    MagicMirrorOS build intermittently not starting mm container (Version 2.30)
    23 Posts 3 Posters 5.9k Views 3 Watching
    • karsten13K Online
      karsten13 @scottwalsh
      @scottwalsh said in MagicMirrorOS build intermittently not starting mm container (Version 2.30):
      However, I am finding if power cycle it, sometimes the calendar does not load up and just have a blank screen.
      I don’t know if this is related to the docker setup but I think not. I have encountered similar problems depending on slow hardware and/or heavy load on start due to many modules starting in parallel or starting after fresh boot.
      So you could try to change the start order of the modules (order in config.js), e.g. put the calendar as first.
      @sdetweil said in MagicMirrorOS build intermittently not starting mm container (Version 2.30):
      @scottwalsh that is not MagicMirrorOS
      that is karstens docker container
      mmos uses my docker setup
        sdetweil @karsten13
        @karsten13
        since when?
        • karsten13K Online
          karsten13 @sdetweil
          from the beginning
            sdetweil @karsten13
            @karsten13 hm…
            • karsten13K Online
              karsten13 @sdetweil
              well, I did not promote it because the image base was to old (beside other problems) but in 2024 I decided to do a complete refactor so now the image build (iso, not docker) is done by me with gitlab based on the current raspian bookworm os lite.
                sdetweil @scottwalsh
                @scottwalsh please dont double post
                  scottwalsh @sdetweil
                  The host is a pi zero 2w - so is on the low spec side.
                    Apologies, user error.
                      @scottwalsh how big is the swap file?
                      free -m
                      will tell you
                      S karsten13K 2 Replies Last reply Reply Quote 0
                        free -m
                        scottwalsh@calendar:~ $ free -m
                                       total        used        free      shared  buff/cache   available
                        Mem:             425         210          66           0         204         214
                        Swap:           1023         203         820
