    MM stopped working with Electron Error
    13 Posts 3 Posters 3.0k Views 3 Watching
      sdetweil @wyovino
      @wyovino you can look at package.json for the requested version
      you can look at node_modules/electron/package.json
      for the installed version
      the error says the process was terminated
      • BKeyportB Offline
        @sdetweil isn’t SIGSEGV a segmentation fault?
          sdetweil @BKeyport
          @BKeyport you are right,
          • W Offline
            wyovino
            Update: Restarting MM and rebooting had no affect. A shutdown and power disconnect fixed the issue, at least for now.
              sdetweil @wyovino
              @wyovino sounds like memory corruption on the pi
              • BKeyportB Offline
                BKeyport Module Developer @wyovino
                @wyovino I suspect some heavy memory corruption - could be anywhere - I’d copy over your config.js and custom.css to another drive and try a new SD card if it continues.
                If it continues after that, I’d get a new device…
                  sdetweil @BKeyport
                  @BKeyport use my backup/restore to save the environment
                  https://github.com/sdetweil/MagicMirror-backup-restore
                  • BKeyportB Offline
                    @sdetweil ooh, I forgot about that.
                    • W Offline
                      wyovino @sdetweil
                      @sdetweil I’m in the process of re-imaging the USB drive from a backup. Hopefully that works. I don’t understand why it would work from a cold start but not a restart or reboot, but we’ll see what happens. It’s very consistent.
                        sdetweil @wyovino
                        @wyovino temperature related
                        W 1 Reply Last reply Reply Quote 1
                        • W Offline
                          wyovino @sdetweil
                          @sdetweil Good idea but I don’t think it’s the case with this. I monitor the temps of all of my Raspberry Pis. Anyway, I re-imaged the usb drive from a backup and it appears to be working. If I set it up to reboot automatically nightly, should I have it stop MM first or is that unnecessary?
                            sdetweil @wyovino
                            @wyovino shouldn’t need to, the os is ending . all processes will be stopped
