    MM stopped working with Electron Error
    13 Posts 3 Posters 2.6k Views 3 Watching
    • W Offline
      wyovino
      MM V2.24.0, Pi Zero2W, Raspbian 10 (Buster)
      MM stopped working yesterday. The PM2 log is showing this error:
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      If I reinstall Electron, do I need a specific version? If so, how can I tell which version I currently have, and how would I do it?
      • W Offline
        wyovino
        Update: Restarting MM and rebooting had no affect. A shutdown and power disconnect fixed the issue, at least for now.
          sdetweil @wyovino
          @wyovino you can look at package.json for the requested version
          you can look at node_modules/electron/package.json
          for the installed version
          the error says the process was terminated
          • BKeyportB Online
            @sdetweil isn’t SIGSEGV a segmentation fault?
              sdetweil @BKeyport
              @BKeyport you are right,
              • W Offline
                wyovino
                  sdetweil @wyovino
                  @wyovino sounds like memory corruption on the pi
                  • BKeyportB Online
                    BKeyport Module Developer @wyovino
                    @wyovino I suspect some heavy memory corruption - could be anywhere - I’d copy over your config.js and custom.css to another drive and try a new SD card if it continues.
                    If it continues after that, I’d get a new device…
                      sdetweil @BKeyport
                      @BKeyport use my backup/restore to save the environment
                      https://github.com/sdetweil/MagicMirror-backup-restore
                      • BKeyportB Online
                        @sdetweil ooh, I forgot about that.
                        • W Offline
                          wyovino @sdetweil
                          @sdetweil I’m in the process of re-imaging the USB drive from a backup. Hopefully that works. I don’t understand why it would work from a cold start but not a restart or reboot, but we’ll see what happens. It’s very consistent.
                            sdetweil @wyovino
                            @wyovino temperature related
                            W 1 Reply Last reply Reply Quote 1
                            • W Offline
                              wyovino @sdetweil
                              @sdetweil Good idea but I don’t think it’s the case with this. I monitor the temps of all of my Raspberry Pis. Anyway, I re-imaged the usb drive from a backup and it appears to be working. If I set it up to reboot automatically nightly, should I have it stop MM first or is that unnecessary?
                                sdetweil @wyovino
                                @wyovino shouldn’t need to, the os is ending . all processes will be stopped
