    Standard Weather Module showing unwanted header
    11 Posts 3 Posters 1.6k Views 2 Watching
      rkorell @karsten13
      @karsten13 OK, have found this as part of an if clause and as member of defaut configuration in module code.
      If this causes the unwanted behaviour: sorry!
      Thanks.
      Ralf
        rkorell @karsten13
        @karsten13 nope :-(
        Deleting “appendLocationToHeader” doesn’t resolve the issue…
        One of the headers (in this case weather_forecast instance) immediatly shows up if I disable the blackness of text/border-bottom …
        Regards,
        Ralf
          rkorell @karsten13
          @karsten13 said in Standard Weather Module showing unwanted header:
          there is no property with above name
          the part of module code I’ve meant is obvioulsy doing something wrong:
          getHeader is “explained” as “// Override getHeader method.”
          	getHeader () {
          		if (this.config.appendLocationNameToHeader && this.weatherProvider) {
          			if (this.data.header) return `${this.data.header} ${this.weatherProvider.fetchedLocation()}`;
          			else return this.weatherProvider.fetchedLocation();
          		return this.data.header ? this.data.header : "";
          I’ve simply replaced this with
          getHeader () {
          		return "";
          And - no surprise - header disappears.
          Regards,
          Ralf
            rkorell @rkorell
            @rkorell OK, just seen at least one other mistake:
            I’ve picked “appendLocationToHeader” but this should be “appendLocationNameToHeader” …
              rkorell @rkorell
              @karsten13 ,
              yupp this seems to do the trick.
              undoing code changes and adding
              appendLocationNameToHeader: false,
              to weather config let the header disappear …
              Thanks!
              Ralf
              (not understood why and how but at least this way the header lines are really not present - the blackness idea makes them invisible but they still occupy room.)
                sdetweil @rkorell
                @rkorell the old weather api returned the location Name, and someone decided to show it in the MagicMirror module header field
                but you can disable this function by setting the config property to false (default true)
                the v3 api does NOT return the location Name, so you need to set the property to false AND YOU have to set the header manually
                header:“…”, after the module:“weather”,
                  rkorell @sdetweil
                  Dear Sam,
                  Thanks for this.
                  Which one of the config properties are you referencing to?
                  I‘ve set
                  header: „“
                  This definitely doesn‘t work because it‘s overwritten somewhere
                  Regards,
                  Ralf
                    sdetweil @rkorell
                    @rkorell said in Standard Weather Module showing unwanted header:
                    and for header
                         module:"weather",
                         header:"something",
                         position:
                    all of these properies belong to MagicMirror, same for every module
                    https://docs.magicmirror.builders/modules/configuration.html#module-configuration
                      rkorell @sdetweil
                      Yeah.
                      OK, already found this…
                      Regards,
                      Ralf
