    MMM-EnvCanada stopped working ...
    26 Posts 8 Posters 7.4k Views 9 Watching
      sunsetrider @sdetweil
      @sdIetweil
      Hello:
      Thanks for your info.
      I changed my config file to access apiVersion: 3.0
      It does not work for me.
      I did not change any other config values in the weather module calls (current and forecast).
      Seems someone has updated the envCanada module. I will give it a shot later.
      MM
        sdetweil @sunsetrider
        @sunsetrider right. just changing apiVersion back to 3.0 isn’t all that is required…
        the endpoints changed, and you now need lat and lon,
        and the header location has to be added manually…
        api 3.0 requires a credit card , and provides 1000 uncharged api request per day.
        • crazylegsC Offline
          crazylegs @charlesf
          @charlesf I took a quick look at your solution and happy to hear that it works! I agree that being able to preserve all the XML parsing is definitely the way to go. To be honest, I was assuming that your approach (parsing the correct file out of the directory listing) was going to be a massive PITA, but I think you did a very nice job! Congrats!
          And if you don’t mind, I hope to lean on your solution to make updates to the envCanada provider code when I get a chance :)
          To anyone using the envCanada provider in the default Weather module: I’m the original author of the envCanada provider. I have been traveling and unable to make corrections to the code, but I do hope to get it all working sometime in August (the earlier the better).
          charlesfC 1 Reply Last reply Reply Quote 0
          • charlesfC Offline
            charlesf @crazylegs
            @crazylegs Thanks. And by all means use as you see fit. I borrowed heavily from your code when I wrote my module 2 years ago.
            Perhaps you can educate me: when I fetch the xml file the async process seems to wait till it is done and then the data is available. But if I use the same steps to fetch the directory list, the calling function receives a pending promise. That’s why I implemented the fetching of the xml file within what is effectively a call back - it didn’t work otherwise, but I can’t see what is different between the two cases. But as I said earlier, I don’t know much about this environment - I am am old assembler/C/C++/C# coder from the mists of time.
              sdetweil @charlesf
              @charlesf is the function for the directory list marked async?? if so, then you could await it
              • charlesfC Offline
                charlesf @sdetweil
                @sdetweil yes, and that is how I started, but it didn’t work.
