MMM-pages - how to know which page index my module has?
@sdetweil said in MMM-pages - how to know which page index my module has?:
git clone https://github.com/sdetweil/MMM-MPlayer
Did as you suggested
The video appears only on page index 0 and not on the hidden page
See the 2 video images on the attached screenshot - both are over the weather module
The header for the MPlayer appears on the hidden page
I can change to the hidden page with Remote Control, no problem
{ module: "MMM-pages", config: { rotationTime: 1000 * 86400, // rotate every 20 seconds modules: [ ["page1"], // class name for page 1 // ["page2"], // class name for page 2 // ["page3"], // class name for page 3 ], fixed: ["fixed_page"], hiddenPages: { "Doorbell": ["doorbell_page"], } } }, { module: 'MMM-MPlayer', classes: "doorbell_page", disabled: false, position: "top_left", header: "MPlayer", config: { useTwoWindows: true, layout: 'column', monitorAspect: 0, rotate: -1, windowSize: { width: 640, height: 360 }, windowPosition: { x: 5, y: 225 }, streamInterval: 30000, streams: { window1: [ 'rtsp://10.0.1.1:7447/gv9eHrB9yZyPhgvN', ], window2: [ 'rtsp://10.0.1.1:7447/D89zTJyDwN8YtKix', ] } } },
@evroom said in MMM-pages - how to know which page index my module has?:
As a workaround, I will make it a requirement to put the MMM-Player on the first page (page index 0).
When I receive 0, then I will start streaming, otherwise I will stop streaming.
That seems to work.@sdetweil Maybe something to do with this?
@mvrlogins no. i added code to start streaming on hidden page,
let me check again.you have my fork, right?
Yes, using your fork
@mvrlogins ok, git pull in module folder…
i didn’t stop the stream when switching away… or if there was another stream already running on page 0
Hi, I notice some requests and other activities,here and on GitHub.
Due to unforeseen medical issues, I do not have really time, nor the means to respond to everything
Already happy I have some sort of Internet connection here.
But with Sam it is in good hands, just make use of his fork.
Greetings, E.J. -
take care, this is not important in the grand scheme of things…
I spent 2 months in hospital with Covid in 2021, luckily laptop, wifi , and MagicMirror kept me sane.
Thanks for your help with this, Much appreciated
I’m now away from the mirror for the weekend. I’ll give it a shot when I return on Tuesday
