    Module stuck on loading?
    11 Posts 2 Posters 2.1k Views 2 Watching
    • C Offline
      croc_dad72
      Sorry if this has been asked before, l did a search but could find anything, but maybe I am wording it wrong?!
      I have two MM displays that display the same thing, and one of them all of sudden is not loading one of the modules (stuck in loading), but the other is fine? Ive tried clearing the browser history and cookies, restarting MM, and reinstalling the module, but so far none of that has worked. A search for the issue on the internet says something about display settings? I haven’t changed any settings, and it was working fine for years?
      Any help or direction would be greatly appreciated!
      S C 2 Replies Last reply Reply Quote 0
        sdetweil @croc_dad72
        @croc_dad72 can you tell us the module?
        also, can you look at the messages where MagicMirror is started?
        if using pm2 then
        pm2 logs --lines=100
        and what changed since it worked last
        • C Offline
          croc_dad72 @croc_dad72
          @croc_dad72 its the MMM-OpenWeatherForecast, here is what I got when I ran the logs? And nothing has changed, ive done nothing new or changed anything in months
          0|mm  | [2025-05-01 10:01:24.797] [INFO]  Start Album scanning
          0|mm  | [2025-05-01 10:01:24.797] [INFO]  Getting album list
          0|mm  | [2025-05-01 10:01:28.333] [INFO]  Finish Album scanning. Properly scanned : 1
          0|mm  | [2025-05-01 10:01:28.333] [INFO]  Albums: Family
          0|mm  | [2025-05-01 10:01:30.093] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
          0|mm  | [2025-05-01 10:01:30.120] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
          0|mm  | [2025-05-01 10:01:30.572] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
          0|mm  | [2025-05-01 10:01:30.600] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
          0|mm  | [2025-05-01 10:01:30.905] [INFO]  Calendar-Fetcher: Broadcasting 3 events.
          0|mm  | [2025-05-01 10:01:31.900] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
          0|mm  | [2025-05-01 10:01:33.550] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
          0|mm  | [2025-05-01 10:01:33.800] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
          0|mm  | [2025-05-01 10:01:33.844] [INFO]  Newsfeed-Fetcher: Broadcasting 12 items.
          0|mm  | [2025-05-01 10:01:34.002] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
          0|mm  | [2025-05-01 10:01:34.087] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
          0|mm  | [2025-05-01 10:01:39.488] [ERROR] Trace: [GPHOTOS:CORE] request fail with URL mediaItems:search
          0|mm  |     at GPhotos.logTrace (/Users/edith02/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:128:13)
          0|mm  |     at GPhotos.request (/Users/edith02/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:169:12)
          0|mm  |     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          0|mm  |     at async getImage (/Users/edith02/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:249:24)
          0|mm  |     at async Class.getImageList (/Users/edith02/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:326:20)
          0|mm  |     at async Class.scanJob (/Users/edith02/MagicMirror/modules/MMM-GooglePhotos/node_helper.js:230:23)
          0|mm  | [2025-05-01 10:01:39.488] [ERROR] Trace: [GPHOTOS:CORE] params null
          0|mm  |     at GPhotos.request (/Users/edith02/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:170:12)
          0|mm  | [2025-05-01 10:01:39.488] [ERROR] Trace: [GPHOTOS:CORE] data {"albumId":"AIZ7-TXwFwVFz0OQvrAkerk3douEpzxDS_ZuekvM1P3EaYgKG2D-X3dX4SgFcX8jWEwZU7uhOPEm","pageSize":50,"pageToken":"CpgBCkR0eXBlLmdvb2dsZWFwaXMuY29tL2dvb2dsZS5waG90b3MubGlicmFyeS52MS5TZWFyY2hNZWRpYUl0ZW1zUmVxdWVzdBJQCkxBSVo3LVRYd0Z3VkZ6ME9RdnJBa2VyazNkb3VFcHp4RFNfWnVla3ZNMVAzRWFZZ0tHMkQtWDNkWDRTZ0ZjWDhqV0V3WlU3dWhPUEVtEDIS4gFBSF91UTQwdnFKRTVyaWp1Tk5qMGlsQVcwT05JMFUzRjZta0pocUZ1WE90TldWa2dxaHpGSk1CNmlhay1wbjhMaGdPYXdWeHgxOVM3R2FnRmlDdENIYjhUMjhZbnFpUDNLbTdMV1VDLWxGSXBZek9SYUE3d1Npd0VzVlRDU1pORTNLTVBWelQyNGw1OEJfX0dybVpCNHFGMzFiMHg0M2MyZ2ZpOEpZTEF4NWxQbXNoOHBhTzU4ZWNVeDBCUmplY2hpb1dnckI4WFdyNWd6ZF9oRFh1RElxbk9ad3BCTEU4dFF3Ghs3WHptcEp2U3hmYlpKMkJsZlVWdlprcjZJWWs"}
