    MagicMirrorOS build intermittently not starting mm container (Version 2.30)
    23 Posts 3 Posters 5.6k Views 3 Watching
      sdetweil @karsten13
      @karsten13
      mmos uses my docker setup
      since when?
      • karsten13K Offline
        karsten13 @sdetweil
        from the beginning
          sdetweil @karsten13
          @karsten13 hm…
            karsten13 @sdetweil
            well, I did not promote it because the image base was to old (beside other problems) but in 2024 I decided to do a complete refactor so now the image build (iso, not docker) is done by me with gitlab based on the current raspian bookworm os lite.
              sdetweil @scottwalsh
              @scottwalsh please dont double post
                scottwalsh @sdetweil
                The host is a pi zero 2w - so is on the low spec side.
                  @sdetweil said in MagicMirrorOS build intermittently not starting mm container (Version 2.30):
                  Apologies, user error.
                    @scottwalsh how big is the swap file?
                    free -m
                    will tell you
                    S karsten13K 2 Replies Last reply Reply Quote 0
                      free -m
                      scottwalsh@calendar:~ $ free -m
                                     total        used        free      shared  buff/cache   available
                      Mem:             425         210          66           0         204         214
                      Swap:           1023         203         820
                        sdetweil @karsten13
                        @karsten13 @scottwalsh
                        bookworm is about 500m bigger that bullseye
                        so swap is critical on small memory machines
                        • 3 / 3
