    MMM-Temp2IOT
    5 Posts 2 Posters 1.4k Views 2 Watching
    • C
      chrisfr1976
      I have created a quick module to visualize outside temperatures from the Temp2IOT Sensor:
      MMM-Temp2IOT
      Screenshot MMM-Temp2IOT
      Get your own Sensor: Temp2IOT
      -1 iFrame on my mirror :)
      Regards, Chris.
      R 2 Replies Last reply
      Reply Quote 1
      • R
        rkorell Module Developer @chrisfr1976
        @chrisfr1976 cool stuff - I like it and it works without any problem.
        Do you have a hint for me how I can disable the icons?
        The text is sufficient for me.
        I’ve tried a condition which never will be met: “condition > 100” but this doesn’t work.
        Good work - especially the code for the ESP board, thanks a LOT!
        Additional question: the api is posting a json record with Unix Startdate (“Thu Jan 1 00:00:00 1970”)?
        Is this correct?
          "systemname": "tbd",
          "secure_counter": 0,
          "firmware": "2.3.06-b",
          "sensors": [
              "name": "Sonne",
              "value": 0,
              "mean-1": {
                "value": "NaN",
                "count": 0,
                "period": 3600
              "mean-24": {
                "value": "NaN",
                "count": 0,
                "period": 86400
              "unit": "Celsius",
              "time": "Thu Jan  1 00:00:00 1970"
              "name": "Schatten",
              "value": 0,
              "unit": "Celsius",
        Warmest regards,
        Ralf
        C 1 Reply Last reply
        • R
          @chrisfr1976
          have solved it by myself…
          Used @sdetweil 's tip with developer console and identified CSS classes for the icons.
          Have set
          .MMM-Temp2IOT .iconify {
              font-size: 0px; /* Symbole verschwinden lassen */
          in custom.css -
          works :-)
          Warm regards,
          Ralf
          Reply Quote 2
          • C
            chrisfr1976 @rkorell
            @rkorell
            my api has the correct time:
              "systemname": "Temp2IoT",
              "secure_counter": 469,
              "sensors": [
                  "name": "Draußen ",
                  "value": -0.1875,
                  "mean-1": {
                    "value": "NaN",
                    "count": 0,
                    "period": 3600
                  "mean-24": {
                    "value": "NaN",
                    "count": 0,
                    "period": 86400
                  "unit": "Celsius",
                  "time": "Fri Feb 14 21:26:53 2025"
                  "name": "Schuppen",
                  "value": 2.0625,
                  "unit": "Celsius",
            But if the temperature is okay it doesn‘t matter for the module.
            The Temp2IOT project is not mine. But it is really great work.
            Regards, Chris.
            R 1 Reply Last reply
            • R
              @chrisfr1976 said in MMM-Temp2IOT:
              OK, thought i was you :-) .
              I’ve found the root-cause for wrong date:
              Yesterday I’ve played primarily with the mirror-module to test if this works for me (yes, it works…).
              Today I’ve done the soldering part and connected the sensors.
              Now sensor data is transmitted and this seems to trigger attachment of time-marks.
              Now the json record contains correct timestamp.
              Regards,
              Ralf
