    Standar "weather" Module: Doesn't keep header setting?
    14 Posts 2 Posters 1.6k Views 2 Watching
      rkorell @sdetweil
      module header not displayed?
      .weather_forecast  .module_header {
          display: none;
      sorry doesn’t work, either :-(
      I’ve even copied your phrase to avoid typos - nothing happens.
      Sounds feasible and plausible, but don’t do the job…
      Ive tried
      .weather  .module_header {
          display: none;
      Didn’t work, too…
      really strange…
      Thanks for any additional idea…
        rkorell @sdetweil
        @rkorell the debugging:true was my choice to provide info during execution cycle vs startup.
        It’s not relevant for other modules
        OK - Just a trial :-) - will delete, especially as no debug info is sent by module
        There is an option in weather, by default it will append the location(from the api data) to the header.
        You can turn that off
        appendLocationToHeader:false,
        This is an interesting addional hint, thanks.
        The REAL problem/question is: Why do the module override my settings?
        Reagrds,
        Ralf
          sdetweil @rkorell
          @rkorell weather is a complex mix of properties
          I’ve never seen anyone complain about headers.
          That property is the only one I know that manipulates the header
          Also, weather is all in browser, so any debug will be shown there unless you use MMM-Logging or some such to redirect them to the startup log
            rkorell @sdetweil
            @sdetweil OK, tanks anyway.
            It seems there is something special in my mirror.
            Not that magic but unfortunate…
