    MMM-CalendarExt3Agenda - how to hide days with no events and hide/filter out events with a keywords
    22 Posts 4 Posters 6.2k Views 4 Watching
    • G Offline
      GrandizerGo
      I’m finally getting back into trying get MM all configured.
      I would like to be able to filter out empty days in the Agenda so it doesn’t list the date if there are no events. I’m also looking to exclude events by keyword. For example, don’t list events with “Swimming”.
      I’ve attached a pic of my current view if that helps. Thanks for any guidance you can provide.
        sdetweil @GrandizerGo
        @GrandizerGo i think on the second you can use the filter
        if the filter routine returns true the event is kept
        dont know of remove days
        • G Offline
          GrandizerGo @sdetweil
          @sdetweil Thanks, the eventFilter did the trick to help hide repeated events.
          Anyone know if it’s possible to filter out dates that have no entries hidden after the filter is applied?
            @MMRIZE will have to answer that
            i know there is the function to handle all events
            but that doesn’t help if there no events for a date
              MMRIZE @GrandizerGo
              @GrandizerGo
              To filter out the empty days
              There could be 2 ways of approaches for your exact purpose. The each ways are different, so choose one.
              1.
              /* CX3A config section of config/config.js */
              onlyEventDays: 5, // This will show 5 specific days which has at least one event on the day.
              2.
              Or you can hide empty days in the calendar scope with CSS.
              /* css/custom.css */
              .CX3A .agenda .cell[data-events-counts="0"] {
                display: none;
                sdetweil @MMRIZE
                @MMRIZE cool on the css approach
                • G Offline
                  @MMRIZE Thanks! On the config.js method it worked right away! I set to 10 days and it works nicely.
                  With the custom.css method it seems to only show about 4 events.
                    rkorell Module Developer
                    Dear gurus,
                    I’m pretty new here and i do have the exact same problem as the original thread owner.
                    I’ve identified and tried the conig.cs approach with “onlyEventDays: 5,” but this doesn’t work for me unfortunately.
                    In addition other documented switches of this module
                    // useWeather: false ,
                    // showMiniMonthCalendar: false,
                    don’t work either for me.
                    Any idea?
                    Because of the other two switches I don’t want to play with CSS right now…
                    Thanks for any hint/advise!
                    Warmest regards,
                    Ralf
                      sdetweil @rkorell
                      @rkorell can you show your ext3 config please
                        Dear @sdetweil ,
                        yes for sure, sorry…
                        It’s VERY basic, because my trials were ignored I doesn’t spent too much time on it yet…
                        As you can see I’ve disabled the not working parts (currently except the asked one - “onlyEventDays”.
                        // Kalenderübersicht (Agendaview)
                        		  module: "MMM-CalendarExt3Agenda",
                        		  header: "Wichtige Termine",
                        		  onlyEventDays: 1
                        Thanks for your prompt reply - I was tired yesterday night, so seen your query rigth now.
                        Warmest regards,
                        Ralf
                          sdetweil @rkorell
                          @rkorell ok, the problem is the config description
                          according to the documentation, all of these config items belong to MagicMirror
                          https://docs.magicmirror.builders/modules/configuration.html#module-configuration
                          everything INSIDE the config:{} section belongs to the module
                          but you don’t have a config section, should look like this
                                                 onlyEventDays: 1
                            .Dear Sam, @sdetweil ,
                            shame on me!
                            This is dumb.
                            thanks a lot for this hint.
                            If you are doing it right - it works …
                            I’m terribly embarrassed.
                            Regards,
                            Ralf
                              sdetweil @rkorell
                              @rkorell we all learn new things every day…
                                @sdetweil , yes indeed.
                                After making a little bit of progress now I’m not able to understand why the module doosn’t do what I expect…
                                I try to change the icons as well as the color of the calendar events.
                                Icon works fine, color for icon as well but the “event” itself doesn’t change color.
                                I’ve figured out that the searchword is found - because it triggers the icon color as well as the icon color (regardless that the current searchword contains an German “Umlaut” (‘ü’).
                                I found a code snippet here and modified it to my requirements.
                                ev.color is the attribute I’ve used - this seems the right one.
