    MMM-SimplePIR
    3 Posts 2 Posters 980 Views 3 Watching
      myfingersarecold
      https://github.com/ryanjblajda/MMM-SimplePIR
      A simple PIR module that uses a PIR sensor with a digital output, and it utilizes gpio interrupts to check it. I liked the MMM-Pir module that once existed, but I didnt see an easy way to add a feature that physically turned off a monitor after a specified timeout, as well as blanking the screen. This utilizes the gpio outputs on the Pi to drive buttons intended for use with this RF controlled outlet (https://a.co/d/4hUItyW) [driven by some NPN transistors with current limiting resistors to prevent gpio damage].
      The module emits the following notification: MMM_PIR-SCREEN_POWERSTATUS, with a boolean payload of whether the display is on or off. this happens when the display is muted, or physically turned on/off
      If the module is visible, it will provide some basic debugging statistics
      An example config is shown below: [actually my exact config from my mirror]
          module: 'MMM-SimplePIR',
          //position: 'top_left',
          hidden: true,
          config:
              debug: true,            //enables debug printing
              blankScreenTimeout: 1,  //in minutes, when the screen will be blacked out.
              offScreenTimeout: 60,   //in minutes, when the screen will be physically turned off.
              pirSensorPin: 17,       //where the output of the PIR sensor should be connected
              displayOnPin: 23,       //connect this to either the on button on a display, or to the RF outlet controller [or whatever you want]
              displayOffPin: 24,      //connect this to either the off button on a display, or to the RF outlet controller [or whatever you want]
        sdetweil @myfingersarecold
        @myfingersarecold add to the 3rd party list
        you edit it
          myfingersarecold @sdetweil
          @sdetweil should be done already, figured i would add it here as well.
