    Getting LED Strip on in conjunction with MMM-Pir
    16 Posts 2 Posters 2.5k Views 2 Watching
      sdetweil @rkorell
      @rkorell yeh, sorry, didn’t give this enough viewing/thinking time…
      the fires section doesn’t support code, its all literals.
      I don’t know if you can attach a function (which returns the literal) to it
           fires: ()=>{  if (this.config.ScreenStatus == 'on')
                                           return "BROADCAST";
                                     else return "?????"
        rkorell @sdetweil
        @sdetweil Yes, sounds like a brillant idea.
        But if I assign a value to this.config.ScreenStatus within the trigerPayloadFilter section the fire section isn’t working - so your thought is great but I cannot try this …
        Any idea why the fire section is skipped?
        THANKS for your effort!!
        Ralf
          sdetweil @rkorell
          @rkorell well, skipped…
          because the code it looking for a literal, and the function is not…
          the NotificationsTrigger module will have to be changed
            rkorell @sdetweil
            @sdetweil O.K.,
            if I have to change modules, I can do this at the “root” - which is the MMM-Pir …
            I will at least have a closer look to the MMM-Notification module - maybe a good starting point to develop a completely new (forked) module…
            Thanks for your engagement anyway!
            Warm regards,
            Ralf
              sdetweil @rkorell
              @rkorell ok, its a tiny change to Trigger module…
                rkorell @sdetweil
                @sdetweil from your perspective :-)
                Just had a deeper look into code and I didn’t understand that much…
