    MM stopped working with Electron Error
    13 Posts 3 Posters 2.2k Views 3 Watching
      sdetweil @BKeyport
      @BKeyport you are right,
      • W Offline
        wyovino
        Update: Restarting MM and rebooting had no affect. A shutdown and power disconnect fixed the issue, at least for now.
          sdetweil @wyovino
          @wyovino sounds like memory corruption on the pi
          • BKeyportB Offline
            BKeyport Module Developer @wyovino
            @wyovino I suspect some heavy memory corruption - could be anywhere - I’d copy over your config.js and custom.css to another drive and try a new SD card if it continues.
            If it continues after that, I’d get a new device…
              sdetweil @BKeyport
              @BKeyport use my backup/restore to save the environment
              https://github.com/sdetweil/MagicMirror-backup-restore
              • BKeyportB Offline
                @sdetweil ooh, I forgot about that.
                • W Offline
                  wyovino @sdetweil
                  @sdetweil I’m in the process of re-imaging the USB drive from a backup. Hopefully that works. I don’t understand why it would work from a cold start but not a restart or reboot, but we’ll see what happens. It’s very consistent.
                    sdetweil @wyovino
                    @wyovino temperature related
                    W 1 Reply Last reply Reply Quote 1
                    • W Offline
                      wyovino @sdetweil
                      @sdetweil Good idea but I don’t think it’s the case with this. I monitor the temps of all of my Raspberry Pis. Anyway, I re-imaged the usb drive from a backup and it appears to be working. If I set it up to reboot automatically nightly, should I have it stop MM first or is that unnecessary?
                        sdetweil @wyovino
                        @wyovino shouldn’t need to, the os is ending . all processes will be stopped
