    MM stopped working with Electron Error
    13 Posts 3 Posters 1.9k Views 3 Watching
    • W Offline
      wyovino
      Update: Restarting MM and rebooting had no affect. A shutdown and power disconnect fixed the issue, at least for now.
      S BKeyportB 2 Replies Last reply Reply Quote 0
        sdetweil @wyovino
        @wyovino sounds like memory corruption on the pi
        • BKeyportB Offline
          BKeyport Module Developer @wyovino
          @wyovino I suspect some heavy memory corruption - could be anywhere - I’d copy over your config.js and custom.css to another drive and try a new SD card if it continues.
          If it continues after that, I’d get a new device…
            sdetweil @BKeyport
            @BKeyport use my backup/restore to save the environment
            • BKeyportB Offline
              @sdetweil ooh, I forgot about that.
              • W Offline
                wyovino @sdetweil
                @sdetweil I’m in the process of re-imaging the USB drive from a backup. Hopefully that works. I don’t understand why it would work from a cold start but not a restart or reboot, but we’ll see what happens. It’s very consistent.
                  sdetweil @wyovino
                  @wyovino temperature related
                  W 1 Reply Last reply Reply Quote 1
                  • W Offline
                    wyovino @sdetweil
                    @sdetweil Good idea but I don’t think it’s the case with this. I monitor the temps of all of my Raspberry Pis. Anyway, I re-imaged the usb drive from a backup and it appears to be working. If I set it up to reboot automatically nightly, should I have it stop MM first or is that unnecessary?
                      sdetweil @wyovino
                      @wyovino shouldn’t need to, the os is ending . all processes will be stopped
