    Standar "weather" Module: Doesn't keep header setting?
    14 Posts 2 Posters 2.7k Views 2 Watching
      rkorell @rkorell
      Additional question as CSS rookie:
      I’ve tried to identify the object of the header.
      how can I address this correctly?
      Sorry, I’m not able to figure this out.
      My best guess is
      .weather_forecast .header {
        border-bottom-width: 0px;
        color: black;
        font-size: 0px;
      but this doesn’t work.
      How do I make this right?
      Thanks!
      Ralf
        sdetweil @rkorell
        @rkorell .module_header
          rkorell @sdetweil
          @sdetweil thanks.
          But this seems not to work.
          .weather_forecast .module_header {
            color: black;
            font-size: 0px;
          changes at least not, what I would like to happen: not visible regardless of content, so text color black and line below not visible, as well - line thickness (border-bottom-widht) 0 …
          What I’m doing wrong?
          Am I on the wrong properties?
          Thanks again,
          Ralf
            rkorell @rkorell
            No, setting both headers to a text doesn’t help.
            Any suggestion where THIS error comes from???
              sdetweil @rkorell
              @rkorell module header not displayed?
                  display: none;
              Before I was giving you the classname of the header element
                sdetweil @rkorell
                @rkorell the debugging:true was my choice to provide info during execution cycle vs startup.
                It’s not relevant for other modules
                There is an option in weather, by default it will append the location(from the api data) to the header.
                You can turn that off
                appendLocationToHeader:false,
                  rkorell @sdetweil
                      display: none;
                  sorry doesn’t work, either :-(
                  I’ve even copied your phrase to avoid typos - nothing happens.
                  Sounds feasible and plausible, but don’t do the job…
                  Ive tried
                  .weather  .module_header {
                      display: none;
                  Didn’t work, too…
                  really strange…
                  Thanks for any additional idea…
                    rkorell @sdetweil
                    OK - Just a trial :-) - will delete, especially as no debug info is sent by module
                    This is an interesting addional hint, thanks.
                    The REAL problem/question is: Why do the module override my settings?
                    Reagrds,
                    Ralf
                      sdetweil @rkorell
                      @rkorell weather is a complex mix of properties
                      I’ve never seen anyone complain about headers.
                      That property is the only one I know that manipulates the header
                      Also, weather is all in browser, so any debug will be shown there unless you use MMM-Logging or some such to redirect them to the startup log
                        rkorell @sdetweil
                        @sdetweil OK, tanks anyway.
                        It seems there is something special in my mirror.
                        Not that magic but unfortunate…
