.js"></script>
                    <script type="text/javascript" src="#CONFIG_FILE#"></script>
                    <script type="text/javascript" src="vendor/vendor.js"></script>
                    <script type="text/javascript" src="modules/default/defaultmodules.js"></script>
                    <script type="text/javascript" src="modules/default/utils.js"></script>
                    <script type="text/javascript" src="js/logger.js"></script>
                    <script type="text/javascript" src="translations/translations.js"></script>
                    <script type="text/javascript" src="js/translator.js"></script>
                    <script type="text/javascript" src="js/class.js"></script>
                    <script type="text/javascript" src="js/module.js"></script>
                    <script type="text/javascript" src="js/loader.js"></script>
                    <script type="text/javascript" src="js/socketclient.js"></script>
                    <script type="text/javascript" src="js/animateCSS.js"></script>
                    <script type="text/javascript" src="js/positions.js"></script>
                    <script type="text/javascript" src="js/main.js"></script>
                  </body>
                </html>
                ![positions.png](/assets/uploads/files/1735328208567-positions.png)
                  @roaminMirror cant attach files, only their text as a paste
                    @roaminMirror are you running on Windows?
                      Yes I am running on windows for the time being until I am ready to move it to a RPI.
                      The positions.js file is
                      const modulePositions=["fullscreen_below"]
                      If I attempt to change it and then start the server with npm run start it will revert back to the above code.
                        @roaminMirror interesting… I don’t see this problem on windows…
                        anyhow
                        edit js/utils.js
                        at the end is the function
                        getModulePositions () {
                        		// if not already discovered
                        		if (modulePositions.length === 0) {
                        			// get the lines of the index.html
                        			const lines = fs.readFileSync(indexFileName).toString().split(os.EOL);
                        change that last line to
                                               const lines = fs.readFileSync(indexFileName).toString().split('\n');
                          @roaminMirror I was able to recreate this on windows…
                          opened issue #3662 and submitted fix #3663
                          change to ‘\n’ as I proposed
                            roaminMirror
                            That was what was needed! Thank you for helping out with that!
                            • R roaminMirror has marked this topic as solved on
                              @roaminMirror great… fixed in next release (Wednesday)
