    MMM-CalendarExt3Agenda - how to hide days with no events and hide/filter out events with a keywords
    22 Posts 4 Posters 4.9k Views 4 Watching
    • G Offline
      GrandizerGo @sdetweil
      @sdetweil Thanks, the eventFilter did the trick to help hide repeated events.
      Anyone know if it’s possible to filter out dates that have no entries hidden after the filter is applied?
        sdetweil @GrandizerGo
        @MMRIZE will have to answer that
        i know there is the function to handle all events
        but that doesn’t help if there no events for a date
          MMRIZE @GrandizerGo
          @GrandizerGo
          To filter out the empty days
          There could be 2 ways of approaches for your exact purpose. The each ways are different, so choose one.
          1.
          /* CX3A config section of config/config.js */
          onlyEventDays: 5, // This will show 5 specific days which has at least one event on the day.
          2.
          Or you can hide empty days in the calendar scope with CSS.
          /* css/custom.css */
          .CX3A .agenda .cell[data-events-counts="0"] {
            display: none;
            sdetweil @MMRIZE
            @MMRIZE cool on the css approach
            • G Offline
              @MMRIZE Thanks! On the config.js method it worked right away! I set to 10 days and it works nicely.
              With the custom.css method it seems to only show about 4 events.
                rkorell
                Dear gurus,
                I’m pretty new here and i do have the exact same problem as the original thread owner.
                I’ve identified and tried the conig.cs approach with “onlyEventDays: 5,” but this doesn’t work for me unfortunately.
                In addition other documented switches of this module
                // useWeather: false ,
                // showMiniMonthCalendar: false,
                don’t work either for me.
                Any idea?
                Because of the other two switches I don’t want to play with CSS right now…
                Thanks for any hint/advise!
                Warmest regards,
                Ralf
                  sdetweil @rkorell
                  @rkorell can you show your ext3 config please
                    rkorell @sdetweil
                    Dear @sdetweil ,
                    yes for sure, sorry…
                    It’s VERY basic, because my trials were ignored I doesn’t spent too much time on it yet…
                    As you can see I’ve disabled the not working parts (currently except the asked one - “onlyEventDays”.
                    // Kalenderübersicht (Agendaview)
                    		  module: "MMM-CalendarExt3Agenda",
                    		  header: "Wichtige Termine",
                    		  onlyEventDays: 1
                    Thanks for your prompt reply - I was tired yesterday night, so seen your query rigth now.
                    Warmest regards,
                    Ralf
                      sdetweil @rkorell
                      @rkorell ok, the problem is the config description
                      according to the documentation, all of these config items belong to MagicMirror
                      https://docs.magicmirror.builders/modules/configuration.html#module-configuration
                      everything INSIDE the config:{} section belongs to the module
                      but you don’t have a config section, should look like this
                                             onlyEventDays: 1
                        rkorell @sdetweil
                        .Dear Sam, @sdetweil ,
                        shame on me!
                        This is dumb.
                        thanks a lot for this hint.
                        If you are doing it right - it works …
                        I’m terribly embarrassed.
                        Regards,
                        Ralf