                                But It only changes the icon color…
                                		  //header: "Wichtige Termine",
                                			        eventTransformer: (ev) => {
                                			            const customEvents = [
                                			              { keyword: "Gelber Sack", symbol: ["fa-solid fa-arrows-spin"], color: "yellow" },
                                			              { keyword: "Restmüll", symbol: ["fa-regular fa-trash-can"], color: "green" },
                                			              { keyword: "Biomüll", symbol: ["fa-regular fa-trash-can"], color: "brown" },
                                			              { keyword: "Papier", symbol: ["fa-solid fa-dumbbell"], color: "blue" },
                                			              { keyword: "Urlaub", symbol: ["fa-solid fa-dumbbell"], color: "cyan" },
                                			            const found = customEvents.find((condition) => {
                                			              return ev.title.search(condition.keyword) !== -1
                                			            if (found) {
                                			                ev.icon = [ found.symbol ]
                                			                ev.color = found.color
                                			            if (ev.title.search('Restmüll') !== -1) {
                                			              ev.symbol = [ "fa-solid fa-cake-candles" ]
                                			            if (ev.title.search('Papier') !== -1) {
                                			              ev.symbol = [ "fa-regular fa-trash-can" ]
                                			            if (ev.title.search('Gelber Sack') !== -1) {
                                			              ev.symbol = [ "fa-solid fa-arrows-spin" ]
                                			            if (ev.title.search('Biomüll') !== -1) {
                                			            if (ev.title.search('Geb.') !== -1) {
                                			              ev.title = ev.title.replace('Geb.', '')
                                			            return ev
                                					//onlyEventDays: 10  -- Nur Tage mit terminen anzeigen ist in der custom.css eingetragen, DAS funktioniert...
                                Where is my error now?
                                TIA for any hint.
                                Regards,
                                Ralf
                                  sdetweil @rkorell
                                  @rkorell sorry, don’t know… not my module… @MMRIZE will have to reply
                                    @sdetweil , thanks anyway!
                                    should I place a separate posting?
                                    Regards,
                                    Ralf
                                      sdetweil @rkorell
                                      @rkorell no, my reference of his userid will send him here when he has time. just understand that this is all volunteer, as time is available, no commitment for support.
                                      maybe others will jump in.
                                        @sdetweil , yes, I’m fully aware of volunteer.
                                        So thanks a LOT!
                                        Ralf
                                          rkorell Module Developer @rkorell
                                          Dear Sam (@sdetweil ),
                                          short feedbacj from this end :-)
                                          I was able to found a compromize.
                                          I’ve found a months old thread with the guy whose mirror I saw and @MMRIZE regardins an equivalent “problem”.
                                          The mentioned CSS solution doesn’t work for me - for whatever reason
                                          /* In your custom.css */
                                          .CX3 .event.singleday .headline .title,
                                          .CX3 .event.singleday .headline .time {
                                            color: var(--calendarColor);
                                          Doesn’t colour the textline.
                                          But in the same discoussion I identified the “idea” to use the fact that whole day events DO use the given color as I define in my config.
                                          So now the apperance isO.K.
                                          For reference to others who might have same issues the whole block here:
                                          			              { keyword: "Restmüll", symbol: ["fa-regular fa-trash-can"], color: "grey" },
                                          			              { keyword: "Restmüll & Papier & Gelber Sack", symbol: ["fa-regular fa-trash-can"], color: "fuchsia" },
                                          			            if (found) {
                                          			            if (ev.title.search("Restmüll") !== -1) {
                                          			              ev.symbol = [ "fa-regular fa-trash-can" ],
                                          			              ev.isFullday = [true],
                                          			              ev.color = "grey"
                                          			            if (ev.title.search("Papier") !== -1) {
                                          			              ev.color = "blue"
                                          			            if (ev.title.search("Gelber Sack") !== -1) {
                                          			              ev.symbol = [ "fa-solid fa-arrows-spin" ],
                                          			              ev.color = "yellow"
                                          			            if (ev.title.search("Biomüll") !== -1) {
                                          			              ev.color = "brown"
                                          						if (ev.title.search("Restmüll & Papier & Gelber Sack") !== -1) {
                                          			              ev.title = "Alle Tonnen",
                                          			              ev.color = "fuchsia"
                                          						if (ev.title.search("Urlaub") !== -1) {
                                          			              ev.color = "green"
                                          			            return ev
                                          Thanks for your support!
                                          Warmest regards,
                                          Ralf
                                            sdetweil @rkorell
                                            @rkorell glad you have it working