          0|mm  |     at GPhotos.request (/Users/edith02/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:171:12)
          0|mm  | [2025-05-01 10:01:39.488] [ERROR] [GPHOTOS:CORE] response.data:
          0|mm  | {"error":{"code":503,"message":"The service is currently unavailable.","status":"UNAVAILABLE"}}
          0|mm  | response.status:
          0|mm  | 503
          0|mm  | headers:
          0|mm  | {"vary":"Origin, X-Origin, Referer","content-type":"application/json; charset=UTF-8","date":"Thu, 01 May 2025 15:01:39 GMT","server":"ESF","x-xss-protection":"0","x-frame-options":"SAMEORIGIN","x-content-type-options":"nosniff","alt-svc":"h3=\":443\"; ma=2592000,h3-29=\":443\"; ma=2592000","transfer-encoding":"chunked"}
          0|mm  | config:
          0|mm  | {"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/json","Authorization":"Bearer ya29.a0AZYkNZgUJ7_4Iw75fVY03dlHpDzi-hR6g16ov-dU0E302z-EjzcpLabDKUtFieuu9VRs8O7R5HUvelsqoUJHrtfn9u6n3kpgoJOiYTe__6vhtNgzDughB_7UPGpwnnFUApbGODTiLDIvqsif7eHV27K8qiEMnjFw7qywcRJtGpQaCgYKAbISARISFQHGX2Mikx21kUNPK_Cwv-hP1L9xow0178","User-Agent":"axios/1.6.8","Content-Length":"670","Accept-Encoding":"gzip, compress, deflate, br"},"method":"post","url":"mediaItems:search","baseURL":"https://photoslibrary.googleapis.com/v1/","data":"{\"albumId\":\"AIZ7-TXwFwVFz0OQvrAkerk3douEpzxDS_ZuekvM1P3EaYgKG2D-X3dX4SgFcX8jWEwZU7uhOPEm\",\"pageSize\":50,\"pageToken\":\"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\"}"}
          0|mm  | [2025-05-01 10:01:39.489] [ERROR] response.data:
          0|mm  | 503
          0|mm  | headers:
          0|mm  | config:
          0|mm  | [2025-05-01 10:01:39.489] [INFO]  Next scan will be at 2025-05-01T15:56:24.797Z
          0|mm  | [2025-05-01 10:01:50.189] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
          0|mm  | [2025-05-01 10:02:06.225] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
            @croc_dad72 ok, i would first disable googlephotos
            add
            disabled:true,
            after the
            module:
            line
            google changed the way google photos works
            • C Offline
              @croc_dad72 I did read that google was changing, but it seems to be still working, still rotating and I still see new photos pop up, so I wasn’t going to remove it until is stopped working, unless you think its interfering with the other modules?
              • C Offline
                @croc_dad72 Well I completely removed my Mirror, and reinstalled it and I’m still having the same issue, the module is showing on one display but not the other? I’m at a loss?!
                  @croc_dad72 open the developers window on not showing
                  ctrl-shift-i , select the console tab and add photo to the filter field
                  • C Offline
                    croc_dad72 @sdetweil
                    @sdetweil said in Module stuck on loading?:
                    • C Offline
                      @croc_dad72 I don’t understand what your saying I should do? It’s not the photo module I’m having issues with it the weather one.
                        @croc_dad72 weather is done all in browser, note that the new apikey only allows 1000 total requests per day, across ALL browsers.
                        so put weath in the filter field, trying to see any errors that might cause this. in the logs the photos modules was having significant troubles
                          @croc_dad72
                          can you install MMM-LogExt or MMM-Logging
                          to send the browser logs to npm start
                          logs, so we have them in one place
