    Standard Weather Module showing unwanted header
    11 Posts 3 Posters 1.5k Views 2 Watching
      rkorell @karsten13
      @karsten13 said in Standard Weather Module showing unwanted header:
      there is no property with above name
      the part of module code I’ve meant is obvioulsy doing something wrong:
      getHeader is “explained” as “// Override getHeader method.”
      	getHeader () {
      		if (this.config.appendLocationNameToHeader && this.weatherProvider) {
      			if (this.data.header) return `${this.data.header} ${this.weatherProvider.fetchedLocation()}`;
      			else return this.weatherProvider.fetchedLocation();
      		return this.data.header ? this.data.header : "";
      I’ve simply replaced this with
      getHeader () {
      		return "";
      And - no surprise - header disappears.
      Regards,
      Ralf
        rkorell @rkorell
        @rkorell OK, just seen at least one other mistake:
        I’ve picked “appendLocationToHeader” but this should be “appendLocationNameToHeader” …
          rkorell @rkorell
          @karsten13 ,
          yupp this seems to do the trick.
          undoing code changes and adding
          appendLocationNameToHeader: false,
          to weather config let the header disappear …
          Thanks!
          Ralf
          (not understood why and how but at least this way the header lines are really not present - the blackness idea makes them invisible but they still occupy room.)
            sdetweil @rkorell
            @rkorell the old weather api returned the location Name, and someone decided to show it in the MagicMirror module header field
            but you can disable this function by setting the config property to false (default true)
            the v3 api does NOT return the location Name, so you need to set the property to false AND YOU have to set the header manually
            header:“…”, after the module:“weather”,
              rkorell @sdetweil
              Dear Sam,
              Thanks for this.
              Which one of the config properties are you referencing to?
              I‘ve set
              header: „“
              This definitely doesn‘t work because it‘s overwritten somewhere
              Regards,
              Ralf
                sdetweil @rkorell
                @rkorell said in Standard Weather Module showing unwanted header:
                and for header
                     module:"weather",
                     header:"something",
                     position:
                all of these properies belong to MagicMirror, same for every module
                https://docs.magicmirror.builders/modules/configuration.html#module-configuration
                  rkorell @sdetweil
                  Yeah.
                  OK, already found this…
                  Regards,
                  Ralf
