    MMM-Carousel CSS influence
    2 Posts 2 Posters 960 Views 2 Watching
    • C Offline
      chrisfr1976
      I used MMM-Carousel more or less since the beginning on my mirror (over 1 year :).
      A few days ago I discovered and issue in the “bottom_bar” region. The bottom bar was not in the bottom at all. It was shifted up like 30px. I searched for the issue but all I found in that region was the MagicMirror body.
      So I adjusted custom.css and even main.css. But without any change on that.
      Then I deactivated modules in other regions. And “uups”, after Carousel was disabled everything was fine again.
      So I reinstalled that module completely. rm -r MMM-Carousel and then again git clone ... instead of git pull. That solved that Issue. Maybe during the past some more has changed in that module or maybe there were some old node_modules inside (maybe npm install was necessary in the past. Don’t know).
      I just wat to tell this if someone is discovering the same behavior.
      Regards, Chris.
      S 1 Reply Last reply Reply Quote 2
        sdetweil @chrisfr1976
        @chrisfr1976 for educational purposes, before you go reinstalling a module you THINK has been modified, do
        git status
        in the module folder
        this will tell you if any shipped files have been changed
        git diff will show you WHAT changed
