    MMM-CalendarExt3Agenda - how to hide days with no events and hide/filter out events with a keywords
    22 Posts 4 Posters 6.8k Views 4 Watching
      Dear @sdetweil ,
      yes for sure, sorry…
      It’s VERY basic, because my trials were ignored I doesn’t spent too much time on it yet…
      As you can see I’ve disabled the not working parts (currently except the asked one - “onlyEventDays”.
      // Kalenderübersicht (Agendaview)
      		  module: "MMM-CalendarExt3Agenda",
      		  header: "Wichtige Termine",
      		  // useWeather: false ,
      		  // showMiniMonthCalendar: false,
      		  onlyEventDays: 1
      Thanks for your prompt reply - I was tired yesterday night, so seen your query rigth now.
      Warmest regards,
      Ralf
        sdetweil @rkorell
        @rkorell ok, the problem is the config description
        according to the documentation, all of these config items belong to MagicMirror
        https://docs.magicmirror.builders/modules/configuration.html#module-configuration
        everything INSIDE the config:{} section belongs to the module
        but you don’t have a config section, should look like this
                               onlyEventDays: 1
        R 1 Reply Last reply
          .Dear Sam, @sdetweil ,
          shame on me!
          This is dumb.
          thanks a lot for this hint.
          If you are doing it right - it works …
          I’m terribly embarrassed.
          Regards,
          Ralf
            sdetweil @rkorell
            @rkorell we all learn new things every day…
              @sdetweil , yes indeed.
              After making a little bit of progress now I’m not able to understand why the module doosn’t do what I expect…
              I try to change the icons as well as the color of the calendar events.
              Icon works fine, color for icon as well but the “event” itself doesn’t change color.
              I’ve figured out that the searchword is found - because it triggers the icon color as well as the icon color (regardless that the current searchword contains an German “Umlaut” (‘ü’).
              I found a code snippet here and modified it to my requirements.
              ev.color is the attribute I’ve used - this seems the right one.
              But It only changes the icon color…
              		  //header: "Wichtige Termine",
              			        eventTransformer: (ev) => {
              			            const customEvents = [
              			              { keyword: "Gelber Sack", symbol: ["fa-solid fa-arrows-spin"], color: "yellow" },
              			              { keyword: "Restmüll", symbol: ["fa-regular fa-trash-can"], color: "green" },
              			              { keyword: "Biomüll", symbol: ["fa-regular fa-trash-can"], color: "brown" },
              			              { keyword: "Papier", symbol: ["fa-solid fa-dumbbell"], color: "blue" },
              			              { keyword: "Urlaub", symbol: ["fa-solid fa-dumbbell"], color: "cyan" },
              			            const found = customEvents.find((condition) => {
              			              return ev.title.search(condition.keyword) !== -1
              			            if (found) {
              			                ev.icon = [ found.symbol ]
              			                ev.color = found.color
              			            if (ev.title.search('Restmüll') !== -1) {
              			              ev.symbol = [ "fa-solid fa-cake-candles" ]
              			            if (ev.title.search('Papier') !== -1) {
              			              ev.symbol = [ "fa-regular fa-trash-can" ]
              			            if (ev.title.search('Gelber Sack') !== -1) {
              			              ev.symbol = [ "fa-solid fa-arrows-spin" ]
              			            if (ev.title.search('Biomüll') !== -1) {
              			            if (ev.title.search('Geb.') !== -1) {
              			              ev.title = ev.title.replace('Geb.', '')
              			            return ev
              					//onlyEventDays: 10  -- Nur Tage mit terminen anzeigen ist in der custom.css eingetragen, DAS funktioniert...
              Where is my error now?
              TIA for any hint.
              Regards,
              Ralf
                sdetweil @rkorell
                @rkorell sorry, don’t know… not my module… @MMRIZE will have to reply
                  @sdetweil , thanks anyway!
                  should I place a separate posting?
                  Regards,
                  Ralf
                    sdetweil @rkorell
                    @rkorell no, my reference of his userid will send him here when he has time. just understand that this is all volunteer, as time is available, no commitment for support.
                    maybe others will jump in.
                      @sdetweil , yes, I’m fully aware of volunteer.
                      So thanks a LOT!
                      Ralf
                        rkorell Module Developer @rkorell
                        Dear Sam (@sdetweil ),
                        short feedbacj from this end :-)
                        I was able to found a compromize.
                        I’ve found a months old thread with the guy whose mirror I saw and @MMRIZE regardins an equivalent “problem”.
                        The mentioned CSS solution doesn’t work for me - for whatever reason
                        /* In your custom.css */
                        .CX3 .event.singleday .headline .title,
                        .CX3 .event.singleday .headline .time {
                          color: var(--calendarColor);
                        Doesn’t colour the textline.
                        But in the same discoussion I identified the “idea” to use the fact that whole day events DO use the given color as I define in my config.
                        So now the apperance isO.K.
                        For reference to others who might have same issues the whole block here:
                        			              { keyword: "Restmüll", symbol: ["fa-regular fa-trash-can"], color: "grey" },
                        			              { keyword: "Restmüll & Papier & Gelber Sack", symbol: ["fa-regular fa-trash-can"], color: "fuchsia" },
                        			            if (found) {
                        			            if (ev.title.search("Restmüll") !== -1) {
                        			              ev.symbol = [ "fa-regular fa-trash-can" ],
                        			              ev.isFullday = [true],
                        			              ev.color = "grey"
                        			            if (ev.title.search("Papier") !== -1) {
                        			              ev.color = "blue"
                        			            if (ev.title.search("Gelber Sack") !== -1) {
                        			              ev.symbol = [ "fa-solid fa-arrows-spin" ],
                        			              ev.color = "yellow"
                        			            if (ev.title.search("Biomüll") !== -1) {
                        			              ev.color = "brown"
                        						if (ev.title.search("Restmüll & Papier & Gelber Sack") !== -1) {
                        			              ev.title = "Alle Tonnen",
                        			              ev.color = "fuchsia"
                        						if (ev.title.search("Urlaub") !== -1) {
                        			              ev.color = "green"
                        			            return ev
                        Thanks for your support!
                        Warmest regards,
                        Ralf
                        S M 2 Replies Last reply
                          sdetweil @rkorell
                          @rkorell glad you have it working
                            MMRIZE @rkorell
                            @rkorell
                            CX3A is identified with CSS selector “.CX3A” to be distinguished from CX3.
                              rkorell Module Developer @MMRIZE
                              @MMRIZE , thanks - I was aware of this.
                              Regards,
                              Ralf
