    MagicMirrorOS build intermittently not starting mm container (Version 2.30)
    23 Posts 3 Posters 7.6k Views 3 Watching
    • karsten13K Offline
      karsten13 @sdetweil
      well, I did not promote it because the image base was to old (beside other problems) but in 2024 I decided to do a complete refactor so now the image build (iso, not docker) is done by me with gitlab based on the current raspian bookworm os lite.
        sdetweil @scottwalsh
        @scottwalsh please dont double post
          scottwalsh @sdetweil
          The host is a pi zero 2w - so is on the low spec side.
            @sdetweil said in MagicMirrorOS build intermittently not starting mm container (Version 2.30):
            Apologies, user error.
              @scottwalsh how big is the swap file?
              free -m
              will tell you
              S karsten13K 2 Replies Last reply Reply Quote 0
                free -m
                scottwalsh@calendar:~ $ free -m
                               total        used        free      shared  buff/cache   available
                Mem:             425         210          66           0         204         214
                Swap:           1023         203         820
                  sdetweil @karsten13
                  @karsten13 @scottwalsh
                  bookworm is about 500m bigger that bullseye
                  so swap is critical on small memory machines
                    karsten13 @sdetweil
                    mmos is critical with pi zero 2w, I had a user who gave up, but it depends on installed modules and quality of used sd-card.
                    CONF_SWAPSIZE=1024 (if not changed by user)
                      @scottwalsh can you show w MagicMirror running…
                        scottwalsh
                        An observation, if I power cycle the pi, there is a good chance of it not starting up with the errors in the original post.
                        Once leave it for five min for all the processes to start (and fail), then run docker compose up -d --force-recreate, it seems to be stable from then on and works well.
                          scottwalsh@calendar:/opt/mm/run $
                          scottwalsh@calendar:/opt/mm/run $ docker compose up -d --force-recreate
                          [+] Running 5/5
                           ✔ Container watchtower  Started        42.0s
                           ✔ Container labwc       Started        41.9s
                           ✔ Container init        Started        42.2s
                           ✔ Container mmpm        Started        42.4s
                           ✔ Container mm          Started        5.3s
                          scottwalsh@calendar:/opt/mm/run $ docker ps
                          CONTAINER ID   IMAGE                          COMMAND                  CREATED         STATUS                   PORTS        NAMES
                          a1cb1b400de1   karsten13/mmpm:latest          "/home/node/entrypoi…"   3 minutes ago   Up 2 minutes             0.0.0.0:6789->6789/tcp, :::6789->6789/tcp, 0.0.0.0:7890-7891->7890-7891/tcp, :::7890-7891->7890-7891/tcp, 0.0.0.0:8907->8907/tcp, :::8907->8907/tcp   mmpm
                          f7ec5d32f0bd   karsten13/magicmirror:latest   "/usr/bin/tini -- ./…"   3 minutes ago   Up About a minute        mm
                          74193ae14fbf   karsten13/labwc:latest         "/entrypoint.sh"         3 minutes ago   Up 2 minutes        labwc
                          bcf30cd7bb10   containrrr/watchtower:latest   "/watchtower --inter…"   3 minutes ago   Up 2 minutes (healthy)   8080/tcp        watchtower
                          scottwalsh@calendar:/opt/mm/run $ free -m
                          Mem:             425         236         134          36         141         189
                          Swap:           1023         296         727
                            @scottwalsh probably swap file speed bound
                              @scottwalsh
                              the script /opt/mm/install/install.sh is executed with every reboot.
                              As workaround you could add
                              sleep 10s
                              at the end (where you have to play with the sleep seconds).
                                scottwalsh @karsten13
                                @karsten13 said in MagicMirrorOS build intermittently not starting mm container (Version 2.30):
                                Is that executed on the OS boot, or by one of the containers as they start?
                                I was thinking of a workaround like that to introduce a pause. Given the low machine spec, it seems to be busy for about 5min after sshd starts, so will just try a 300 sec sleep.
                                  @scottwalsh
                                  on OS boot
                                    scottwalsh
                                    As an update, based on the pointers from @KARSTEN13 and @SDETWEIL, have a workaround.
                                    Had three issues going on.
                                    1:
                                    I found that on a graceful reboot (shutdown -r now) that it would generally start fine, but not on an ungraceful reboot (power cycle the machine).
                                    Looks like when it was ungraceful reboot, the labwc container would show with uptime of (for example) five hours when ‘docker ps’, even though the machine was rebooted 20min ago after ‘docker compose up’ was executed by install.sh. Whereas the magicmirror container would have recently started.
                                    I assume kind of lock file confusing things?
                                    Workaround was to change the first ‘docker compose up’ install.sh to ‘docker compose up -d --force-recreate’
                                    2:
                                    I’d also included a pause and --force-recreate at the end of the install.sh and noted it was never executing as per @KARSTEN13’s suggestion.
                                    Looked like the install.sh script was hanging at docker compose pull.
                                    Commented that out.
                                    3:
                                    Lastly, the initial ‘docker compose up -d --force-recreate’ in install.sh would still fail often with the mm container restarting with logs as per the original post.
                                    With a 7 min pause and then second ‘docker compose up -d --force-recreate’ it seems to start the second time well (3min wasn’t enough, 5min was better, 7min seems to work).
                                    Workaround is a bit on the slow side, at some point will see if can refactor it a bit so that a pull for updates occurs.
                                    Extract of resulting install.sh below.
                                    _info "--> Pulling docker images and starting magicmirror"
                                    # need sudo for docker here if docker was installed with this script
                                    # use up so mm can start if there are already local images
                                    _info "--> Pre Start Pause for 2min"
                                    sleep 120
                                    _info "--> Start and recreate"
                                    $_sudo docker compose up -d --force-recreate
                                    #_info "--> Pull Pause for 1 min"
                                    #sleep 60
                                    # pull new images
                                    #_info "--> Image Pull"
                                    #$_sudo docker compose pull
                                    #_info "--> Restart Pause for 1 min"
                                    #sleep 60
                                    # restart (only if new images pulled)
                                    #_info "--> Restart stopped"
                                    #$_sudo docker compose up -d
                                    _info "--> Final Pause for 7 min"
                                    sleep 720
                                    _info "--> Final  start and recreate"
                                    if [[ "$_sudo" == "sudo" ]]; then
                                      _info "--> Reboot needed, starting in 120 sec. (use ctrl-c to skip)"
                                      sleep 120
                                      sudo reboot now
                                    fi
                                    # cleanup
                                    $_sudo docker image prune -f
                                    • S smegbadger referenced this topic on
